Dezod Turbo kit...
Old Dec 18, 2008
  #31
d17civickid's Avatar
d17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of light
Re: Dezod Turbo kit...
just bought from dezod the pcs xfc with pressure sensor... put a nice hole in my wallet.. lol
Old Dec 18, 2008
  #32
speedfoos's Avatar
Should have let me know since I don't track stuff on this forum very closely anymore.
Old Dec 19, 2008
  #33
dezod's Avatar
7thgen Power Maker
Thank you for the support.
Old Jan 1, 2009
  #34
ok so i tried to install deatsch werks injectors today and i couldnt get the fuel rail to bolt up again to the 2 studs tha hold it in place.. they are the same size as the rsx-s... ( when i hold them next to each other the o rings line up)... i tried to modify the fuel rail and that didnt work either... any suggestions?? or can someone post a link to a diy.. i looked for one but couldnt find a diy. do i need an aftermarket fuel rail?
Old Jan 2, 2009
  #35
speedfoos's Avatar
There is no DIY for installing injectors. The o-rings are probably just tight. Either use a little liquid soap on the o-rings or some good old fashioned spit to lube them up so they will seat properly. If they are the same length as the RSX-S, then they will fit.
Old Jan 2, 2009
  #36
I lubed them up before i put them in... they were all the way in.. as far as they could go in...
Old Jan 2, 2009
  #37
speedfoos's Avatar
Pics would help.
Old Jan 2, 2009
  #38
i didnt take any pics when i was doing it.. im running stock ones right now... heres a pic of rsx-s and deatsch werks next to each other... rsx is in black... come to think of it is there a sticker on the fuel rail from another brand other than honda???
Old Jan 2, 2009
  #39
speedfoos's Avatar
Those are the exact same as the SRT-4 bodies which I'm running. There is no reason they would not fit aside from not being seating properly in either the rail, the injector plate, or both.
Old Jan 4, 2009
  #40
does the stock fuel rail have a sticker that says ipt? or something like that?
Old Jan 4, 2009
  #41
speedfoos's Avatar
Yes.
Old Jan 4, 2009
  #42
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
the rail sits a little higher with the rsx-s injector's than the stock injectors. I had to just get longer bolts for the fuel rail
Old Jan 4, 2009
  #43
Ok.. for a sec i thought i was the only one with this problem.. lol
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
justcruzin125
Aug 11, 2015 09:09 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
