K24block/K20head or a K20A2
ive been doing alot of readin and listenin to members of my car club and what to do i was thinkin about the K20 swap but then my car club was tellin me about hte k24 wit k20 heads and i did a sreach and i couldnt come up wit an numbers as far as horse power and what would give me a better run time and over all horse power which ever set up i go will be turbo but im just wonderin if anyone had any more info that i cant seem to find on this
ok i found the post on here about someone in the middle of this build now but wit the k20z3 head instead of the k20a2 head i kno there is a problem wit the k24 and k20a2 head if you dont build the bottom end. and revin to high and blowing a rod is there an issuse u wit this on the k20z3 head also or is it only the k20a2 head on that block
K24/K20 is the only way to go imo, unless you want to have a some what torqueless high reving motor.
As far as numbers, K24/K20 with bolt-ons are usually around 230 whp and almost 200 ft/lbs torque
or try the f20 block, k20 head, b16 IM, and b18 valve cover. From past experiences, ive seen this setup make close to 395whp.
ps...this topic has been beaten to death. use "search"
oh yeah, and welcome to the boards.
See i kno i said in my post i did use sreach but that was only a few hours of lookin and yes i kno i need to do more time into it but i wanted to maybe ask the people on here what they have done and also seen work if u can help lead me in the right way please help but im just tryin to make sure i have bases cover before i do this build. i know for the stock swap it like 5-10k but im lookin at buildin it from the bottem up and doing it right from thew beginin no point nad havin to go back and do something later so im gonna be spendin alot more money so im sorry if i bring up something yall have talked and talked about but i wanna make sure i get a good understandin before i spend 10-20k on tryin to make this motor run the way i wanna be able to run and im not talk just 250hp im talk at least 350-400hp so thats me and im glad to be here but dont assume that i didnt use the sreach before i posted.
thanx for that site alos if anyone knows any more let me kno ty for the help
Its ok, people think they have to parent the forums when they feel people didn't search long enough.
Like Hondaluver said, K20a.org is great, but read the FAQ's over there too.
A long winded 7th genr
I think that the frankenstein head swaps are relatively ambitious, next step up from the standard k series swap. I do not have confirmed imformation on this but I thought that the combination itself didn't make more power then the complete k20 until you bolt on.
true story... i freakin' agree. My cars a joke when i race from a roll. I lose to the most unexpected... quick off the line though. But k20/k24 is the best setup.
Odd that you should say that. I've been around a helluva lot of type-s, and the only races they ever win are from a roll, concisdering they don't start making power until about 5k. I know you have the K20a, but the only recognizable "low end" difference is your more agressive transmission.
Its a celebration bitches!
when i had my k24/k20 set up with my 225/45/17 azenis, i would have full wheel spin between 1st, second, and third gear i would actually get traction half way. the amount of low end tq is unbelievable.
tekgnosis
77
Aug 1, 2003 03:13 PM
