SRS light on after RSX-S seats swapped...
Old Aug 13, 2003
Stephon314's Avatar
Stephon314 is an unknown quantity at this point
Hi everyone
I had RSX-S leather seats with airbags swapped and everything was connected properly. However, the SRS light came on and of course I followed the steps from DIY section. The light blinked twice, then goes off for 3 seconds, and then comes on again no matter how many times I did it. I'm 100% sure that I did the steps right since it worked out on my girlfriend's ride but not mine. I also tried to disconnect the battery for 10 minutes and then put it back on but still....I know Honda dealer wouldn't help me for sure, and they are going to charge me a lot even if they could find out what the problem is since it is no longer under warranty...This is a different problem from just reseting the SRS light since the steps did not help at all... I hope someone can help me out, and I would really appreciate for any advice. THANKS A LOT!
Old Aug 13, 2003
Ronin's Avatar
Ronin is an unknown quantity at this point
--> moved to Tech Stuff
Old Aug 14, 2003
Deejai35's Avatar
Deejai35 is an unknown quantity at this point
Is it possible that one of the sensors are bad in the seats? I had airbags in my stock seats and both of the sensors went bad. The dealer replaced one sensor, reset the light, and the next morning the light was on again, because the other seat had a bad sensor too.
Old Aug 14, 2003
Bryn's Avatar
Bryn is an unknown quantity at this point
I'm sure you connected it correctly since you said you did, but you could have missed one of the yellow plugs underneath one of the seats. that would do it.
Old Aug 14, 2003
jwin5401's Avatar
jwin5401 is an unknown quantity at this point
check the fuse in the fuse box or the airbag sensor. Also the sir bag light or srs light in your dash will stay on if you have a dead battery. the dealer will charge you like forty bucks to diagnos it
Old Aug 14, 2003
Stephon314's Avatar
Thanks guys! My SRS light sensor was a defect so I had dealer changed to a new one a long time ago. The yellow plug was connected right after the DIY so it shouldn't be the main problem that caused the SRS light on...I might had blown the fuse for it? Could anyone specify which one the SRS light fuse is and where can I get a replacement? Also let me know how to check if the fuse is bad since I don't know how...-__- THANKS AGAIN!
Old Aug 25, 2003
vvhirI's Avatar
vvhirI is an unknown quantity at this point
Fuse diagram
If you have your manual, there should be a fuse diagram in there. I've got a 2001 Honda Civic EX and its manual shows every fuse and description.
Old Aug 25, 2003
aznrj's Avatar
aznrj is an unknown quantity at this point
thats what it's here for
Old Aug 25, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
lilasiian has the same issue. The SRS light comes on because the rsx seats have side airbags and your stock civic seats probably didn't, right?
Ignore it.
Old Aug 25, 2003
vvhirI's Avatar
Talking SRS light Honda FIX!!!
Found this posted in some forum. Tried it, it worked, it saved me at least a quoted $90 diagnostic. In combing many forums, it looks like many people were bent over the barrel by Honda on this one... you can't f'n trust even your friendly neighborhood Honda dealer!
Problem : SRS light on Honda (Civic, Odyssey, Accord) won't turn off.
Cause : cables underneath seats were disconnected, SRS fuse was removed/replaced (new stereo, alarm, car-starter install)
Solution : Reset the SRS funtion:
1- look underneath dash, near fusebox, for a 2-wire yellow plug, disconnect it and pull it down so you can work with it
2- turn ignition OFF
3- jumper the 2 wires together (cut paperclip in half and straighten, insert one end of both halves into back end of plug where each wire goes in, touch them together and hold)
4- turn ignition ON (SRS light will turn on for 6 seconds, then turn off)
5- within 4 seconds of SRS light turning off, unjumper the 2 wires (SRS light will turn ON)
6- within 4 seconds of SRS light turning on, jumper the 2 wires (SRS light will turn OFF)
7- within 4 seconds of SRS light turning off, jumper the 2 wires (SRS light will blink ON and OFF, indicating SRS function is reset)
Thanks to whoever originally posted this!
-Darek
Old Aug 25, 2003
Stephon314's Avatar
Thanks Darek, but it did not work out to my coupe somehow even though I tried 10+ times already...-__- I guess I have to change some fuse and stuffs since the battery wasn't disconnected while I was installing the seats...Anyone have an idea of how to do it? Thanks.
Old Aug 26, 2003
vvhirI's Avatar
SRS light (more)
I didn't have my battery connected either when I did my seats... do this:
Check your fuse under the hood (dig out your manual if the fuses aren't marked on the actual fusebox) for "SRS"... heck- if that's fried, that's the problem!
Also, does the SRS light turn on, then turn off, then turn on, etc when you're doing the jumpering/unjumpering? If it is, just watch the SRS light during the process... when you see the SRS light blink 2 or 3 times, you're home free. Just turn your ignition off for at least 10 seconds (I don't think I put that in... sorry) and then start car to try.
I had a hard time trying wedge my f'n body under the dash/steering column, then contort my arm up to the ignition, then pinch 2 paperclip shafts together and hold 'em, then let 'em go, then hold 'em... it sucked! Plus, I was in my dress clothes for work, it was about 95% humidity out, about 80° at 7:00 a.m... it was a joke.
Also, I read (probably in the same post) that a dead/weak battery may cause the SRS light to stay on.
That help? We'll get it!
Old Aug 26, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
vvwhirI everything ur sayin is already in the DIY section , and he's already tried that.. im not gonna flame just cause ur a n00bie
and the theory about the side srs makes sense.. what model is ur car ?
Old Sep 4, 2003
jay2's Avatar
jay2 is an unknown quantity at this point
U HAVE TO REINTIALIZE YOUR OPDS UNIT...AND THEY ONLY WAY TO DO THAT IS WITH A PGM TESTER AND OPDS PROBE...AND THE ONLY PEOPLE THAT HAVE THAT IS THE DEALERSHIP...
Old Sep 4, 2003
Stephon314's Avatar
Hmmm....then I guess there is nothing else I can do except having ppl from dealership taking care of my issue...-__- I'll ask my friend who is the fleat manager of McHarvey's Honda dealer and see if he can hook me up with it. Thanks man.
Old Sep 5, 2003
vvhirI's Avatar
WHY would I need a clown to reset the OPDS unit?
Burnout
Jul 15, 2022 10:24 PM
Blazz
May 25, 2015 10:56 PM
jimmyfloyd
May 20, 2015 07:06 PM
cukaracha
May 16, 2015 02:11 PM
SimDogg
Nov 27, 2001 04:20 PM
