k20 automatic?
Old Sep 3, 2006
gmag21's Avatar
gmag21 will become famous soon enoughgmag21 will become famous soon enough
k20 automatic?
I have an 02 civic ex auto and i was woundering if it was possible to make a k20 auto. Or would it be easier to convert my car to manual instead and have a regular k20 swap?
Old Sep 3, 2006
RHCP0801's Avatar
convert it to manual
Old Sep 3, 2006
jamesandrew58's Avatar
Super Member
jamesandrew58 is an unknown quantity at this point
i wanna do a k20a3 from a base auto but i cant find info.. any1 else know beside converting?
Old Sep 3, 2006
jester444's Avatar
Dain Bramaged.
jester444 is an unknown quantity at this point
I've never heard of it done... Not to say it can't, but every K-swap I've seen has either been manual in the first place, or converted to manual.
Old Sep 3, 2006
maybe its never been done cause youre barely gonna gain 20hp
Old Sep 3, 2006
RHCP0801's Avatar
waste of money also
Old Sep 3, 2006
Super Member
if i did a manual conversion on a d17 i would need to get
shifer assembly, shifter lines, clutch/brake/gas pedals, clutch master cylinder, hardlines, and the actual tranny w/fly and clutch and new throwout bearing, ecu
do i need a new subframe also? is the top tranny mount located in the same area?
and for installation of the clucth pedal and mastercylinder
are the holes already making this a bolt on install or do i need to drill holes?
for the wiring harness, anything needed to be modified?
can the fly/clutch bolt onto the motor that was previously a automatic?
mahalos
Old Sep 3, 2006
TeamSF_em2's Avatar
Show and Go. N/A is BEST.
TeamSF_em2 will become famous soon enoughTeamSF_em2 will become famous soon enough
you will need to drill holes for the pedal assembly, there are are grooves in the uni-body that indicated where the pedal assembly is going to go. so it makes it a bit easier to do.
as for the master cylinder im not quite sure about that, but for the slave cylinder you will have to drill for that as well. im not sure if theres a groove for sure but most likely there is. all you have to do is drill and grind. its alot easier said than done.
i dont know about wiring harness, but if you dont use a manual ecu you have to so some cutting and splicing for the auto ecu to work correctly.
your manual tranny will bolt up fine to the egine including clutch and flywheel.
you can modify your subframe so that it supports the smaller manual tranny but if you dont know how to weld i would suggest getting the manual subframe.
Old Sep 3, 2006
BlackKnight008's Avatar
420 Member
BlackKnight008 has a spectacular aura aboutBlackKnight008 has a spectacular aura aboutBlackKnight008 has a spectacular aura about
if you do an auto k20 i will buy a plane ticket to where ever you live so that I can come to your house to bitch slap you
Old Sep 3, 2006
RHCP0801's Avatar
hahahahaha
Old Sep 3, 2006
SLO REX's Avatar
250+ awhp Stage 2
@ this thread
Old Sep 3, 2006
RHCP0801's Avatar
lets play what mod will close this
i say c2i0v0i1c or something like that or havok2k1
Old Sep 3, 2006
Curiouz_G's Avatar
Curiouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really nice
if your looking for more power, it would be easier to boost instead of a k20 auto swap. youd make more power with less money.
man what happened to s2kman?
Old Sep 3, 2006
RHCP0801's Avatar
yea he hasnt been here for a while, if he was it wouldve been closed by him as soon as it was posted
Old Sep 3, 2006
SLO REX's Avatar
250+ awhp Stage 2
I say one of these three civic01vtec, Havok2k1, C2i0v0i1C. (they are the only people who can close the threads in here )
Old Sep 3, 2006
jfan's Avatar
Try to help him out or just browse another thread.
Old Sep 3, 2006
Super Member
hmm look
http://www.7thgencivic.com/forums/sh...d.php?t=123114
was searching and i found out if ididnt misread the holes are already predrilled, just bolt on for the pedals/cylinder
Old Sep 4, 2006
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
Well I for one would like to see this done. If you did a turbo auto and the trans was sent out to be beefed up. Think of the consistent times you could have.
Old Sep 4, 2006
ya but think of all the $ you spend.
Old Sep 4, 2006
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
after seeing all these threads poping up....i'd like to see just one person or two do this....just to see
Old Sep 4, 2006
02fpcivic's Avatar
90% of all drag cars use some form of an automatic transmission, or clutchless sequencial transmission. Consistancy is no waste of money, it wins races more often than not. The stock k20 has proven to be durable enough to handle descent amounts of boost. I see great potential for a built turbo k20 bracket racer. If this dude wants to try an auto swap out, dont fault him for it. It may help some of us later on for a more serious build.
Old Sep 4, 2006
420 Member
ya right I bet he just doesnt want to drive manual
Old Sep 4, 2006
02fpcivic's Avatar
prolly, lol. I honestly cant stand driving an auto on the street.
Old Sep 4, 2006
Super Member
crap i want to drive stick.. i drive my friends integra/rsx/eclipses just so i dont forget how to haha.. and i make them drive my car.. they like my car since it handles so good
Tyler93
Mar 20, 2016 09:03 PM
danace99
Oct 17, 2015 02:51 PM
cferry7
Oct 3, 2015 04:33 PM
General DIY
Sep 25, 2015 08:02 PM
blizza
Sep 22, 2015 03:48 AM
