d17 turbo question....
Old Mar 29, 2006
filipinop1405's Avatar
filipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of light
hey ya'll i've searched and i remember seeing it on here before but can't find it anymore.... i have and lx and was wondering if i plan on boosting should i do the ex head swap for vtec? i can't remember what was said before. thanks... also in your personal opinion is it worth it to do a frankenstein swap and turbo it than just building the internals to a d17 and boosting it?? thanks for the info ya'll...
Old Mar 29, 2006
dezod's Avatar
7thgen Power Maker
Stick LX. VTEC & boost is great, but the LX heads can hold a bit more boost.....BUT all of the goodies like camshafts and such are for EX only...choice is yours.
Old Mar 29, 2006
BoostedVik's Avatar
BoostedVik is an unknown quantity at this point
that he said ^^^
listen to dezod
Old Mar 29, 2006
tuner04civic's Avatar
spell check pwns you
dezod knows his stuff
Old Mar 29, 2006
turboengnr's Avatar
DONT PANIC
i would put the money towards something else. Like an AEM EMS.
Old Mar 29, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
I wouldn't swap. It's extra expence without any significant gain for the turbo d17. Turbo stock LX d17 and leave building this for later (if neded). Just get a basic turbo kit with intercooler, rsx-s injectors and AEM ems or emanage, ~200whp with upgraded clutch and mild tune.
Old Mar 31, 2006
dezod, do you recommend me doing the lx to ex head swap or just putting in a ex??? if i do the ex head swap will the bottom end components fit on my lx... the components that you sell, i.e. pistons, connecting rods, etc. thanks
Old Mar 31, 2006
dezod's Avatar
7thgen Power Maker
It's up to you. Each way has it's own benefits and draw backs.
EX-
You get the benefit of the Crower Cam & valve train.
Crower Rods
Less boost unless you run our pistons (8.8:1)
LX-
Lower compression therefore more boost on pump gas
Rods should fit fine here too, but no one has proven it yet...
No cam use for j00
Valve train..........not sure if it will fit (should)
You already have an LX....I say boost that.
Old Mar 31, 2006
You can always upgrade to EX later on, no mods to existing turbo kit you will need to do.
Old Apr 2, 2006
se7engen_riDe's Avatar
se7engen_riDe is an unknown quantity at this point
well dezod says you can run more boost with an LX. i would just go ahead and boost your LX and forget about the EX.
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Donahue
Sep 8, 2015 09:00 AM
KAMIKAZEEx
Aug 30, 2015 08:30 AM
justcruzin125
Aug 11, 2015 09:09 PM
