Powersteering Cooler
Old Mar 19, 2008
Civicman1988's Avatar
Anyone know where to get one? Just installed one on my buddies 350z and you cna see the difference. Its not a big difference but i still would like to do one any help would be appericated.
Old Mar 19, 2008
tfnaaf's Avatar
BLDNPSI Mod
Re: Powersteering Cooler
lots of cars use them stock. I know off hand dodge caravan uses one in late 90's+ just saw one today on a car i was working on. Im sure it could be adapted to work on a civic
Old Mar 20, 2008
i know it can just need help with which one.
Old Mar 20, 2008
speedfoos's Avatar
Honestly Phil, it's the same concept as adding anything inline of the PS system. Find a tranny cooler at the pick 'n pull, tap into the line that feeds the rack from the pump and run the cooler in-line of that. It would just a matter of finding a place to mount the cooler. IDK, that's what I would do if I were fabbing it up.
Old Mar 23, 2008
lemac's Avatar
lemac will become famous soon enough
speedfoos correct. Just finding a place to mount and making sure you have a leak free connection, I would recommend using high pressure fittings or barbed fitting will do.
Old Mar 23, 2008
lemac's Avatar
just noticed you asked where to get one. lol sorry I'm sure a tranny cooler would yeild the same if not more sufficient cooling.
Old Mar 23, 2008
what effect does cooling the ps fluid have?
Old Mar 23, 2008
Boilermaker1's Avatar
Jap-Euro Fusion
You need 2500 PSI lines for the pressurized PS lines. Its more than just a barbed fitting. Russell makes lines, but you're better off going and having crimped hydraulic lines made.
Old Mar 23, 2008
robbclark1's Avatar
Retired suspension supermod.
it cools it
Depending on the tires and the abuse, the PS fluid will bubble and froth up. My friend was able to do it after two autox runs.
Old Mar 26, 2008
HondaLuver's Avatar
Its a celebration bitches!
my eps runs really cool
Old Mar 26, 2008
drunkenmagnum's Avatar
waste of cash and you run the risk of leaks.
save your money for a caravan since they come OEM with them.
but here is one on ebay that you might want to try since it is a honda peice
http://cgi.ebay.com/ebaymotors/OEM-H...spagenameZWDVW
or a smaller 1
http://cgi.ebay.com/ebaymotors/C6AA-...spagenameZWDVW
Old Mar 26, 2008
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
Unless you race or tow alot you have absolutely no need for one!
carid
Nov 7, 2015 01:46 AM
Whitexj
Sep 30, 2015 02:04 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
adamdrives
15
Aug 8, 2015 08:53 PM
ELTsanwich
Sep 10, 2002 09:38 PM
