Results are in on page 10 @ 17 PSI now with vid!
Old Oct 21, 2007
  #151
spoonEM's Avatar
omgwtfbbq mod.
Re: Results are in on page 10 @ 17 PSI
haha...that burnout was alllright. haha
Old Oct 21, 2007
  #152
spoonEM's Avatar
omgwtfbbq mod.
here it is:
http://www.youtube.com/watch?v=gyPT9kRARPI
Old Oct 21, 2007
  #153
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
awesome thanks man!
Old Oct 21, 2007
  #154
dopes6070's Avatar
Re: Results are in on page 10 @ 17 PSI now with vid!
hey rob if you want to fix the description my car is an 2001 not 03 lol.
Old Oct 21, 2007
  #155
spoonEM's Avatar
omgwtfbbq mod.
oh yeah....i knew that too...lol.
Old Oct 21, 2007
  #156
HonCiv02's Avatar
HonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond repute
nice vid and awesome numbers. congrats man.
Old Oct 22, 2007
  #157
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
whats the smoke?
Old Oct 22, 2007
  #158
speedfoos's Avatar
Best thing about this place is the Youtube tags!
[youtube]http://www.youtube.com/watch?v=gyPT9kRARPI[/youtube]
Old Oct 22, 2007
  #159
Matteo's Avatar
Matteo will become famous soon enough
nice...video some pulls!! get that thing on the highway with that camera lol
Old Oct 22, 2007
  #160
dopes6070's Avatar
it wasnt smoke its oil vapor from the valve cover breather
Old Oct 22, 2007
  #161
drunkenmagnum's Avatar
wow! great work. makes me want to turn the boost back up on mine!
Old Oct 22, 2007
  #162
dopes6070's Avatar
Ya the higher pressure definatly makes a huge difference. This thing has insane ammounts of torque now.
Old Oct 22, 2007
  #163
ronaldo9's Avatar
Great numbers man. Very impressive for a stock cam. I think you'd easily break 300 with a stage 2 or stage 3. In addition, can we say the stock intake mani can handle the boost?
Old Oct 22, 2007
  #164
dopes6070's Avatar
Well so far so good with the stock manifold. I don’t know if it will last long but we will see. Im sure ill get in the 300s with just a new fuel pump and a bit colder spark plugs. I would really like to get the dezod pnp job done. But I cant spend the $$ rite now.
Old Oct 22, 2007
  #165
filipinop1405's Avatar
filipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of light
Great job! Keep it up!
Old Oct 22, 2007
  #166
dezod's Avatar
7thgen Power Maker
Nice numbers for sure. Not to mention for the stock FP, IM & 91 octane.
Now it's time for a race mani!
Old Oct 22, 2007
  #167
dopes6070's Avatar
well it wasnt quite "pump" gas we had to add a bit of race gas because shawn thinks I got bad gas from the chevron station I usually go to. We couldn’t even run 11 PSI without it detonating which was really strange because we did 13 with no problems before. but I should be able to run ~14 psi daily no problem.
Old Oct 22, 2007
  #168
spoonEM's Avatar
omgwtfbbq mod.
I think it was running about ~98 octane is what he figured after he added in the 115 octane. Just think, once you get the new fuel pump in and get those colder spark plugs, youll definitely break 300, and then once you do the pnp, who knows. I told you it wasnt a good idea to sell it. lol.
Old Oct 22, 2007
  #169
andyman97's Avatar
Turbo Guru
I very seriously doubt that if you're using a stock cam. You may want to consider a cam before porting and polishing. It doesn't matter how much more air you can fit in the ports if you can't get it past the valves.
Old Oct 22, 2007
  #170
andyman97's Avatar
Turbo Guru
Originally Posted by greeen01civic4d
thats AWESOME!!! good to know it only takes 17 psi to make 300 hp
This was 18 psi with a stock cam. Before that, I couldn't break 265 whp at all with stock cam. from an 18 to 21 psi jump, I still couldn't get above 270. Then with a stage III cam install alone, I got the following results at 18 psi. It isn't like this is uncharted territory....
Also, keep in mind that Church uses a dynapack. Your numbers are going to be higher on a dynapack than a dynojet. Nevertheless, good job. Breaking 250 on a d17 isn't an easy feat.
