Short Throw Shifter Adaptor
Old Sep 21, 2018
piano55man's Avatar
piano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of light
Since i'm a cheap azz, i decided to build me a short throw adapter plate.
It boils down to 4 holes being drilled into a piece of steel and one hole being drilled next to the existing shifter pin.
Double nutting everything.
Attached within the pics are the measurements used.
My original shifter throw was over 4 inches. This plate lowers the throw to 2.75 inches!
Final plate. The angled cut is necessary to clear the shifter boot cover. Bottom two holes for mounting. I drilled two holes to try different throw angles. Utilizing the top hole brings the throw down to 2.75 inches.
Throw length.
Old Sep 21, 2018
GolNat's Avatar
Prelude Owner
Re: Short Throw Shifter Adaptor
Sweet! Practical and a lot cheaper then then buying one. I wanted to do something similar to my Fit. Are you going to cut the stick down also to shorten that?
Old Sep 21, 2018
piano55man's Avatar
no, i have a hurst shifter handle...it's low enough!
Old Sep 24, 2018
piano55man's Avatar
Adapter plate worked great at the track!
Honda2k4
Nov 10, 2004 01:52 PM
specter542
16
Aug 23, 2004 09:09 AM
slammed2k2
Jun 4, 2003 12:45 PM
jkim1978
Nov 26, 2002 04:06 AM
Slow2k1Civic
Jul 24, 2002 12:59 PM
