It begins...
Old Mar 7, 2007
  #31
AmbulanceMonkee's Avatar
subscribed. looks like a hella project.
Old Mar 7, 2007
  #32
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
Quick side question, where do I get wunnadoes tech manuals? I'm trying to look online, but not finding anything.
Old Mar 7, 2007
  #33
Boilermaker1's Avatar
Jap-Euro Fusion
handaaccessories.com
Old Mar 8, 2007
  #34
streetthrowback's Avatar
streetthrowback should not be trusted
what motor are u strippin??
Old Mar 9, 2007
  #35
andyman97's Avatar
Turbo Guru
www.helminc.com
Old Mar 9, 2007
  #36
CIVIC X3's Avatar
CIVIC X3 is on a distinguished road
if i'm not wrong the D17a2
Old Mar 24, 2007
  #37
Jap-Euro Fusion
Re: It begins...
Just an update... I got the whole thing ripped apart. The block is going to the machine shop with the pistons on friday for honing and possibly decking (I dont think it needs it). I'm still waiting for intake valves and my OEM parts from the Majestic Honda (all $677 of it). I have my rods, rings, slugs, cam, retainers, springs, exhaust valves, tools, head studs, etc... Once the block comes back I can notch the sleeves and put this pig back together... Waiting for my new guides and seals, then I can drop the head off at the shop, then all hell shall break loose
Old Mar 24, 2007
  #38
skipbarber's Avatar
Re: It begins...
i got a head, and new valve seals, then got lazy. i need to pick up the pace. youre moving too fast for me..
Old Mar 25, 2007
  #39
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Re: It begins...
why only 20 mins of boost why not an hour!!! lol.. but i figure you plan on upgrading the Cooling system?
Old Mar 25, 2007
  #40
Jap-Euro Fusion
Re: It begins...
Standard track day sessions are 15-20 minutes (either HPDE 1-4 or Novice, Intermediate, Advanced). It divides out the hour. Most tracks are well aware that street cars wont go much longer (tires and brakes start giving out), and they dont want to be peeling cars off walls and out of sand traps.
Cooling system..... eh, its pretty well cooled now, I'll probably end up with a Koyo race radiator just for the hell of it, and on the track I tend to run very little antifreeze and a whole lot of water and water wetter (water absorbs heat better than ethylene glycol), and I already have a big oil cooler, so I think I'm set. I'll probably prop the back of the hood up a tad to clear the hot air out from under the hood, I've heard it helps a lot to just keep air moving under there. I dont anticipate any problems.
I'm in turbo mode... bahhhhhhhhhhhhhh. Ok, I'm going to bed now.
Old Mar 25, 2007
  #41
andyman97's Avatar
Turbo Guru
Re: It begins...
So I guess you decided against the sleeves after all. Sounds like its going well thus far, how did the notching go?
Old Mar 25, 2007
  #42
Jap-Euro Fusion
Re: It begins...
Enough people said it wasnt necessary to convince me not to.... I started notching one cylinder, then concluded I needed a piston on the rod to center it so I knew how much to take off, so I figured I'd have the walls honed to avoid potentially messing up the new pistons on the old walls.
Old Mar 25, 2007
  #43
NSRCivicRacer's Avatar
NSRCivicRacer is an unknown quantity at this point
Re: It begins...
i gotta see this through. subscribed!
Old Mar 25, 2007
  #44
andyman97's Avatar
Turbo Guru
Re: It begins...
Yeah, its really overkill. Once I drop in the gt30, I still don't plan to sleeve it, even at 450 whp. I think your pistons would have been fine, but either way, it won't matter. Good luck.
2005EM2
Nov 20, 2008 08:31 PM
LogicWavelength
Oct 5, 2004 11:14 PM
ZdS03Civic
Engine Swaps
Jun 2, 2004 03:57 PM
