Turbo Set-up. Is this all i need to get started?
ive been doin sum research and i have come up with a list of what i need to get my turbo set up started, im not sure if im missings anything but i just want to know if this is whats needed for a basic set up.
Plz add anything i may have missed or things i need.
D17Z1 (Aus Spec) 8psi MAX
Garrett GT2560R BB Turbo
Exhaust + dump pipe
HKS SSQV BOV
RSX 310cc injectors
Intercooler
Charge pipes
Walbro 255 Fuel Pump + Lines
Return Oil System
Water Lines
Manifold
ECU
Fuel Regulator
Turbo Timer
Spark Plugs NGK
Gauges
im still researching since ill be doin this around the September period so i know what ill be getting is a good set-up.
Exhaust + dump pipe
HKS SSQV BOV
RSX 310cc injectors
Intercooler
Charge pipes
Return Oil System
Water Lines
Manifold
ECU
Fuel Regulator
Turbo Timer
Spark Plugs NGK
Gauges
Yeah every other ones are too long and push ur fuel rail onto the tps sensor on the throttle body. Trust me there is no room for anything other than them. I have heard of people using srt4 injectors, but it is really hard to tune on idle with them.
I'm confused on the turbo.... you say 2560R/S... do you mean the 2860RS AKA the GT28RS, Disco Potato? Or do you mean 2560R also known as the GT28R?
The RS is a little bigger of a turbo, if you go the RS route, opt for the T3 hot side. Also, H2O cooled turbos reduce the need significantly for the timer, since water will naturally continue to move from hot to cold and the waterjacket stays full.... so you'll have some water moving through as the turbo cools.
the only reason i say emanage or ems is because no one has actually used the kpro since it was just realeased. I mean if he wants to be the first then all props to him, but i dont think hes willing to spend alot of money to be the first to tweak out the tweaks thats why i mentioned emanage which works and only runs anywhere from 200-400 depending on the set up.
im still deciding on which turbo to get the T28R ot the T25, i want the turbo to run efficiently
also since both are oil & water cooled turbos i wouldnt need a timer ur saying. how does that actually help, any more info on that system boiler.
Power difference between T28 and T25 are neglidgeable. You don't necessarily need a turbo timer if you can let your car idle for 1 minute before you're about to turn it off.
Water continues to move if there is a temperature difference, so as long as the turbo is hot, and the coolant outside the turbo is cooler, water will continue to move. You use a timer on journal bearing turbos because once the car shuts off and theres no oil pressure, the oil more or less drains out through the return line, and you're left with a basically dry housing.
Since the water jacket stays full, and water moves, its got its own cool down system.
Re: Turbo Set-up. Is this all i need to get started?
this is not true! i currently run a stock intake manifold with rsx injectors....do some searching or go out there and try to put them in yourself before you come and give false info
Buds302 I think he had 440's in there and the guy later came and edited it. Although I do know someone personally using 440's on a stock intake manifold. The Emanage over Hondata comment though is completely wrong lol.
ban AThompson, his information is RIDICULOUS...
also, if your gonna be running the rsx 310cc injectors, our stock pump can support it. You really dont need to upgrade to a walbro, but if you want to go right ahead...
and he wouldnt be the first to run hondata...search for andyman's thread...
He first had the rc 440 injectors on his list and i told him the only ones that fit with our intake manifold and rail is the rsx injectors. And the reason i stated to not use hondata was cuz when i wrote that it had just came out and no one, including andyman had used it yet. I am now in the process of saving for hondata after seeing it in action, i was just giving him a heads up, that at the time, which was the beginning of march, that he posted this, no one had used the kpro for our cars then. Sorry if i said anything wrong, but i dont feel that i had
Supramk3
May 8, 2015 11:16 AM
black2k1vtec
Dec 6, 2001 09:49 PM
