ES2 k20a3 swap ... and it auto
Old Jul 11, 2017
babbshonda's Avatar
babbshonda has a spectacular aura aboutbabbshonda has a spectacular aura about
Hey guys! My name is Phillip and I own a 2005 Honda Civic Special Edition sedan. I recently decided to do a k20 swap on it in order to have a little more power while merging on the interstate and such...yes I am leaving it automatic, why you ask? Well I drive about 40 min each way to work and frankly I want to be lazy. I previously had a 2003 sedan with a manual transmission and sold it when I bought this 2005. This is not a racecar build and I don't plan to do any additional "performance" modifications.
I found a 2003 Acura RSX with minimal body damage but running and driving with no mechanical issues for $1500.
I got the swap pulled out of the RSX
Old Jul 11, 2017
babbshonda's Avatar
Re: ES2 k20a3 swap ... and it auto
Then I got started on removing the D17A2
Old Jul 11, 2017
babbshonda's Avatar
Then I got started on the mounts. I drilled out the spot welds on factory civic driver side engine mount and got it out of the way.
I welded in the transmission mount on the driver side from the RSX
I know the paint doesn't match but it will be mostly covered and I already had this blue paint on hand.
Transmission mount installed and ABS bracket modified and mounted.
Old Jul 11, 2017
babbshonda's Avatar
On to the passenger side ... Removed the factory transmission mount from the civic, again by drilling out the spot welds.
Test fitting the RSX passenger engine mount.
The RSX passenger engine mount welded in and primed!
Again, I know the paint doesn't match but it will be mostly covered.
Old Jul 11, 2017
babbshonda's Avatar
Then I got started on installing the a/c lines and power steering lines. The power steering lines are from the RSX, A/C lines came off of an EP3 Civic
RSX power steering cooler installed.
The engine mount installed on the passenger side.
A/C Lines routed along the driver side
Then I finally pulled the Civic subframe
Old Jul 11, 2017
babbshonda's Avatar
Got the engine bolted in an most everything hooked up. I ran into a couple issues though. While researching the swap, Many people stated that you needed EP3 A/C Suction Hose and that the RSX hoses wouldn't work. The EP3 suction hose WILL NOT clear cruise control or power steering. I elected to try the RSX A/C Suction Hose and it worked with very minor tweaking. I used the EP3 Discharge hose to go from the A/C Compressor to the original condenser.
I moved on to installing the power steering reservoir, I read in many places that you need a eg bracket .... yada, yada, yada.... I used the original d17 bracket, I used a self tapping screw and bolted it to the body part of the engine mount. It works perfect. Also I'm using the original hoses and reservoir from the RSX.
Old Jul 11, 2017
babbshonda's Avatar
While the car was apart, I decided to go ahead and swap over the 5 lug and rear disc brakes.
While installing the front 5 lug, I noticed the Civic had larger calipers than the RSX. The rotors are the same size. I used the Civic caliper and bracket on the RSX spindle so I now have 5 lug with my original calipers.
5 Lug Complete!
Old Jul 11, 2017
babbshonda's Avatar
Got the skeleton of the hood notched to clear the power steering!
The hood will now close without issue!
Old Jul 11, 2017
babbshonda's Avatar
I got the RSX shifter installed. Unfortunately, it's a little too tall. It will work until I have a chance to go check out some other shifter assemblies at the junkyard. Also wired in the sport shifter.
I'm using the EP3 radiator. Since EP3 never came in auto, the radiator's were not offered with the transmission coolers. I purchased an aftermarket transmission cooler and installed it.
Got the throttle cable and battery installed. Extended the wiring from the fuse box over to the battery. Extended the rsx exhaust 2.25 inches and it bolted right up as well. I took it up to my buddy's shop on 7/5/17 and he programmed the key for me. After programming the key, it started right up!!!!!
Old Jul 11, 2017
babbshonda's Avatar
Got the slim fans in, wired in the fan switch and installed the radiator.
