K20a2 Swap Parts List Needed
Old Oct 17, 2003
ffokuf's Avatar
I can resist everything except temptation.
ffokuf is a jewel in the roughffokuf is a jewel in the roughffokuf is a jewel in the rough
Question K20a2 Swap Parts List Needed
ive got some money saved torwards my swap now and i want to start buying all the items ill need for the K20A2 swap into me 03 civic ex. I dont want to buy the motor first cause ive been watching the prices falling over the last few months and i dont want to buy it now and once i finally have everything have it selling for less you know. Anyhow i need a list of exactly what parts ill need for this, because i dont really know, although once i know ill have no problem finding the stuff. Also i want to do all small engine mods before its dropped into my bay so any recomendations on what engine mods to do before i put it in also greaty appreciated! This is gonna be awesome K20A2 lol..... Let me know anything you know!!!!!
Thanks!!
Old Oct 17, 2003
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
hasport.com look it up...
Old Oct 17, 2003
§C§H§O§C§O§B§O
http://www.hasport.com/News/Articles/ESK1parts.htm
there u go
Old Oct 17, 2003
ffokuf's Avatar
SWEET! thanks alot...that was exactly what i was looking for. Yawll rock.
Old Oct 17, 2003
Em2Guy's Avatar
Em2Guy is an unknown quantity at this point
1.engine
2.rsx/si subframe
3.rsx shift cables,rsx/si radiator.w/fans
4.all stock mounts
5.axles
6.ecu
7. clutch line
8.some wire mods..gook luck figurin those out
thats all required stuff. ABS, powersteering, AC will cost a while lot more. my friends says its not all that bad with out that stuff
Old Oct 17, 2003
iamboo's Avatar
Retired - SoCal FI Mod
if you're going drag setup, no need for the abs, powersteering or a/c... if you're going touring or roadracing then abs and powersteering is a must.... i wish i had abs...
Old Oct 18, 2003
NoBottleJustThrottle's Avatar
NoBottleJustThrottle is an unknown quantity at this point
hasport doesnt have all the parts listed that you need. Believe me, those missing parts set my project back by quite a few weeks. Its just a bunch of little stuff, like there is this little fitting that the RSX-S clutch line screws onto that goes into your clutch master cylinder...the civic fitting is 12mm, the RSX-S one is 10mm. You will need that fitting. Yea, its like that throughout the entire swap. Or, you can just buy my wrecked car, and not have to worry about all those little things cause its all there on my car. Plus TEIN coilovers, rims tires, headlights, grill, short shifter, and so on.
Good aftermarket stuff to buy before the swap is started, is tranny stuff. Everything else you can get to, it will be tight to get to some things, but not as bad as the tranny.
Old Oct 18, 2003
snowboreddave's Avatar
snowboreddave is an unknown quantity at this point
http://www.hondawerx.com/kseriesswapparts.htm ....try this one out !!
Old Oct 18, 2003
Snowboreddave, im pretty sure thats the exact same list off of the HASport site...which is missing stuff from it.
Old Oct 19, 2003
ImportRacer2123's Avatar
K20 Member
No Bottle did you wreck your car?
Old Oct 19, 2003
i didnt, some drunk brod ran into me at 85mph though when i was going maybe 5mph from a stoplight.
Old Oct 19, 2003
DarrenA's Avatar
DarrenA is an unknown quantity at this point
Even though this really isn't on topic how much do you want for the Teins?
Old Oct 20, 2003
selling the car as a whole...9-10 large for the whole thing.
Old Oct 20, 2003
K20 Member
what needs fixing?
Old Oct 20, 2003
From what i hear (since i dont have the car), all the aftermarket stuff on my car is still in near perfect condition. The only exceptions to that is the rear passenger rim now has some scratches on it, and the rear passenger tire has a hole in it. All the other tires were put on the friday before the accident though. The TEINs, rear lower DC tie bar, rims and tires (for the most part), TYC Black Projectors, Altezza Grill (which isnt painted), short shifter, pedels, shift ****, and the entire motor swap are still in perfect condition. You would be buying about $10,000 worth of aftermarket upgrades, and a car that you can use for extra parts.
The car itself is totalled. The rear passenger side was hit pretty hard, which in turn tweaked the entire car just enough to total it out. Since our cars are a uni-body design...trying to fix it would be pointless.
the person that buys this car could have his new motor in his car and running within a weekend. Its all just pull, and plug in. The wire harness is already modified, the axles are new, everything to get the motor swap done is there...no little suprises.
Old Nov 1, 2003
Island2K2's Avatar
Island2K2 is an unknown quantity at this point
ill give you 5000 for the car
Old Nov 2, 2003
...no.
You want to give me 5 grand for 10 grand worth of aftermarket parts alone, on a car thats worth $2800? You want to give me less than half what the car is worth? Again i say, no.
This isnt like buying a wrecked RSX-S. Cause with buying a RSX-S you would still have to spend over $2000 to put that motor in your car...thats not counting labor charges. There is no guess work with what you will be buying. This is a working RSX-S motor swap...all the parts are there to make it work in a 7th gen civic. Nothing would have to be bought.
Old Nov 2, 2003
Island2K2's Avatar
im doing the k20 swap rignt now my car is in 100 differnt pieces down stairs i just need to know how to do the wires on the o2 sensors on my k20 someone help me with the wiring asap thats all i need
Old Nov 2, 2003
do what i did...goto Honda and get the wire diagrams for your civic...then goto Acura, and get teh wire diagrams from the RSX...then compare them, and see what has to be modified.
Its not that hard, you just have to think about it for a little bit.
You should be able to get the copies of the diagrams for free.
Old Nov 2, 2003
Island2K2's Avatar
thats what i was wondering because i cant find them online
Old Nov 3, 2003
i think ephatch.com has the RSX-S helms...no idea on the 7th gen civic though.
Best bet...goto Honda, and Acura.
Old Nov 4, 2003
Jodster's Avatar
Post Whore General
^^^^^^^^^^Question for you, what year RSX did the motor come out of? Cause if it was a 2002, those that have a 2003 civic would not be able to legally able to install your motor into their civic. Just a heads up.
Old Nov 4, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
don't forget...you need the keys programmed as well unless you can bypass the
immobilizer
Old Nov 4, 2003
I got my keys done for free from my local Honda dealership.
The RSX-S motor i have came from a 2002. Which, you are right, would be a problem if someone has a 2003 civic in california...in other states i dont think it matters. Atleast it didnt with all my other friends in Texas.
Plus, there are always ways around getting it smog'd...but we cant talk about that here.
Old Nov 5, 2003
Island2K2's Avatar
i need the wirng diagaram for the rsx and civic engine harness the motor is a 2002 and my car is 2002
usajags84
15
Aug 19, 2015 03:12 AM
green01civic
Apr 29, 2015 01:36 PM
bsmiley
Apr 27, 2015 01:27 PM
Myredjonda
Apr 14, 2015 07:00 PM
JeffSpeed21
Nov 3, 2001 10:32 AM
