D swap.
Old Aug 5, 2022
Jolson581's Avatar
Jolson581 is an unknown quantity at this point
D swap.
My question is can you swap a D17a2 for a D16y7?
Old Aug 5, 2022
Re: D swap.
depending on local laws, you get in trouble with emissions by putting and engine older than the car
Also, you will need to figure out how to match an distributor engine. ECU might not be compatible with all the pother sensors around the car too
Will you need to change SRS modules also?
etc, etc
Old Aug 5, 2022
Colin42's Avatar
Re: D swap.
Not without a ton of work. Plus most likely illegal in your area. Plus it would be a step backwards in terms of power and technology. Either put in another d17a2 or kswap it.
Old Aug 31, 2022
crajnai's Avatar
7th Gen Victim
crajnai has a spectacular aura aboutcrajnai has a spectacular aura about
Re: D swap.
I’m jumping in on this thread. I looked at some of the ancient stickies on k swaps into 2001-2004 civics. Has there been any additional parts or advice out out there?
If my 2003 EX has a cracked block I would consider it. Can it be done at home or will it be too much?
Old Aug 31, 2022
Colin42's Avatar
Re: D swap.
This thread is stickied:
https://www.civicforums.com/forums/7...swap-auto.html
Basically bolt in besides drilling out some spot welds and welding in a bracket
Old Aug 31, 2022
crajnai's Avatar
7th Gen Victim
Re: D swap.
Hey Colin thanx. That sticky make it look much more complex. Engine direction is different. How do we align those welds properly for the mounts. And is the harness the same?
Old Aug 31, 2022
Colin42's Avatar
Re: D swap.
All explained in the thread...
Old Aug 31, 2022
Re: D swap.
for K-series engines? Thread was about D to D series...
estimate some 3-5k to do swap.
Old Aug 31, 2022
crajnai's Avatar
7th Gen Victim
Re: D swap.
Mea culpa I was thinking g k swap.
$5k??! F that noise, I drop in a d7a JDM before I spend that.
Old Sep 3, 2022
Re: D swap.
that price tag was back in the day. Not sure if that price tag is the same these days.
Also, Hasport makes a k-swap mount kit for like $600 https://hasportperformance.com/product/esk3/
IfollowUdie
Jul 24, 2021 12:19 AM
Dhimbu
Aug 18, 2020 01:31 PM
cvc2f2f
Engine Swaps
Jul 5, 2004 04:08 PM
nookiemonster
May 20, 2004 01:24 AM
