I got a problem with turbo
Old May 24, 2007
Silverstreak04's Avatar
Silverstreak04 is an unknown quantity at this point
I just installed my turbo on my 04 civic... i start up the car and the turbo spins and when i hit the the gas it stops... its stops spining when the oil pressur reachs 50 psi. after i turn the motor and spin the turbo by hand it starts to spin fine...... Do i have to much oil pressure.... Do i need an oil pressure reducer... where can i get one.
Old May 24, 2007
Buds302's Avatar
Buds302 will become famous soon enough
Re: I got a problem with turbo
did you let the motor warm up first? mine doesnt spin all that great until it is warmed up. remember...oil is thicker when its cold. so it might not have gotten to all of the bearings yet....but it might have its just thick and being difficult. let the car warm up completely and then see what happens.... what size turbo?
and as for a reducer....its actually called a restrictor and the best one i seen is function7 ones. you can find them on Ebay. just search Function 7
Old May 25, 2007
tfnaaf's Avatar
BLDNPSI Mod
i know your not gunna believe this but if you stick your fingers in there with the motor running, its gunna chop your fingers off! lol..... seen it on a video someone getting thier hand sucked in!!
Old May 25, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
yeah, you need a restrictor if you value the turbo's seals.
Old May 25, 2007
cleanmagcivic's Avatar
cleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trusted
yeah it happened to the guy who was helping chris rado buld his car i think his last name is norwood
cbalonon
Turbo
15
Dec 1, 2015 03:22 PM
Tommy Cohen
Jun 14, 2015 10:36 PM
Supramk3
Jun 11, 2015 11:13 AM
Supramk3
May 8, 2015 11:16 AM
mikevtec
May 3, 2015 01:36 PM
