Wideband Sensors Explained
Old Jul 16, 2007
andyman97's Avatar
Turbo Guru
dddd
Old Jul 16, 2007
metalviper's Avatar
metalviper is just really nicemetalviper is just really nicemetalviper is just really nicemetalviper is just really nice
Re: Wideband Sensors Explained
wow a lot of info ive been wondering about!
any other info on tuning? like closed loop, map sensors, etc... all stuff ive seen but never understood.
+rep!
Old Jul 16, 2007
andyman97's Avatar
Turbo Guru
Sorry, with tuning, its way too broad a topic to try and explain in a post. There are manuals that are very long and don't cover it all.
Old Jul 16, 2007
DsevenEm2's Avatar
This is Myspace
oman thanks alot! i requested something liek this in another thread or forum or something. cool this explains alot.. +1 for u guru..
Old Jul 16, 2007
metalviper's Avatar
I guess i meant if u could post a glossary style list of terms and other stuff u see as important in tuning for noobs (like me )
like so, i had no clue wat a wideband sensor was!
Originally Posted by andyman97
What is a wideband sensor?
A wideband sensor, unlike a narrowband sensor, uses a larger voltage scale to read your air/fuel ratio (AFR).
Old Jul 16, 2007
burke420's Avatar
The World Is Yours!
nice info, im glad it;s more detailed to me, great advice for me!
Old Jul 16, 2007
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
What does it take to put in a wideband?
Installation varies on model, but typically, you connect a positive 12V ignition source for power and a ground. There are two outputs, one for a wideband signal, another for a narrowband signal. These connect to the ecu or piggyback computer that you're using for datalogging, monitoring, etc.
Does this mean UEGO w/b sensor can work simultaniously as a w/b and n/b?
Old Jul 17, 2007
speedfoos's Avatar
Fantastic stuff Andy! Rep for you. My wideband arrived yesterday safe and sound!
Old Jul 17, 2007
andyman97's Avatar
Turbo Guru
Stock ECU, yes. This is why they have narrowband outputs. You replace your signal wire at the ecu and run the wideband in place of the stock narrowband with resistors and wire the narrowband signal wire back into the ecu while maintaining a display and using the wideband output for datalogging, etc.
Old Jul 17, 2007
andyman97's Avatar
Turbo Guru
Great man, glad you got it. That was damned fast!
Old Jul 17, 2007
Doeas this mean you can substitute n/b o2 sensor with w/b one and have it for w/b and n/b duties?
Old Jul 17, 2007
dezod's Avatar
7thgen Power Maker
Some of the gauges can be substituted for NB O2 sensors. Each manufacturer is different and if I recall, PLX can.
Old Jul 17, 2007
andyman97's Avatar
Turbo Guru
Correct, PLX widebands do have narrowband and wideband outputs, as I believe Innovate does, as well. Not sure about AEM.
Old Jul 17, 2007
DsevenEm2's Avatar
This is Myspace
i guess i might as well ask here while its open but...whats a UEGO...
Old Jul 17, 2007
dezod's Avatar
7thgen Power Maker
Universal Exhaust Gas Oxygen Sensor.
Old Jul 17, 2007
ronaldo9's Avatar
That is a gauge type wideband aem uego.
Old Jul 17, 2007
tfnaaf's Avatar
BLDNPSI Mod
The PLX can substitue the NB sensor but it was much easier for me to just weld in a 3rd bung and not worry about it
Old Jul 17, 2007
andyman97's Avatar
Turbo Guru
I agree. I tried to wire in the narrowband wire and use the wideband in place a long time ago when I was running a stock ecu and I never managed to get rid of the CEL for the primary sensor. Not to say it can't or hasn't been done but its a PITA.
Old Jul 24, 2007
Is this chart specific to 2001+ Civic or for any OBD-II?
Old Jul 25, 2007
andyman97's Avatar
Turbo Guru
No, its the general (generic) voltage operating range of most any narrowband sensor.
Old Jul 25, 2007
Does anyone have the o2 voltage operating band for the 7th gen?
...Also, on additional note... anytime when I have ignition on my AM radio starts to interfere, it was OK before I installed my AEM wideband.
Has anything like this happened to you?
BootyDo
Jun 21, 2016 03:45 PM
EdGasket
40
Nov 27, 2015 11:11 AM
viperGTS
Jul 27, 2015 08:38 PM
mistermenphis22
Jul 13, 2015 04:43 PM
fordover
Jul 11, 2015 09:10 PM
