Auto lock issues after window regulator install
Old Aug 8, 2015
brady15's Avatar
brady15 is an unknown quantity at this point
Hi all, this is my first post so bear with me. I put a drivers window regulator in a 2002 EX sedan the morning with zero issues. However, now that its all back together the auto lock is getting screwy. It either wont lock or if I lock the door manually, it wont unlock.
What Ive tried already: I unplugged everything and checked wires. appeared good. I felt the actual door lock rod. appears unbent but the lock does not physically go up and down like I think it should. I unhooked the battery and let it set for a while all with no results. Anyone ever have this issue? Am I missing something simple or did something fry in the autolock set up? Any help is appreciated.
Old Aug 8, 2015
Re: Auto lock issues after window regulator install
Got the door closed while you are trying to get this working? (or pull out on one of the handles so the lock can work)
Did you unplug the wiring from the door latch?
Damage the wiring to the latch?
Did you unplug the power lock switch?
Did the power lock actuator go bad (they do this)
Use a test light to check for electrical activity at the power lock connector?
(get a small #194 bulb, unbend the 2 wires from the base of the bulb, stick it into the 2 wire connector at the latch then operate the power lock switch. The bulb should light if it is getting both power and ground)
Old Aug 8, 2015
brady15's Avatar
Well, I know I'm getting power to the actuator. When I push the key fob or the switch on the door it tries to lock and door unlock but it only does one. I only unplugged the switch on the door when I pulled the door panel off. That's why it seems so strange to me, I didn't touch any other part of the door lock system or any kind of electronics.
Old Aug 8, 2015
So it only tries to go one way then quits?
If you wait a while then try the opposite way, it will try again?
Sounds like a bad power lock actuator, motor is too weak to run the full distance.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
MamaBear2015
May 3, 2015 02:17 PM
bsmiley
Apr 27, 2015 01:27 PM
mwwhonda
Nov 7, 2001 07:24 PM
