Throttle Cable Help
Old Nov 4, 2003
R3DL1N3's Avatar
Arrow Throttle Cable Help
ok this is really starting to **** me off. on friday i decided i wanted to up my idle to 1000rpm just to test it out. well i started messing with my throttle cable (not the first time ive done this) and i never could get it to exactly 1000rpm so i said **** it. put it back to normal. then today i started messing with it again. i pulled the cable as far right as it would go and tightened it, when i test drove it every time i pressed the clutch in it would jump to 3000rpm. so i was like wtf. and tried to fix it. after school i went to my local racing shop to work on it some more. once again i pulled the cable as far right as it would go and tightened it. then i revved it. it started to idle at 2500rpm. so i fixed it and i pulled it enough to where i could leave. theres not very much slack in the cable, but at the same time it seems that the idle has dropped down to like 650 or something. wtf is going on. also when i pulled into my garage i decided to rev it a couple times. i started looking at my A/F ratio gauge while revving and i noticed that when i revved it to no more than 3000rpm the A/F ratio just stayed lean but i had to rev it really hard before it would jump to rich. could someone tell me how to fix this problem?
Old Nov 4, 2003
R3DL1N3's Avatar
umm yeah i really do need help here k thx..
Old Nov 5, 2003
ohmysac's Avatar
ohmysac is an unknown quantity at this point
ummm...well i think most people would say you shouldnt be messing with the throttle cable...but that wont help ya
Old Nov 5, 2003
cambo's Avatar
I wish I was asian
ECU trying to over compensate for something maybe?
Old Nov 5, 2003
SMURF_KILLER's Avatar
SMURF_KILLER is an unknown quantity at this point
Hate to say this but go to dealer and have them readjust it for you....Thats all i can think of
Old Nov 5, 2003
SILVERSI's Avatar
SILVERSI is an unknown quantity at this point
THE COMPUTER IS TRYING TO ADJUST FOR YOUR OVERCOMPENSATION. THE IDLE IS NOT SOMETHING THAT SHOULD BE MIESSED WITH, ANYTING YOU DO THE COMPUTER WILL TRY AND TAKE IT BACK TO WHERE IT SHOULD BE.
Old Nov 5, 2003
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
And your A/F guage is useless...
Old Nov 5, 2003
cambo's Avatar
I wish I was asian
uhh..caps lock dude. try it out sometime.
Old Nov 5, 2003
IronFist's Avatar
I have no idea what I'm talking about, but...
I would say get the idle back to where you want it and then reset the ECU. That might fix it.
Notice my proper use of CAPS LOCK key.
Old Nov 6, 2003
03civicdx's Avatar
03civicdx is an unknown quantity at this point
im with ironfist on this one sounds like you might have to reset the ecu to trick it to staying where it should be
Old Nov 6, 2003
obtix's Avatar
www.AbsouluteDriven.com
obtix is an unknown quantity at this point
Re: Throttle Cable Help
Well first off you A/F gauge only has an real reading when you give the car full throttle... It all the pretty lights are just pretty lights until you gun the car then those pretty lights mean something.
If you have your throttle cable so that there is no slack id leave it there (thats where mine is) if you want to let the car idle at 1,000rpm press your foot on the gas lightly when you stop.. there is no point to do that on a daily driver.
Old Nov 6, 2003
Green Civic's Avatar
Ya, try unhooking your battery to reset your ecu. Than hook the battery back up and turn on the car. If that doesnt work, go to honda.
Old Nov 6, 2003
mad03civic's Avatar
mad03civic is an unknown quantity at this point
Just take it to the dealer
Tyler93
Mar 20, 2016 09:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
Bruce2
Sep 27, 2015 08:45 PM
Matt T
Idle Issues
Sep 24, 2015 04:53 AM
Bricoleur
Sep 9, 2015 12:30 PM
