1.7 to 3.2 swap? Can I?
Old Apr 13, 2018
Ogtuner's Avatar
Ogtuner is an unknown quantity at this point
Can this be done without major changes to subframe? I find the 1.7 rather challenged in the performance Dept. and would love to have a sleeper Civic.
Old Apr 13, 2018
Colin42's Avatar
Re: 1.7 to 3.2 swap? Can I?
would probably require a custom subframe.
K is alot easier
Old Apr 13, 2018
BrotatoChip's Avatar
Super Moderator
K swap is much much easier. As far as I know you cannot find mounts to accommodate a J series engine so everything would have to be custom made, and wiring would also be a mess. You would almost certainly not be able to fit it under the hood without cutting a good sized hole or removing it completely.
Is it possible? Absolutely.
Will it cost a small fortune? Absolutely.
Old Apr 13, 2018
Ogtuner's Avatar
Ok, that answers that question. Thanks.
Old Apr 13, 2018
i think they make mounts for the older generations, but it will either have the oil pan too low or a lifted hood.
first hit in google (searching is easy )
http://www.superstreetonline.com/how...s-engine-swap/
http://www.enginebasics.com/Civic%20Type%20RL.html
quietriot732
Jul 20, 2014 09:51 PM
spoonEM
Jan 30, 2008 03:44 PM
nookiemonster
May 20, 2004 01:24 AM
DC
Sep 16, 2002 05:25 PM
TehBandicoot
Jun 18, 2002 12:52 AM
