can somebody help me out with a fuel regulator
Old Dec 20, 2006
puertorro's Avatar
puertorro should not be trusted
hey i got a d17a1 and im looking for the better and easier way to install a fuel regulator, do i need to change the fuel rail or i got to make a fuel return line to install a convectional one.
what alse can i do to my car to run faster i already got the header install with piping and catalitic convertor, better sparks, less wheel weight, suspention. tell me more...
Old Dec 21, 2006
Michalo187's Avatar
Abortion Survivor
the only way you can install a fuel regulator is with a return fuel system. Atleast this is what i think. AS for performance only way to get a lot of power is turbo, swap or spend a lot of money on a nice n/a setup.
Old Dec 21, 2006
civic01vtec's Avatar
Why do you want to install a regulator ?? Our stock pumps have one built in. You don't need to go messing with that stuff.
Old Feb 3, 2008
hitsugaya's Avatar
hitsugaya is an unknown quantity at this point
Re: can somebody help me out with a fuel regulator
is the regulator in our pump adjustable? i'm doing a custom turbo install and im only running 8 psi or so but i dont really wanna eff around with a return system if i dont have to.
Old Feb 4, 2008
speedfoos's Avatar
You don't have to mess with it and the FPR on the stock system is not adjustable. I boost at 9psi daily on a stock regulator with a Walbro pump.
Old Feb 6, 2008
hitsugaya's Avatar
with the bigger fuel pump you must use bigger injectors aswell right?
i've seen the rsx-s injectors on ebay and thought about buying them for $100
good or bad deal?
Old Feb 7, 2008
speedfoos's Avatar
It's not so much the pump that determines you needing bigger injectors, it's the fuel requirements of the car.
Stock injectors can't hang above like 1psi on a boosted setup, they're only like 220cc. RSX-S injectors are good to about 180-whp (ish) as they flow 310cc. $100 isn't bad for them, but you can find them cheaper. I picked up my SRT-4 injectors (stage 1, 577cc) for $60 shipped.
Old Feb 7, 2008
andyman97's Avatar
Turbo Guru
Yes there is a way to run an aftermarket regulator and return line with zero modification to the fuel rail....
Old Feb 7, 2008
speedfoos's Avatar
Yes, but your way makes my head hurt Andy and I've forgotten how you did it.
Old Feb 7, 2008
andyman97's Avatar
Turbo Guru
Well mine is run normally, I have a manifold and rail made by Gery. The way to do it is very simple. Just tee the feed line before the rail. One side of the tee goes to the rail, the other to the fpr, then drop the return line back to the tank.
soufigured
15
Aug 18, 2015 08:22 PM
brady15
Aug 8, 2015 08:16 PM
Civicircus
Aug 6, 2015 11:58 PM
Green02civic
Jul 27, 2015 10:48 PM
jzhartman
22
Jul 23, 2015 10:42 PM
