Tranny Dead!!! One Question!
Old Jun 15, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Unhappy Tranny Dead!!! One Question!
Ok my tranny is DEAD!
It no longer goes in to 3rd gear!
My question is, if I get an 04 (EX) tranny...
Is the "gearing any different on the 04" compared to my "old 02 EX tranny?"
The search button tells me NO! But I would like to hear that from some of the people who have an 04 tranny on their 02's.
Any difference AT ALL????
Well thanks;
Too any advice anyone can give me for this next endeavor I will be facing.
Old Jun 15, 2006
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
There is no difference but I'm pretty sure that they are made better. Still weak none the less but better than 01-02
Old Jun 15, 2006
02BLKCIVIC's Avatar
Ok stronger.
Ummm do you have any evidence to back this up?
Or are you just assuming that Honda got its act together in 03 & made the tranny "better" or "stronger."
I guess my point is do you think in 2003 Honda decided to make trannys different then they did in 2002??
any incite anyone??????
Old Jun 15, 2006
djmota's Avatar
yes better quality syncros in the 03-05 models.
Old Jun 16, 2006
02BLKCIVIC's Avatar
Thank you sir!!!^^^
Anyone?
Last edited by 02BLKCIVIC; Jun 16, 2006 at 02:11 PM. Reason: Automerged Doublepost
Old Jun 16, 2006
Kyle23's Avatar
Yea sorry.... I meant to say that they had better syncros but I couldn't think of the word. Hopefully this helps
Old Jun 16, 2006
02BLKCIVIC's Avatar
Syncrows check!
anything else??
Old Jun 16, 2006
01HonderCivic's Avatar
Don't be a n00b, search ftw
I do belive that gearing is the same from all the EX civics from 01-05. I know that the gearing is different from the DX/LX manual trannies compared to the EX. There are really two benefits to getting an 04 transmission - Better schyncros and it's most likely to have less miles on it then any 02 tranny you would be able to find. Maybe now would be a good time to get an aftermarket clutch as well
Old Jun 16, 2006
02BLKCIVIC's Avatar
LOL^ ya honder you know the whole story!
I found an 04 EX tranny for $450.
DHL will ship it to my house for $100.
But I wanted some in put from 7th gen!
Last edited by 02BLKCIVIC; Jun 16, 2006 at 05:14 PM. Reason: Automerged Doublepost
Old Jun 16, 2006
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
have u tried putting syncro mesh in there for now to at least see what happens.. i have had b-series trannys go bad and a little syncro mesh helped fix that tproblem..?? FYI
Old Jun 17, 2006
Tragedy's Avatar
skate or die
Damn, sorry that happend to you dude. On the bright side a new transmission is a very good thing.
Old Jun 17, 2006
02BLKCIVIC's Avatar
I do believe the syncros are fvcked to say the least.
Im just tired of this tid bit ****. If its not this its that.
So on & so forth.
Thanks for the heads up. I think im gona get the tranny & just keep in it in my garadge.
Im still driving the car. It still "somewhat" goes into gear.
Can I cause any more damadge to my car by driving it like this?
Thaks tragedy, I agree.
Old Jun 17, 2006
Yes, you can damage it more. If the schyncros wear down to the point where they break, that can spell the total end for your tranny. Little pieces of crap floating around in the oil is quite bad for the gears. If I were you, I'd try to avoid third all together
Old Jun 17, 2006
02BLKCIVIC's Avatar
Well **** I dont care if I heart my little tranny!
Im more worried about the engine or any other part...
Old Jun 17, 2006
Well if you wanted to be able to drive it until you got the new tranny you would take care of it
Old Jun 17, 2006
well.. if your still driving it.. hell just drain ur tranny fluid and put in some syncro mesh.. it will help it out a bit.. at least make it easier to drive... then if you can find one at ur local store put in a magnetic tranny drain plug... these are all cheap things you can do in like 30 minutes
Old Jun 18, 2006
02BLKCIVIC's Avatar
Thanks I will do that!^^^
Old Jun 21, 2006
02BLKCIVIC's Avatar
Will the 05 tranny will bolt up just like the 01,02,03,04??
I assume yes! I just want some reassurance.
Old Jun 21, 2006
Yess
May 4, 2016 07:14 AM
Kyle Cargazm
Jul 16, 2015 02:06 PM
NoobyKid
Jul 13, 2015 07:53 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
ZILLA
Jul 5, 2015 05:24 PM
