It has arrived !!!
Old May 24, 2003
n318z's Avatar
n318z is an unknown quantity at this point
It has arrived !!!
Well, I ordered my extreme turbo discounters kit may14th and it arrived today !
Now I don't know if I can answer any questions anyone might have yet because it's not installed but, I have two problems already. I wasn't sent a fuel pressure regulator and the directions are for a "generic 4 cylinder" So ..... tomorrow I will call Brad and hopefully get this resolved. Also, does anyone know of a source for the wiring schematic for our ecu
I will continue to update everyone and try to answer any questions you have from a
"buyers point of view"
Old May 24, 2003
Weaponx12o's Avatar
you can be our guinea pig!! tell us how it works out, and remember to post pics!!
Old May 24, 2003
n318z's Avatar
Absolutely ........ however, I won't be installing until May 31, expect full report and DYNO a few days after that.
Old May 24, 2003
krayziebonet4l's Avatar
Samoan<^>(-_-)<^>Power
krayziebonet4l is an unknown quantity at this point
congrats, cant wait for those dyno #s.
Old May 24, 2003
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
the extreme kit is set up to run like 5psi, the most you can run on any stock engine is 5psi before needing a fuel system to keep from running lean, mabey thats the reason they didnt include a fuel pressure regulator......... keep us informed..........
Old May 24, 2003
MadWheel's Avatar
Premium Boosted Member
Nawe cuz the Extreme kit comes with an FPR and a dual-injector setup for the throttle body to add more fuel. I knew someone would have this soon, can't wait to see some results!
Old May 25, 2003
SaiyanMatador's Avatar
SaiyanMatador is an unknown quantity at this point
hmm aluminum block + turbo = bad, good = iron sleeve the cylinders then boost
eric
Old May 25, 2003
ohmysac's Avatar
ohmysac is an unknown quantity at this point
i can help you out with the ecu wiring...what wires do u need?
Old May 25, 2003
n318z's Avatar
I need the ecu location for the RPM signal and where to connect to the parking brake wire, ignition, and the ACC on DC
Old May 25, 2003
MadWheel's Avatar
I should try to write this info down, I'll need to do the same thing when I have it.
Old May 25, 2003
ohmysac's Avatar
what are you doing? installing a turbo timer? I just installed mine yesterday...apexi auto timer...what do u mean by ACC on DC (accessory on ???)
Old May 25, 2003
n318z's Avatar
One of the features is a turbo timer and i imagine you're correct ACC on DC must be accesories on DC
Old May 25, 2003
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
me too
Injen
Old May 26, 2003
ohmysac's Avatar
ok...i'm not sure how your timer hooks up so i'll just list off the wires going to the ignition switch...
Accessory - White/Red
Constant 12v - White
IG1 - Black/Yellow
IG2 - Black/Red
and for your RPM sensor wire at the ECU:
should be the BLUE wire on the top plug...
oh yeah...as for the parking brake wire...its a Green/Orange wire leading up from under the console heading towards the under dash fusebox...i installed mine directly on the switch..it was pretty heavily covered with tape and wire loom and i didnt want to cut into it
Old May 27, 2003
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
Is your car an EX or an LX? I just want to know so we can compare numbers.
Old May 27, 2003
n318z's Avatar
My car is an EX. When I post my dyno numbers I will include my other mods as well.
Old May 27, 2003
sspem2's Avatar
em2
Hey n318z I gave you a pm and you didnt answer it so here I go. I live in Tampa as well. Im by USF. Where you live at? If it isnt any trouble could I see the kit cuz Im really interested in it to? One more question you installing it or you got a shop cuz Ill be buying pistons and all that stuff and turbo and I dont know anybody who can do that kinda stuff cuz thats a lil advanced for me. Thanks man
Old May 27, 2003
n318z's Avatar
I live in south tampa and I'll PM you my number so you can see the kit. So everyone knows yes, I'll be installing the kit myself.
Old May 27, 2003
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
i wanna see it too im in tampa...let's meet up
Old May 27, 2003
n318z's Avatar
Hey guys, just got off the phone with Brad at Turbo Discounters. Are cars DO NOT need the fuel pressure regulator and he is e-mailing me some extra directions about how to install the kit. I'll keep everyone up-to-date as the install continues .....
Old May 27, 2003
Chaddck's Avatar
Chaddck is an unknown quantity at this point
Question But...
How did you manage to get the kick within 10 days? Doesn't it say on the website that it takes 3-4 weeks to get the turbo kit shipped? Just wondering...
Old May 27, 2003
n318z's Avatar
I didn't buy through the group buy, I ordered directly.
Old May 27, 2003
Chaddck's Avatar
Ok...
So have I, so I should be expecting mine with a couple of days then? Unless you specified other shipping methods than standard UPS ground. I'm not trying to point fingers, just curious since I can't wait for my boost
Old May 27, 2003
n318z's Avatar
Yeah, I was surprised myself when it showed up in two weeks with normal groung shipping
Old May 27, 2003
zinkyroo's Avatar
cool beans
zinkyroo is an unknown quantity at this point
When do you think your install is going to be complete?
Old May 27, 2003
n318z's Avatar
I'll start the install Friday May 30th, it should be done that weekend.
Old May 27, 2003
MatrixShark's Avatar
MatrixShark is an unknown quantity at this point
Good luck with the install. I know plenty of people are watching to see how you make out.
Old May 27, 2003
zinkyroo's Avatar
cool beans
Cant wait to see it in your engine bay!
Old May 28, 2003
Green Civic's Avatar
Good luck with the install. Let people know #s and all. Are you going to posta DIY? I am looking into getting the extreme kit. I got a 2001 ex coupe.
Old May 28, 2003
Niter1dah's Avatar
Niter1dah is an unknown quantity at this point
Keep us posted I am seriously considering that mod and am waiting on your reviews of this product! :devil:
