My New Turbo Set-Up Thread
Old Apr 18, 2007
  #31
electric130's Avatar
Re: My New Turbo Set-Up Thread
Originally Posted by 02fpcivic
Well I got the v-band flanges and 409ss mandrel bends for the 3" downpipe I didnt bother to take pics of those. Here are some other goodies.
Intake manifold flanges. I have decided to go with an H22 TB instead and relocate the IAC. The pic shows the total D17 flange set we use.
http://jdmfabtech.com/gerIMflange.jpg
Now for the fun stuff. Precision GT3076RLE-12. Assembled to my specs. Probably nothing special but it should be good to almost 500 crank HP, not that I will make that much, hehe. Gotta thank Chris and Timmy for the great deal. They are sponsored by Presicion and Chris really came through for me by doing all the legwork to set me straight.
http://jdmfabtech.com/GT30Ger1.jpg
http://jdmfabtech.com/GT30Ger2.jpg
http://jdmfabtech.com/GT30Ger3.jpg
http://jdmfabtech.com/GT30Ger4.jpg
nice, but use the [img] tag to post pics instead of linking them.
Old Apr 18, 2007
  #32
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
EDIT: Fixed
Old Apr 18, 2007
  #33
Boilermaker1's Avatar
Jap-Euro Fusion
Still buildin motors in the Kitchen I see.....
So which is worse, you building in the kitchen? or me building in a walk in closet?
Old Apr 18, 2007
  #34
02fpcivic's Avatar
I dont know, hehe. I havent tryed the closet thing yet but the kitchen works good if you keep everything covered with trashbags under towels, haha. Tracey was a good sport, thats why I married her.
Old Apr 19, 2007
  #35
metalviper's Avatar
metalviper is just really nicemetalviper is just really nicemetalviper is just really nicemetalviper is just really nice
subscribed....nice work!
Old Apr 19, 2007
  #36
yeah, much better. my one computer at home doesn't allow me to use the advanced features either. in that case, i'll just manually type the [img] tags around the links. can't wait to see this all done!!!
Old Apr 20, 2007
  #37
Randyh's Avatar
Randyh will become famous soon enoughRandyh will become famous soon enough
Glad to see this thread still moving, I see it as one of the most important threads to ever hit the forced section on this board. d16 and 17 rods are the same except the 16 has beefier big ends. Both motor have the same deck height. Pretty much the only difference is the cranks and the pin height in the piston. But since the rods big ends are thicker you are better of just loosing the .1L
Cant wait to see how it turns out, if I can ever finish my Starlet my 7th gen will be getting the same treatment.
Best of luck
Randy
Old May 3, 2007
  #38
02fpcivic's Avatar
Got around to welding up an intake manifold. I used a Honda Pilot TB I scored on ebay for $35 shipped. Its about 2.5" ID so it should work out great with my 2.5" piping. I am going to have the manifold powdercoated sometime soon too. I never clean anything so I dont wanna polish it, hehe. The pics were from my cell phone so hope you can deal with it, hehe. Same kinda setup as Andy's with the tapered velocity stacks and the plastic insulator spacer (not in the pics), just a little different plenum and the obvious TB change. It should work out nicely after I rework the throttle cables and such.
Old May 3, 2007
  #39
02fpcivic's Avatar
P.S. With this TB I can still have my cruise control, YAY!!!
Old May 3, 2007
  #40
tfnaaf's Avatar
BLDNPSI Mod
looking NICE!
Old May 3, 2007
  #41
dezod's Avatar
7thgen Power Maker
Good stuff Gerry
Old May 3, 2007
  #42
andyman97's Avatar
Turbo Guru
Sweet **** bro. I thought that looked familiar
Looks like we learned something about not using supports with the velocity stacks hehe.
Old May 3, 2007
  #43
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
thats pretty tight.. So with a 1.6L crank, you should be having a shorter stroke length correct? If i remember correctly, i believe that the D16 has a 90mm Stroke, and the D17 has a 94.4mm? Did you use custom rods?
little picture i like to show:
Old May 4, 2007
  #44
speedfoos's Avatar
Damn. Very very nice.
