Quaife LSD Update
Old Mar 21, 2008
  #31
Rufus's Avatar
Re: Quaife LSD Update
Originally Posted by LatinEM2
How much are these LSD's???
I think they're all $895
Old Mar 21, 2008
  #32
Valdeezy's Avatar
Valdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to all
Roll me a fatty when U get a chance Andy. Great Job on all of this!!
Old Mar 21, 2008
  #33
speedfoos's Avatar
He can't. He's in the Army and has to pee in a cup. Unless he's in to "large" women.
Old Mar 21, 2008
  #34
robbclark1's Avatar
Retired suspension supermod.
I would call Andy's g/f the antithesis of "large". I think you are just projecting your love for "large" women onto Andy.
Old Mar 21, 2008
  #35
andyman97's Avatar
Turbo Guru
Haha, you wish. All but the one for the fit...
Try closer to 1200.
Old Mar 21, 2008
  #36
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
I'll take a beer. Thanks.
i second that, and as for price, i've seen em listed for 1195....
edit: nvm, andy beat me to it...
speaking of andy, when you gonna lay down some dual stripes with the vic and post pics
Old Mar 21, 2008
  #37
Rufus's Avatar
^^ amen
Old Mar 21, 2008
  #38
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
This is a funny thread. That's awesome that the LSD fits in nicely. I can only imagine what it'll do for road course/auto cross events.
Old Mar 21, 2008
  #39
andyman97's Avatar
Turbo Guru
Well, I'm still breaking everything in. Having some minor issues I need to fix. I'm getting the most annoying rattle at 3k from the right rear (something with the disc conversion), the front right brake squeaks a little, the speedo is bouncing all over the place (prolly a bad vss from the new tranny since it sat for who knows how long) and I'm breaking in the clutch so I don't glaze it over. And I'm not exactly "tuned" for the injectors I'm running. All good things come in time
Old Mar 22, 2008
  #40
filipinop1405's Avatar
filipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of light
sounds good andy!!
Old Apr 15, 2008
  #41
04civic07's Avatar
Living Life Turn After Turn
04civic07 will become famous soon enough04civic07 will become famous soon enough
any update?
Old Apr 15, 2008
  #42
Rufus's Avatar
Can I use the OBX version on eGay? It's 1/3 of the price!
Old Apr 15, 2008
  #43
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
you should be able as long as it is the one for the fit but it won't be as nice as a torque biasing diff
Old Apr 16, 2008
  #44
andyman97's Avatar
Turbo Guru
Don't buy obx unless you want problems. Get the real thing and save yourself the headache. And I happened to be searching around and found them for around 900 on honda-tech, so you can pick them up for cheaper than 1200 now the price has come down some.
Old Jan 11, 2009
  #45
gmcuajo's Avatar
gmcuajo can only hope to improve
Originally Posted by andyman97
Confirmed. The quaife made for the fit works with a d17 tranny using fit ring gear bolts.
I haven't gotten on it or anything but I ran for initial 15 minute break in with new motor and tranny and had no issues. It goes into gear and everything seems perfectly fine.
For those who've been waiting on me to see if it works, you now have your answer.
Stupid question but, the FIT speedometer gear is also needed???
Old Jan 11, 2009
  #46
gmcuajo's Avatar
And what bearings?
Old Jan 13, 2009
  #47
bomerman19's Avatar
And what bearings?
You use the bearings that are already in the original transmission you just press them off the old diff and onto the new diff you can use the speedo gear off the d17 diff but it has to be pulled off with a bearing spiltter and then pressed onto the new diff It's not hard if you have the right tools or a machine shop I do recommend the honda fit speedo gear cause it gives a little more support around the bearing so that the center race does not flex that much.
Old Jan 13, 2009
  #48
gmcuajo's Avatar
The speedometer gear of the d17 is removeable? I open my tranny and saw it made of cast metal, I think it was built-in the differential...
Old Jan 14, 2009
  #49
bomerman19's Avatar
No it's removable I have pulled it off before it's pressed on from the factory and looks like it is cast on but its not. It's not too hard to pull off you just have to be careful about it cause it is a thin piece of metal. I used a bearing splitter to get underneath on the sides and pop it up a bit and then used a gear puller on it to pull it off. Grab a big nut (I think I used the rear lower control arm nut to chasis. or the nut off the front strut to the knuckle) and drop it into the hole were the axle goes so you have something for the gear puller to push off of. Or if you have a big enough slide hammer use that. I think I have like 3 of those speedometer gear rings laying around back home off the diff's.
UltraHDGames
Jun 8, 2016 05:16 PM
Dave Brabant
20
Oct 6, 2015 12:44 AM
beanhead
Sep 24, 2015 12:04 PM
Jrosa
Sep 14, 2015 08:24 PM
KamikazeKunze
Aug 30, 2015 10:38 AM
