e-manage
Old Dec 13, 2006
slow04civic's Avatar
slow04civic is an unknown quantity at this point
e-manage
Ok have used the search first! didn't find what I needed to know I'm hooking up my e-manage blue what harness xtra do I need this is on a d-17a2 turboed with a t-3 and rsx-s injectors.Do I need a vac manifold if so what does it do.I'm new at this so any help would be good.
Old Dec 13, 2006
BCCentaur3's Avatar
BCCentaur3 is an unknown quantity at this point
The vacuum manifold is just a cleaner and more efficient way to disribute vacuum source to the bov, wastegate, boost gauge, ect. If you're using that many stuff get a vacuum manifold, its better off than Teeing everything up. The e-manage would work for any turbo.
Old Dec 13, 2006
BCCentaur3's Avatar
Some times I wonder if people just say that they have searched and ask their question to get an answer just to avoid bashing.
Old Dec 13, 2006
I my self had looked for over an hour not to say some don't.Thank you for the info.I need to know what harrness do I need the 3 bar map sensor and harrness and Ignition harness.I may have worded the search wrong I will try again.
Old Dec 13, 2006
Boggie1688's Avatar
Diamond Member
Boggie1688 is an unknown quantity at this point
Yea the search function is hard to use...sometimes the information is there but your keyterms are just way off.
Old Dec 13, 2006
BCCentaur3's Avatar
Yeah thats kind of true and for your question I think you are going to need the injector harness. Why don't you just go with Dezod's pnp harness, so you won't have to wire everything yourself.
Old Dec 13, 2006
I am having a shop hook it up and tune it I just want to have everything be for I take it there.I still can not find on the search a list of what you need to hook up the e-manage I am also looking for wiring diagram for hooking it up read this not to long a go I must be doing some thing wrong in the search.Thax for your help.
Old Dec 13, 2006
Boggie1688's Avatar
Diamond Member
I dunno if this is what you want...but check out this thread.
http://www.7thgencivic.com/forums/sh...d.php?t=217534
I think it was only like 15 down from yours.
Old Dec 13, 2006
Yes that is it.how do I rep you you have been a big help!
Old Dec 13, 2006
Boggie1688's Avatar
Diamond Member
Notice how each individual post has a little boxed area. Look at the top right, there should be a # that signifies the number of the post of that thread. Directly below it and slightly to the left is a blue little square, almost like a chicklet. Click on that, thats how you rep.
Old Dec 13, 2006
I hope that rep was right. still no luck on the parts list would gearbox know what I need.
Old Dec 13, 2006
BCCentaur3's Avatar
Greddy pressure sensor, Greddy Pressure Harness, Greddy Ignition Harness, Greddy Injector Harness. Thats if you don't want to do any short cuts.
Old Dec 13, 2006
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
rep me to.. lol
Old Dec 14, 2006
BCCentaur3's Avatar
Hey if your repping them rep me
Old Dec 14, 2006
What short cuts and can I buy a vac mani, where can I buy one for the rep I try to rep everyone that helped if I didn't rep you please tell me why I sould have reped you.
Old Dec 14, 2006
hers what a typical VM would look like
heres a website selling it
http://www.davidenglish.com/swift/Va...manifolds.html
ebay has it
http://cgi.ebay.com/ebaymotors/GOLDE...spagenameZWDVW
http://cgi.ebay.com/Vacuum-Manifold-...QQcmdZViewItem
Heres something like it but not really known
http://www.kimble-kontes.com/html/pg-216105.html
now you can rep me.. lol
Old Dec 14, 2006
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
this site just needs something to make it more simple to navigate....i've been on here for a while and can use it...but i was pretty frustrated for a while when i was new reading all the opinions and b.s....and all the biching....but the site is only getting better...like how everyone's going turbo or swap or just progressing way more than a year ago
Old Dec 14, 2006
I will rep you xproductionz I have to wait it's telling me to much rep in last 24 hrs thank you for the pick.
Old Dec 15, 2006
BCCentaur3's Avatar
Heres a site to buy a vacuum manifold. By short cuts i meant going the route by not useing an e-manage. Since you are using E-manage, get the harnesses i listed. http://www.accountwizard.com/clients...acuum+Manifold
Old Dec 15, 2006
If I use Dezods $200 harness will I need the other greddy harness the plug and play harness looks like a way cleaner install.
Old Dec 15, 2006
ronaldo9's Avatar
Dezod harness aka Boomslang harness is all that you need. I have it on my car. Literally just unplug ur factor harness plug the factory harness into PNP harness and the other end of the PNP harness goes into the ECU. Takes 15 mins or less.
Old Dec 15, 2006
BCCentaur3's Avatar
Just go with Dezod's pnp harness
Old Dec 15, 2006
If I go dezod's harness do i still need the map sensor harness from greddy.Dezod don't say it comes with this part greddy's site says if you are turbo you need it is this true.
Old Dec 15, 2006
ronaldo9's Avatar
Yes you do I think its called the pressure sensor though.
Old Dec 15, 2006
procivic.com don't list this pressor sensor just 3 bar map sensor.
Old Dec 15, 2006
ronaldo9's Avatar
PM dezod or just call them they'll tell you exactly what you need so you don't order the wrong thing by mistake. It's my understanding you the pressure sensor and the pressure sensor harness.
Old Dec 15, 2006
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
why do you need a 3bar map sensor? your not gonna be running crazy boost are you? the standard greddy pressure sensor and harness should be sufficient...
dezod
Engine Management
112
Feb 7, 2008 12:38 PM
abmerop18
Engine Swaps
Dec 13, 2004 03:10 AM
shady88
Engine Swaps
Jul 30, 2004 02:54 PM
opto_isolator
20
Jul 2, 2004 09:37 AM