Old May 4, 2007
  #45
bigmax1665's Avatar
bigmax1665 is an unknown quantity at this point
so you need custom rods to use the d16 crank? can you use the d16 crank/rods and d17 pistons? or are the d16 rods not short enough?
Old May 4, 2007
  #46
02fpcivic's Avatar
I am assuming they will. The mains should be the same, on the rods the size difference seemed to be negligable. If anything they might be a touch narrower but they probably are the same. I used the D16 bearings to match my crank and rods. Honda journal sizes usually are pretty consistent and many blocks share the same size bearings. Actually one of the part numbers I used was also for an H22. If you have an engine apart and you want to use the ACLs just buy a set and mic them out, if they arent the same toss em up on ebay and order OEM.
Old May 4, 2007
  #47
Buds302's Avatar
Buds302 will become famous soon enough
so which D16 lower end did you use? i heard the lower end fro ma Y8 is different from that of a A6? can you clear this up please? and a set of stock D16 pistons will do the trick? well not stock but stock dimensions. like say some forged endynes?
Old May 10, 2007
  #48
02fpcivic's Avatar
Well I chopped out the whole radiator support, got the center brace tied back in, and the manifold mocked up a lil. I did it in my driveway with a scratch-start 110v DC TIG inverter so its a lil messy but once I get it tacked I'll take it back to the shop and work some magic. I ran out of elbows but the rest should be here tomorrow. The compressor touches on the #2 runner so I either need to stick a spacer in there or chop off the flange and raise it up, NBD. The compressor isnt staying in that direction either. I know it looks like hell but the end result will be much neater. The old motor is still in there and its just a primary mock-up.
P.S. if you are confused about my WG and manifold placement dont be, Im using a older style half radiator with a 2 inch core and a 1600cfm fan to gain a bunch of room. Lots of crap needs to go back in there still, hehe.
Old May 10, 2007
  #49
Jap-Euro Fusion
HAAAAAA finally someone went for a top mount. This is gonna get fun.
Old May 10, 2007
  #50
02fpcivic's Avatar
I didnt want all kinds of sharp bends in the manifold and downpipe so this is going to work out sweet. Plus I can run the air filter behind the headlight and pop it out at the track. Still need mounts for the rad. Im hoping to have enough room to put the crash bar back in FINALLY! gonna use a 3.5 inch thick IC, maybe 8" high and mount it to the crash bar.
Old May 10, 2007
  #51
dezod's Avatar
7thgen Power Maker
Should be an interesting manifold. Similar to the tC one we are working on. Keep us posted.
Old May 10, 2007
  #52
andyman97's Avatar
Turbo Guru
That's sick dude.
Old May 10, 2007
  #53
Alpha 5's Avatar
DAMD DUDE, DAMN! LOL That kicks ***.....
Old May 10, 2007
  #54
cleanmagcivic's Avatar
cleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trusted
nice work
Old May 10, 2007
  #55
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
you just may be the best fabricator/welder I have ever seen. Top quality stuff man, keep it up.
Old May 11, 2007
  #56
gsniper666's Avatar
gsniper666 has a spectacular aura aboutgsniper666 has a spectacular aura aboutgsniper666 has a spectacular aura about
looks good
Old May 11, 2007
  #57
ST8RACE's Avatar
ST8RACE has a spectacular aura aboutST8RACE has a spectacular aura aboutST8RACE has a spectacular aura about
looking great. im watching and learning as you go along.
great stuff, cant wait to see the final product.
Old May 14, 2007
  #58
02fpcivic's Avatar
Got it all tacked up. Reworked No.2 runner to clear the compressor and tightened up some of the joints too. Everything fits perfect, compressor outlet goes where I planned, the downpipe has ample clearance, I can almost fit the whole palm of my hand in between the hood too! Gonna rip the old motor out tomorrow night I hope. I'm just chipping away at it, it will be done soon I hope.
Old May 14, 2007
  #59
andyman97's Avatar
Turbo Guru
That's looking really nice man, great work! Hey, do you think the heat wrap on the turbine housing is beneficial over ceramic coating?
Old May 14, 2007
  #60
02fpcivic's Avatar
The Jet Hot Ceramic I had on my old housing rusted through after about 2000 miles. I think the wrap actually works better at keeping the underhood temps down IMO. Im going to use heat wrap this time around.
