Quick E-Manage w/vtec question
Old Feb 25, 2006
ajhdragon's Avatar
7thgens official a$$hole
Right now im running a lx ecu with a d17a2 engine. I am useing a VAFCII to run the vtec high to low cam change. Wil lthe emanage do the same thing? From reading Dezod's huge emanage thread on the install on how to i got the impression it would. BTW I will be useing the Dezod pnp adapter with the Emanage if that makes a diffrence.
Old Feb 25, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
Yes, you can use the emanage to engage vtec. Order the EX Vtec PnP harness. you will have 2 wires for vtec, one is in one is out. The light blue "vtec out" wire is the one you will cut and splice into the vtec solenoid. (cut the wire before it gets to the PnP harness and hardwire it to the solenoid) the other wire pink "vtec in" can stay where it is because no power is gonna be sent through that wire anyway.
i hope that makes sense. from there you can adjust engagement point and all that good stuff. Your welcome.
Old Feb 26, 2006
Logan3024's Avatar
Are you getting that from anydymans DIY? If so he has the vtec in and vtec out wires reversed. Its should be YELLOW vtec out, LIGHT BLUE vtec input.
Ajhdragon, Make sure that you use 4-8-C as your rotary setting, Also make sure jumper 3 (vtec output) is set to 2-3. This works perfect on my EX engine with the non vtec ecu.
Old Feb 26, 2006
ajhdragon's Avatar
thanks guys i appreciate it.
Old Feb 26, 2006
hydroflare's Avatar
hydroflare is an unknown quantity at this point
the vtec on the emanage doesn't work on the 7th gen civics. i have used the diagrams provided by greddy and it will just give u a check engine light for vtec voltage error. if you look up the wiring diagrams for the 7th gen civic si and rsx, greddy does not show the vtec wiring diagram for it. it is possible that the new vtec designs are going off something similar to the economy vtecs and they are variable which is a problem for the emanage. i have already tried wiring it and going through the forums. it didnt work for me. if someone got it to work then they should upload the info and diagram.
and for dizzle who said to use rotary 4-8-c, that is a rotary settings for non vtec engines. having the rotary at 4-8-c will overwrite the jumper settings for vtec on the board and will set it as non-vtec.
Old Feb 27, 2006
XSRCivic's Avatar
He's not using a EX ecu, he's using a LX ecu on a vtec motor. 4-8-E is the proper setting for vtec engagment with the emanage. I'm pretty sure the wire you will need is the light blue "vtec out". It's been awhile since I did this. If that doesnt work, try the other wire (pink), thats how I found out.
Old Feb 28, 2006
ruffryde009's Avatar
ruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to all
I bought a PnP harness from Dezod recently... its actually scheduled to arrive today... He told me even with the right jumper settings 4-8-E, and the right wires you wont have vtec no more.
CraigW
Aug 18, 2015 07:06 AM
civic98?
Aug 13, 2015 01:32 AM
Strycker
Aug 2, 2015 08:40 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
NoobyKid
Jul 13, 2015 07:53 AM
