Auto to Manual
Old Nov 19, 2007
  #151
Civicman1988's Avatar
Re: Auto to Manual
Originally Posted by tfnaaf
actually i think its against the law everywhere to purposely vent freon into the air
your right on that
Old Nov 19, 2007
  #152
varner88's Avatar
...JeRsEy sTyLe...
varner88 is a glorious beacon of lightvarner88 is a glorious beacon of lightvarner88 is a glorious beacon of lightvarner88 is a glorious beacon of lightvarner88 is a glorious beacon of light
Re: Auto to Manual
its against the law if the law knows...
yea u can pull trnas out from bottom without removing motor.
Old Nov 19, 2007
  #153
spoonEM's Avatar
omgwtfbbq mod.
Re: Auto to Manual
Me and Bob (dopes6070) are doing this swap for another member this weekend. I will take a lot of pictures and there will be a detailed DIY on this once its done. Pull the motor out...its easy as hell and it makes it ALOT easier. Dont be afraid to do it. Just get in there and learn as you go. Sure, you may make a few mistakes, but thats how you learn. You dont need a K20 with a 6 speed to have some fun. Manual is WAY more fun than auto, and the parts are relatively cheap these days. Too bad youre so far away, otherwise I could do it for you. haha.
Old Nov 20, 2007
  #154
susuking's Avatar
susuking is on a distinguished road
Re: Auto to Manual
finally! I'll be keeping an eye on this soon to be release DIY!
Old Nov 20, 2007
  #155
LoneWolf's Avatar
LoneWolf is an unknown quantity at this point
Re: Auto to Manual
quick question...
what are the 2 sensors on the clutch pedal for???
Old Nov 21, 2007
  #156
Re: Auto to Manual
Originally Posted by JDMInspired
post progress pics please. are you changing your ecu and any part of the wiring harness? is the tranny mount thats spot welded to the chassis in the same location?
ya i am changing everything and right now i am not having any problems
Old Feb 15, 2008
  #157
jamesandrew58's Avatar
Super Member
jamesandrew58 is an unknown quantity at this point
Re: Auto to Manual
bump.
what size hole saw did you guys use when drilling the firewall for the clutch master cylinder
anyone have those pics. im gonna be picking up a donor car soon
anyone know where i can purchase a clutch alignment tool? ill be using the clutch coming off the donor car
Old Feb 15, 2008
  #158
Ellocodetroit's Avatar
The Declaration of Independence was written on marijuna paper
Ellocodetroit is a jewel in the roughEllocodetroit is a jewel in the roughEllocodetroit is a jewel in the rough
Re: Auto to Manual
Originally Posted by LoneWolf
quick question...
The top one is the starter cut relay(pressing in the clutch pedal to start the car) and the bottom is for the cruise control.
Old Feb 15, 2008
  #159
Super Member
Re: Auto to Manual
will this alignment tool work on the stock clutch
http://www.advancedclutch.com/142546...I_(D17A1).html
and do the flywheel bolts have 12point heads?
Old Feb 16, 2008
  #160
Super Member
Re: Auto to Manual
alright ive started on the swap.
can i use the ex engine harness on a lx motor?
i can still use my auto tranny ecu correct?
if i dont use the under dash harness what kind of wiring modifications would i have to do?
Old Feb 16, 2008
  #161
army12bc's Avatar
army12bc will become famous soon enough
Re: Auto to Manual
you have to use a manual ecu, as for the harness, i wouldn't use a different model's, dont know the difference. the under dash harness requires all kind of soldering and stuff because of the reverse lights and stuff from what i have researched. i'm starting my swap soon.
Old Feb 16, 2008
  #162
Super Member
Re: Auto to Manual
hmm someone said you dont have to use a manual ecu?
Old Feb 22, 2008
  #163
I<3JDM's Avatar
I<3JDM is an unknown quantity at this point
Re: Auto to Manual
i also heard that the manual ecu is not needed
Old Feb 23, 2008
  #164
Super Member
Re: Auto to Manual
i just finished my swap and yes i can confirm you don't need a manual ecu or manual engine harness. you just need to reconnect the black box from the auto trans and have it set on park for the car to start, and yes you will be able to go past 5500rpm. but by doing this you will throw a cel for the missing auto tranny sensors. also i haven't got the reverse lights to work. but i will be swapping in a manual engine harness along with the ecu and dash harness to make it a clean swap.
Old Feb 23, 2008
  #165
Willabee's Avatar
Willabee should not be trustedWillabee should not be trusted
Re: Auto to Manual
oh, i was planning on this aswell. glad to hear you got everything going well. so how much did this end up costing you?
Old Feb 23, 2008
  #166
Super Member
Re: Auto to Manual
600 for the donor car (03 civic ex)
100 for tow
100 bucks for fluids and food lol
Old Feb 23, 2008
  #167
I<3JDM's Avatar
Re: Auto to Manual
^nice!
Old Jul 26, 2009
  #168
subworm07's Avatar
subworm07 is an unknown quantity at this point
Re: Auto to Manual
sorry for bring back and old tread I did this swap and yesterday I changed the engine harness to the manual one as well as the ECU and the ignition because i got the key for the ECU. but now my car doesn't want to start I am still using the Auto Dash harness and found out I need to connect the Clutch Pedal I know I have to ground one but what do I do with the other wire please help.
Old Sep 25, 2009
  #169
ekfour's Avatar
ekfour is an unknown quantity at this point
Re: Auto to Manual
you just loop the two thicker black wires to the clutch pedal sensor! (the top sensor on the clutch pedal)
now i need help on wiring the car to PARK/ to remove the key... i also sent you a pm
Old Sep 25, 2009
  #170
subworm07's Avatar
Re: Auto to Manual
^ IM you back.
Old Nov 16, 2009
  #171
spoolinEM2's Avatar
spoolinEM2 is an unknown quantity at this point
Re: Auto to Manual
hi i was wondering if i just needed a manual motor mount or all of the engine motor mounts? and wat r some of the main bolts in need that i cant just re use from my auto crap?
Old Jul 3, 2012
  #172
Hensinger2010's Avatar
Meh...
Hensinger2010 will become famous soon enough
Re: Auto to Manual
very helpful
oneheadlight
Apr 29, 2015 11:30 PM
davidpaustin
Apr 29, 2015 02:23 PM
C6GrandSport
Apr 25, 2015 09:41 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
SugarRay
Jan 7, 2002 08:20 AM
