Fuel rail not fitting with rsx injectors
Old Apr 2, 2006
joshb_'s Avatar
Boosted 04
joshb_ is just really nicejoshb_ is just really nicejoshb_ is just really nicejoshb_ is just really nice
as you can see the line is hitting the tb......Should i just bend the line or should it fit down in there?
It goes across the rail to evap...i think puge maybe???
I think it should be safe to bend becasue fuel doesnt go threw it....
Old Apr 2, 2006
it should fit without hitting the tb..
you sure you got them pushed in all the way?
Old Apr 2, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
did you put the injectors on the rail first then put them in? Or put them in the mani first? You do know that the fuel rail isnt going to go all the way down right? since rsx injectors are a little taller right?
Old Apr 2, 2006
tfnaaf's Avatar
BLDNPSI Mod
its a tight fit but it should clear
Old Apr 2, 2006
joshb_'s Avatar
Boosted 04
I bent it a bit and it went in fine...
ZeroDegreze
Jun 17, 2015 11:10 PM
rcolosi
Apr 29, 2015 07:48 PM
MooCoW
Nov 15, 2001 10:58 AM
