My New Turbo Set-Up Thread
Hi guys, Im going to start a thread on my next build up. I have started but I am still waiting on some parts, mostly my turbo which should be here next week. Im trying some different stuff and the thread should turn out pretty nice. I dont have much for pics yet so I'll start off with a couple and update as things progress. Those familiar with me/my car will know that I run an AEM EMS and a custom Crower cam which will be included in my new setup. Other than that, everything else is going to be custom built by myself and Ryan (JDM Fabtech). Right now the car is ripped apart and I am waiting on my flanges to finish the exhaust and intake manifolds. We decided after lots of debate to go with a GT3076R from Presicion. One of our good friends got us a super good deal on it too! Some of my engine specs and such I will keep secret, I wanna keep some tricks up my sleeve haha.
This is the start of a new custom IM. Much like Andy's but I'm experimenting with a new plenum design. It has just a touch more volume and the runners will be just a smidge shorter. Im hoping this will make power up to the almost 8000rpms I'll probably need to make use of the GT30 on the new motor. It doesnt show as much of the actual taper in the pics but it shrinks down towards the end quite nicely.
This is the merge collector for the new exhaust manifold. The wastegate outlet was left long for now. Typically I'd wanna merge these in at less of an angle but I'm trying to stuff everything in there in a certain spot so in this case the shorter merge was neccesary.
I figure this thread will be informative to people that want to see just whats involved in a scratch-built, one-off turbo/engine combo seeing how we always just get bits and pieces here on the forums.
Re: My New Turbo Set-Up Thread
you post this to make us jealous lol....anyway i wish there is someone out there that could make all of us an IM so we can all be happy. Santa said he wont do it cuz his welding shop is broken lol.
Here's some pics of the new lower end. It started off as a brand new Honda block. The gut consists of a Honda crank, Scat rods, and custom SRP pistons/JE rings and ACL race bearings. Before I have people telling me I cant get those for a D17 I will say YES you are correct, but they are in my engine anyways! I'm pretty sure these rods are lighter than the Crower rods and they are much cheaper thats for damn sure! I have yet to have a scat rod fail so I'm not concerned. You'll notice something different in one of the pics. New Honda blocks dont come with engine codes on them, neat fact! Im going to scribe a question mark where the engine code goes just for ***** and giggles.
No not to make ya jealous. If anyone puts as much heart as we do into a project, they can do just as much or more. Its all about determination. Not to mention we're tired of everyone poking fun at the "stupid D17" haha.
Maybe you can save me some work, Did you put a d16 crank in it and use d16 rods and pistons? I'm trying to find a junk d16 to see if it will work or not. seems like it should. I am wanting to try a d16 cranks, tuners toys rods and vitara pistons for a low buck boost *****.
Later
Randy
Later
Randy
It fits. Gotta use D16 oil pump, crank sensor(plugs are different, need rewire), timing cog, and balancer. everything else is a bolt-on. Saves you about $500-1000 if you know how to shop and spec out engine stuff.
Good luck with the build. Keep us updated if you will. I do not have the time or money or knowledge to take on a project like this but always love reading about it.
Oh heres a con for people living in the sticks, you have to ditch the timing covers. Like an *** I run mine open anyways so no loss on my part.
Theres a lot of stuff to realize when you do this though Randy. The d17 combustion chambers are bigger by like 2 or 3ccs so you want like a stock compression D16 piston. It'll still be lower than stock by about .5 The pistons seem to come up higher in the cyl so you so I dont think you'd wanna deck the d17 block. I am actually going to deck my head. I should be running about 9.2:1 or so based on my calculations which is only moderately lower than stock. I was actually going to go higher but I think this will work out just fine. I dont remember the specifics off hand(lots of figuring) but if you get the 2 side by side and grab some free calculation software on the net you can figure it out without a too much trouble
Mmmm, sleeved D17 block. Very nice. So the D16 rotating assembly fit without having to notch the block to clear the rods? I'm still researching the smartest way to build up my bottom - aside from drinking beer and sitting on it. Good stuff, can't wait to see the results.
I dont have one but 300+ is expected for sure. The gt30 should be capable of making more than I probably could even use. Im going to run it on pump gas. Ill crank it up until I am happy with the power/drivability. Im not set on making record numbers just getting to a power level that is optimal for a street/strip car. 350 would probably be enough. We'll see. Im not making any claims yet nothing is even in the car, hehe.
Dropped right in. The D16 has a shorter stroke creating more clearance for the rods if anything. The Scat rods seem to have a little less material on the big end of the rod too so that helps.
Me too, hehe. Here's another pic.
Comp Clutches Stg. 5
4 puck ceramic sprung hub clutch
Haha, you're all giddy now, lol. New parts will do that. Nice to see you going all out with it and making some progress. Did you get those injectors checked out? What was the deal?
I havent yet. I've been busy. Im going to end up with 750s I think. RC gets $25 just to check em out. Ill wait until I get done with my stuff then I'll have em checked out. For now they are good for mock up purposes
Good deal man. I dono about the $25 though. I know that's what they "claim" but when I sent in my 750's, they didn't end up charging me to check them, I used the powers of persuasion, lol.
good to know Andy. Maybe its actually worth it to send em in. I was thinking its going to cost me like 150 to take care of these things between shipping and such. At that rate I'd be better off buying new ones. I still will need 750s though.
I spent about 115 between shipping and cleaning. If you get them working right you should be able to sell them for around 250-300, it'd be worth it.
7thgen Power Maker
Center to center
5.394 for both
BE Bore
1.890 for both
BE Width
D17 .780
D16 .892
PE Bore
.748 both
PE Width
D17 .90
D16 .716
Rep it up!
mmmmm, thats why I switched cranks. I doubt .1 Liter will affect much, only one way to find out, haha.
Well my runners are a little shorter than Andy's in total purely for experimentation. The rest of the specs I dont wanna dish out. If it works out well for me I'd like to keep an edge at least for a little bit, hehe. I have made a bunch of manifolds and spent lots of money trying different stuff and I think I got the F/I manifolds going in the right direction now. Its hard to say exactly whats what though, when everyone is running a different setup.
With a little side-by-side comparison it wasnt that bad to create this beast. D16 aftermarket parts are cheaper for me to get though our connections and just about everyone has d16s laying around for cheap or free for spare parts so I figured I'd give it a whirl.
Well I got the v-band flanges and 409ss mandrel bends for the 3" downpipe I didnt bother to take pics of those. Here are some other goodies.
Intake manifold flanges. I have decided to go with an H22 TB instead and relocate the IAC. The pic shows the total D17 flange set we use.
Now for the fun stuff. Precision GT3076RLE-12. Assembled to my specs. Probably nothing special but it should be good to almost 500 crank HP, not that I will make that much, hehe. Gotta thank Chris and Timmy for the great deal. They are sponsored by Presicion and Chris really came through for me by doing all the legwork to set me straight.
