head swap
Old Nov 26, 2006
detroittosag's Avatar
detroittosag has a little shameless behaviour in the past
head swap
hey i have a question would a ex head pnp with some of thoes new valves from dezod and a cam gear sound good on a lx bottom??? will i have to get my key programed any suggestions would be helpfull
Old Nov 26, 2006
rutscivic's Avatar
rutscivic is an unknown quantity at this point
no..
Old Nov 26, 2006
ian01ex's Avatar
ian01ex is an unknown quantity at this point
nice informative answer
Old Nov 26, 2006
Civicman1988's Avatar
If u do it I would recommened a camshaft I dont think u will have to reprogram your key
Old Nov 26, 2006
rutscivic's Avatar
yea sorry about that i was kinda blunt...but i really dont think it would be worth the money to do that..
Old Nov 26, 2006
CenZ's Avatar
PWIT
a ex head will fit a lx. im sure if you work the head it will work fine on lx block. and no you will not need to reprogram the key. search for a minime swap.
Old Nov 26, 2006
CenZ's Avatar
PWIT
he didnt ask if it would be worth it, he asked if it could be done.
Old Nov 26, 2006
rutscivic's Avatar
true, it can be done
Old Nov 26, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Unless you're revving it to 9 grand, you don't need new valves.
Old Nov 26, 2006
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
yes you can put an ex head on an lx. you need the ex head and head gasket and a vafc-ii. no work needs to be done to the block. if you have an 04-05 good luck finding the ecu pinouts when it comes time to wire the vafc-ii. ive got my car torn all apart rebuilding the motor and doin a head swap and i still cant find the pinouts.
Old Nov 26, 2006
if you decide to swap the ecu to EX model, then you need a new key. but not if you use vafcii to adjust vtec and fuel.
Old Nov 27, 2006
thanks i see it wouldn't be worht the money and time. cool i'll let this project go
Old Nov 27, 2006
dezod's Avatar
7thgen Power Maker
That is the whole point! Power from 7500+ RPMS!
Old Nov 27, 2006
05 civic lx
Guest
Posts: n/a
a guy at a shop told me that if u did the vafc2 and use that set-up after about a year and a half it would get f-ed up, cuz of the lx ecu or something. didnt really understand it but he said its basically just going to wear out(the controller that is)
and ya it wouldnt be worth it, like its what maybe a grand or 1500? and like 7hp? lol
Old Nov 27, 2006
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
i got a PNP head for sale for 300
Old Nov 27, 2006
Jap-Euro Fusion
Well I've never seen valves add HP, and its gonna take a lot more than valves and a head swap to go beyond the stock redline. (even still, it appears from reading around that even aftermarket valves are no guarantee against bending or snapping one) In the context of the OP, who appears to only want to swap a head, stainless valves are utterly pointless, so why put in new valves when the stock $6 valves work more than adequately?
Old Nov 28, 2006
dezod's Avatar
7thgen Power Maker
No where in my post did I state that the valves add power. So I am unsure where you derived that notion from.
With respect to power on a different note....higher reving capability allows for a larger, more broad power band, which in essence on persay a turbo car with a decently sized turbo could produce some great mounds of power and be able to breathe more on the top end. Similar can be said with power bands that seem to climb to and past redline of 6250. Small turbos that peak HP at 5K RPMS would not benefit from them.
The stock valves take quite a beating on this app when boosted or not due to the rocker arm assembly. They snap these valves open and closed VERY quickly putting lots of strain on the stock valves. I have seen numerous Honda motors including the D17 melt valves with turbo, nitrous etc.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
Chronic_issues
May 8, 2015 05:40 PM
Drk01Civic
Jan 23, 2002 06:33 PM
supercivic01
South
Nov 30, 2001 11:27 AM