Old Oct 22, 2007
  #171
dopes6070's Avatar
so that is just from the stg 3 cam? no head work? If so those are pretty good results. My main concern about going with a cam like that is idle and drivability since this car is my daily driver. I don't want it to have to idle much higher then stock. Also it seems like you lost a lot of low end. I made 140 tq at 3000 RPMs and 265 @ 5k. Mine just tapers off fast after 5k and yours holds the torque longer. Thanks for the advice ooh and also do you have a custom intake mani?
Old Oct 22, 2007
  #172
7thgen.nick's Avatar
7thgen.nick has a spectacular aura about7thgen.nick has a spectacular aura about
nice job, congrats. cantwait to get mine running again
Old Oct 23, 2007
  #173
dezod's Avatar
7thgen Power Maker
Don't forget he has our race manifold, which makes a huge difference on how the power is delivered.
Old Oct 23, 2007
  #174
dopes6070's Avatar
Well with the PNP job, 1mm O/S valves and the stock or maybe a stg 1 cam could I expect to keep most of my low end? My car already feels like you are filpping a light switch once it hits boost. Haha
Old Oct 23, 2007
  #175
andyman97's Avatar
Turbo Guru
There are alot of things to take into account. I was just trying to make the point that without a cam, I very seriously doubt you'll see 300+ whp. I think you're pretty much at your power ceiling with the stock cam, regardless of headwork, your lift will remain the same even if your ports can flow more air, they have no means to get by the valves.
As far as power difference at X rpm goes, attribute that to the turbo and exhaust. I'm running a t3/t4e 57 trim, whereas you're probably running a smaller turbo and I have an open 2.5 downpipe with no exhaust restriction at all. This allows me to keep the power numbers climbing all the way to redline. I would imagine your exhuast is pretty restrictive, which is probably what's having an effect on your power dropping off in the higher rpms.
When it comes to idle, I have no issues. Yes, I'm idling higher than stock, about 1k, but it isn't bad and its very consistant. I can tell you from experience, I could never get a perfect idle with the AEM and that was with 2 of the best tuners in all of Texas tuning it. When I swapped the kpro in, the idle issues dissappeared. Now that's not to say the AEM can't idle the engine with this cam, but there are way more paramaters and its very difficult to get any kind of consistancy with the idle.
Old Oct 23, 2007
  #176
andyman97's Avatar
Turbo Guru
Yeah, but remember when I retuned that one time and ran out of fuel? I had your manifold on and still couldn't break 260 at 18 psi. There's no doubt that the manifold was a contributing factor to the jump, but technically, the only thing I changed was the cam to see that power jump. I don't think realistically that with a stock im, inferior turbo manifold, weak exhaust setup and stage III cam that anyone would be likely to hit the same power numbers.
And yeah, I have an aftermarket, one-off intake.
I wouldn't suggest a stage one cam. I say go all out if you want big numbers. The better the engine can breathe, the more power you'll make. You won't loose low end, as I said, that has more to do with the turbo.
Old Oct 23, 2007
  #177
dopes6070's Avatar
I have a 3" exhaust all the way back with a straight through magnaflow muffler. There is no restriction at all vs an open dp. Im gonna have to think about maybe going with an a2 head the the cam then.
Old Oct 23, 2007
  #178
spoonEM's Avatar
omgwtfbbq mod.
I say lets throw in the fuel pump and see what we can do. I seriously think you can hit that 300 mark with the stock head. Sure, its not the strongest setup or even the best, but I think you can do it. Even Shawn said once you throw in that fuel pump you should be able to hit it.
Old Oct 23, 2007
  #179
dopes6070's Avatar
ya he did. Ive seen d16 guys hit over 300whp with the stock head also. I cant see why the d17 head would flow worse. Im going to take care of the intake mani one way or another b4 the fuel pump.
Old Oct 23, 2007
  #180
andyman97's Avatar
Turbo Guru
You would have to compare the lobes between the a1 and a2 cam. If the lobes on the a2 cam are lower lift/shorter duration then its possible, maybe. If they're the same or smaller, no way, won't happen. But go for it and try anyways, I'd like to see the outcome.
And for a 3" exhaust, trust me, you have much more restriction with that than an open downpipe. Adding 1 bend and extending a pipe 2 feet will cause more restriction that without it.
