Engine swap or rebuild D16y7
Old Mar 17, 2018
Virtaullyinsane's Avatar
Virtaullyinsane is an unknown quantity at this point
Headgasket is gone May need a new rad in my 1997 Civic Hatchback. No idea what is the best way to go
Old Mar 17, 2018
Re: Engine swap or rebuild D16y7
Depends on how bad it is, how hot it got, how much money you want to spend, what your goals are, your skills and abilities, and your tooling/equipment/space
Did I leave anything out?
Old Mar 18, 2018
mac25's Avatar
Dr Krieger of Modification
Well a rolling chassis is worth about $500 here
Another 97 hatch would run you $1700, but may develop the same issues.
getting the head gasket replaced will cost you around $1200, nearly the same as buying one.
............ or you could try to replace it your self if you can.
-head decked $100
-head gasket $150
-arp head studs $80
-coolant $18
-Honda bond $15
-your time
Old Mar 18, 2018
ok thanks for the advice. I have someone who is a licensed mechanic , works from home. I have 1500 I can spend. All the belts water pump cranck shady seal are brand new tie rods and brakes too . Body has no rust interior is mint . So I really don’t want to get another plus I paid 2500 for 6 months ago.
Old Mar 19, 2018
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
I’d get a good used engine if you can. Search around. You can get these engines for a few hundred dollars, which is much less than the cost of rebuilding the engine. Plus, you’ll have a lot of extra parts from the old engine.
SilverScyth
May 2, 2017 06:25 PM
btungcab87
Mar 17, 2016 11:52 PM
honda5272
Apr 1, 2013 12:53 AM
packrat79
Jun 15, 2012 07:12 PM
jeremiahm
Apr 26, 2012 12:37 AM