Kinda aggravated that I had to trim the bumper to clear the top of the radiator. Oh well life goes on.
And its done!
It runs perfect and code free!!!
Old Jul 14, 2017
SammySC's Avatar
SammySC has a spectacular aura aboutSammySC has a spectacular aura about
Looks like a good project. Why didn't you fix the RSX instead? Just curious...
Old Jul 14, 2017
Looks great!
Just a word from my experience with slim fans. Depending on where you're located, those through-radiator fan mounts don't last long. It might have been more of an issue for me since I have to deal with Vegas heat, but mine didn't last long at all. Maybe 6 months. I ended up taking my old fan shrouds, trimming them down, and fabbing up a way to mount them like that using aluminum flat bar stock from home depot. I also wanted it that way so I had a way to mount the coolant overflow tank. I'm not sure how much of an issue that'll be with a k swap, but just some food for thought.
Old Jul 14, 2017
Looks great! How does it drive?
Old Jul 15, 2017
babbshonda's Avatar
I purchased the RSX just for this project. Parting out the remainder of the RSX.
Old Jul 15, 2017
babbshonda's Avatar
Looks great!
I'm in Alabama. It gets pretty hot here but I've never had an issue with them in past experiences. I'll keep an eye on them though.
Old Jul 15, 2017
babbshonda's Avatar
It drives great. Everything functions as it did from the factory. I've put about 500 miles on it already.
Old Jul 17, 2017
SammySC's Avatar
I see. It looks good, congratulations!
Old Jul 20, 2017
thornygravy's Avatar
Car Audio Inc
thornygravy is an unknown quantity at this point
beautiful job!
Old Jul 20, 2017
mac25's Avatar
Dr Krieger of Modification
Clean work man!
Old Jul 21, 2017
Sakib Kamal's Avatar
Sakib Kamal is an unknown quantity at this point
Very nice and clean swap! Well done!
Old Jul 28, 2017
bravo79's Avatar
bravo79 is an unknown quantity at this point
Do you mind posting a video of it? Something like 0 to 60. Just wondering how it pulls.
Old Jul 29, 2017
babbshonda's Avatar
I'll try to make one and post it. It's not fast by any means.
Old Sep 8, 2017
babbshonda's Avatar
I finally got around to installing a TL shifter assembly. I think I'm going to redo my adapter brackets for it and slide it forward some. After that, I can redo the piece around it to do away with the gap.
Old Sep 9, 2017
SammySC's Avatar
Originally Posted by babbshonda
[IMG]https://cimg1.ibsrv.net/gimg/honda-tech.com-vbulletin/540x960/80-shifter_b90ed0d814b5c8f7c00e97c1e4c60b88dc413d39.j pg[/IMG
Looks nice, Good job please post a pic once you finish off the gap!
Old Sep 22, 2017
Anonymous7o2's Avatar
Anonymous7o2 is an unknown quantity at this point
Any Updates ?? how it running, driving, and interior complete?
Old Sep 22, 2017
babbshonda's Avatar
It runs and drives like it came factory with this drivetrain. I'm probably going to get some bigger slim fans. These are 10" and I'm probably going with a 12" next. I don't have any problems with overheating, the a/c just isn't as cool as I want while stopped.
Interior has been complete minus the console trim since July when I did the swap. Currently it is still like the last picture I posted with the gap around the TL shifter assembly.
Old Nov 1, 2017
babbshonda's Avatar
So far I've put about 8k miles on the car since I completed the swap. Only issue I've had up to now is a leaking power steering pump which I replaced last week.
Old Nov 1, 2017
nice work! good job!
and the solutions you found along the way makes this even better!
good research and critical thinking!
Old Jan 10, 2018
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
Isn't this the same thing that you posted on Honda-Tech? Anyways, great job on the swap!
Old Apr 25, 2019
Colin42's Avatar
stickied because this is one of the best swap write-ups i've seen and i keep referring people to it
