View Poll Results: Are you using E85
Yes
8.33%
No
33
91.67%
Voters: 36. You may not vote on this poll
E85 Fuel
Old Apr 24, 2007
  #31
andyman97's Avatar
Turbo Guru
Re: E85 Fuel
I will attest that I know several people who run e85 and have had ZERO issues with hose or pump breakdown.
Old Apr 25, 2007
  #32
andyman97's Avatar
Turbo Guru
Re: E85 Fuel
Yes, the mileage is worse. But if you're trying to build a drag car, mileage isn't the priority, power is. This is exactly why I'm sticking to 93, I don't want to deal with the headache of decreased gas mileage, damaged o2 sensors, daily driveability issues (I have enough of those) and separate tunes. I want to be able to drive the car anywhere anytime, so for me, e85 isn't even really an option.
Old Apr 27, 2007
  #33
gmcuajo's Avatar
gmcuajo can only hope to improve
Re: E85 Fuel
Originally Posted by servion
It requires ~30% more fuel, but you will make ~5% more power because it burns so much cooler.
"you will make ~5% more power because it burns so much cooler"
How it is possible? Maybe that fuel make ~5% more power, but I doubt it is because "it burns so much cooler".
In an internal combustion engine the expanding HOT GASES makes the power, so anything that is "so much cooler" (if that means lower temp.) will make less power.
Old Apr 27, 2007
  #34
gmcuajo's Avatar
Re: E85 Fuel
Originally Posted by GibaD17
Here in Brazil we only use Pure Ethanol at turbo cars. All civics from 7th gen here were made to use a mix of 80% gas and 20% ethanol.
If you use more ethanol than your car is prepared you will have trouble at:
1 - Fuel pump (you have to replace it to a Ethanol-made)
2 - Fuel filter (it wil be obstructed after 20k miles)
3 - Fuel injectors (you'll need 30-35% bigger injectors)
(from Discovery Channel)
Brazil have the largest production of sugar cane in the world. A large percent (I think around 70%) of that sugar cane is used to make ethanol. From 1980 on Brazil (by Law) all the fuel stations have ethanol, gasoline and diesel; and the ethanol is cheaper too. That's why in Brazil most of the cars are flex-fuel.
P.S.
Correct if something wrong.
Old Apr 27, 2007
  #35
gmcuajo's Avatar
Re: E85 Fuel
There is something that is called the energy rating of the fuel. It is commonly given in BTU (british thermal unit) per gallon of fuel.
One Hp is about 42.4 BTU. The ethanol (not talking about E85 specifically) have less energy than gasoline so it can't make more power. Is the engine that makes more power, either advancing the ignition or higher compression, or whatever... Another fact is higher octane fuel burns faster.
That's why you have less milage with ethanol, even more if your engine isn't make or tuned for it. To understand this, also compare with the diesel. Diesel have more energy content than gasoline, thats why the diesel engine gives more milage.
Old Apr 27, 2007
  #36
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Re: E85 Fuel
Holly triple post batman!!!!
Old May 5, 2007
  #37
GibaD17's Avatar
GibaD17 is an unknown quantity at this point
Re: E85 Fuel
gmcuajo,
all the ethanol made in brazil is from sugar cane. All that you wrote is correct. We have ethanol at all fuel stations. The price is usd 2,59 per galon and it's cheaper than gas. We pay usd 4,67 per galon of gas.
Bman2212
Sep 2, 2015 11:49 AM
cwisenbaker06
Aug 19, 2015 04:29 PM
Civicircus
Aug 6, 2015 11:58 PM
Green02civic
Jul 27, 2015 10:48 PM
