Hondata for d17a2 manual
Old Dec 6, 2007
silver surfer's Avatar
silver surfer is an unknown quantity at this point
Talking Hondata for d17a2 manual
I know that they have the Hondata with cam gear for d17 out now....does anyone know what you get on the dyno with it?Was thinking of trying to pick one up for my civic but I would like to see numbers first...thanks
Old Dec 6, 2007
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Re: Hondata for d17a2 manual
its a stand alone engine managment system yo...
its ment to tune your mods IE turbo...
on a stock engine i dought youd make much extra power
Old Dec 6, 2007
ronaldo9's Avatar
It's a waste of $1200 w/o serious modifications whether that be N/A or turbo. I remember a long time ago Andyman said he made like 130whp with just AEM EMS and a stock motor before he went turbo. I imagine that kpro would yield similar numbers.
Old Dec 6, 2007
Rufus's Avatar
I'm buying one for my turbo setup
Old Dec 6, 2007
ronaldo9's Avatar
+1 That would be worth it.
Old Dec 6, 2007
thanks for the info...it would be better or worse then AEM ems standalone ?? costs less to i think?
Old Dec 6, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Hondata is going to be better because its not universal, its derived from honda software. This is utterly useless without boost or a major build up. Most people see 10-15 hp on a boosted setup with just the addition of a standalone, because of the added control over the system.
No one is going to have one of these on a stock motor. There's no point.
Old Dec 6, 2007
Spikez1222's Avatar
Spikez1222 is an unknown quantity at this point
Wow, that's some info I needed to know!
Old Dec 6, 2007
Civicman1988's Avatar
I plan on getting one to with my set up
Old Dec 6, 2007
if you have a stock motor, the apexi controlers are really all you need to adjust the fuel curves.
Old Dec 6, 2007
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
I just got a K-pro and stuck it on. the motor right the moment it is basically a stock setup headers, cat back exhaust, & cold air intake. you do pick up a little more power, the power band is better, and you can control everything on your car. which is sweet. I have noticed that the car is quicker and so have a couple of my friends.
But if that is all you are going to run it is worthless.
The reason I have it is cause I have a stage two cam waiting to go in when it gets a little warmer and I pick up valve springs. and the possibility of internals later on in the year.
If you are going turbo or your dive deep into N/A(putting cams and messing with valve train) I say get it but other wise it is not going to net you enough gains for the price tag
at most I may have picked up 20hp but I doubt it. It is more likely 10 to 15
Old Dec 6, 2007
nice info thx again..really informative
Old Dec 12, 2007
overrev_it's Avatar
overrev_it is an unknown quantity at this point
You can find alot of info concerning the Hondata VS EMS issue...
I myself would take the EMS, probebley because i'll be controlling E-VTEC instead of I-Vtec which i'll need a K-Pro for, probebley to control VTC, i'll take the EMS anytime for the D
Old Dec 12, 2007
Mr_Plenty's Avatar
Mr_Plenty is a jewel in the roughMr_Plenty is a jewel in the roughMr_Plenty is a jewel in the rough
I-vtec > E-vtec
Old Dec 12, 2007
Mr_Plenty's Avatar
give me props for me informative post too silver surfer haha^^^^^^^^
Old Dec 12, 2007
spoonEM's Avatar
omgwtfbbq mod.
Talk to Oscar (djmota) and look at his numbers. He has a built top end and Hondata and was tuned by Church Automotive. Its a nice setup.
Old Dec 13, 2007
andyman97's Avatar
Turbo Guru
Hondata did a tune on a stock d17 for the map that's provided with the software. They went from a stock of about 93-ish to about 125-ish at the wheels if memory serves me.
There's no difference between controlling i-vtec and vtec-e. You're opening a solenoid which allows oil pressure to flow into certiain spots, activating alternate cam lobes. That's it. If you can connect that circuit, the solenoid opens and your vtec works.
BootyDo
Jun 21, 2016 03:45 PM
horta1212
Aug 22, 2015 08:31 PM
mac25
Aug 21, 2015 11:14 PM
JetsterDajet
Aug 16, 2015 01:56 PM
hunda91
Aug 12, 2015 03:04 PM
