Upgrade Suspension? What is your Fav?
Old Oct 29, 2003
halflife's Avatar
halflife is an unknown quantity at this point
I Currently have Nuespeed Race springs with 18 in racing hart c5's. I love the look. Nice and low and the rear tire is tucked a little. However the ride sucks. It is very ruff over bumps and bouncy at high speeds.
?is, What stut/shock should I upgrade to and keep the Nuespeed Race springs with an improved ride. Or should I just replace the whole thing.
Would prefer not to spend too much cash but if it would improve things dramatically I could spend some cash. Basically, I want a slammed ride that drives like stock.
Thanks for the advice
Old Oct 29, 2003
civicvtec1ps's Avatar
Search and Learn
since you dont wanna spend too much cash. koni yellow shocks would be nice with neuspeed race springs.
tein basic/ss wont go low as race springs. however b&g fullcoilovers will.
Old Oct 29, 2003
Zzyzx's Avatar
Autocross Junky
Rough is caused by the springs (Neuspeed Race have a high spring rate) bouncy is cause by to weak of shocks.
So Pick up some Konis. that should take care of the bounce, but for ride harshness, you'd have to get softer springs.
On second thought, a lot of the roughness could be caused by your 18's
Old Oct 29, 2003
halflife's Avatar
Thanks for the info. Will the Koni's help the suspension BANG when I am driving over the mountainous potholes of NYC?
Old Oct 29, 2003
Zzyzx's Avatar
Autocross Junky
Bang? are you bottoming out? THey may help alittle by slowing down the springs.
Old Oct 29, 2003
4bangin's Avatar
i dont think the bang is bottoming out. it could be, but i get the bang too. its just the nature of the civic, when u hit a pothole, it sound slike the ****ing car is gunna fall apart. it isnt as loud with stock tires on, but with some low pros it sucks, and lowering it makes it sound even worse.
just try to avoid potholes, although i live in pa and it is damn near impossible to miss them all, i cant even imagine what nyc is like!
Old Oct 29, 2003
TriptronicCIVIC's Avatar
TriptronicCIVIC is an unknown quantity at this point
the bang is probably because you have shitty shocks or they blew.... i used to have ground controls for my civic ... and when i went over a pothole it was VERY VERY LOUD!!!! i had 19's on too... but when i changed to KW however... the bang went away.... i purposly went over the same pothole after i installed my KW's.... mind you that i still had my 19's on... what i suggest is that you save your money and buy the whole shabang... shock/strut combo.... i've heard ppl still having problems with the koni yellows and sleeved coils...
Old Oct 30, 2003
halflife's Avatar
Money is not the issue, I just have the race springs already so was looking just for some reco's on shocks which i know are cheap. if money was not an issue what would you use then?
Old Oct 30, 2003
4bangin's Avatar
you forgot the little / in the last [img] tag in your sig.
Old Oct 30, 2003
PunkingCivic's Avatar
I need TP for my bunghole
get Teins. I had the neuspeed sports on and it is bouncy, corner great but man ifyou have to **** for get it. it is like shaking a coke can, when will it burst.
This site has the Tein basic package for $880.00
http://www.prostreetonline.com/pso/p...asic+Coilovers
Old Oct 30, 2003
halflife's Avatar
where do i put the / ?
Old Oct 30, 2003
robbclark1's Avatar
Retired suspension supermod.
no you added an extra / before the http.
Old Oct 30, 2003
halflife's Avatar
thanks
Old Oct 30, 2003
CivicHX01's Avatar
i have gc/koni setup and i'd say the ride is ok and i'm content with my setup...
however, if i were to do it again, i'd go with the full coilover setup from the beginning
Old Oct 30, 2003
jedo's Avatar
jedo is an unknown quantity at this point
by the way, how do we know if our shocks have bottomed out?? how do we differentiate?
Old Oct 31, 2003
CivicHX01's Avatar
when the shocks can't travel any more, your upper mount will hit the bump stop... you'll hear a loud "bang" depending on how fast you were going on that bump....
thats when you know you've "bottomed out"
Old Nov 2, 2003
jdmb16ahatch's Avatar
jdmb16ahatch is an unknown quantity at this point
i love my tein flex coilover
Old Nov 2, 2003
ELaudio's Avatar
ELaudio is an unknown quantity at this point
I've been looking into several coilover kits for my ride. Right now I'm favoring the Teins, based on reviews, price, etc... Now I'm wondering if I should go with the basic kit, the SS or the Flex kit. I know the SS and Flex kits offer adjustment to the damping rate, while the basic kit doesn't. Is this a major issue?
Also, how much of a drop can you get with tein coilovers? I'm looking for about 1.5 to 2.0 inches. jdmb16ahatch, did you have an alignment kit installed as well. I'd like to keep my camber in check - don't want that silly el-cheapo cut-the-springs look. Nor do I want to replace my tires every 5000 miles...
Any info would be greatly appreceiated!
Old Nov 3, 2003
about to order the camber kit for the rear the flex have front adjustment built into the upper mount
Old Nov 3, 2003
robbclark1's Avatar
the flex gives you higher springs rates (if you get the EP3), a pillowball upper mount, and front camber adjustment.
Old Nov 4, 2003
Drifter's Avatar
Drifter is an unknown quantity at this point
That bang is your shocks bottoming out. I had H&R race with illuminas cause I was on a bit of a budget and loved the combo it rode good and the shocks never did blow and are still in use to this day with no signs of being blown.
Old May 25, 2004
GaryC17's Avatar
GaryC17 is an unknown quantity at this point
Are you driving an EM ? Where did you get those illuminas ?
Old Jul 27, 2004
joshuajoh's Avatar
joshuajoh is an unknown quantity at this point
ive got my ride on progress springs. rode suprisingly well with my stock shocks until they blew. i love my springs ... ive only come across a few posts who mention having progress springs. i just ordered sum tokico hp's. cant wait.
Old Jul 27, 2004
dragoon's Avatar
hayame v1's, if you can find them.
Old Jul 27, 2004
clownprince's Avatar
Ricerus Maximus
I've got the Neuspeed Race springs like you and have it on Tokico's as well. Of course they don't perform to the max like the Koni's would but they are 1304703947092375X better than stock. The drop is still low and looks damn good, rides damn good too.
Tedverseti
Apr 23, 2020 01:45 PM
Cam Diaz
Sep 29, 2015 07:17 PM
Tedverseti
Sep 29, 2015 05:41 PM
czarlun
Sep 14, 2015 08:16 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
