defective emanage? weird problems, need help.
Old Nov 26, 2006
  #31
BoostedVik's Avatar
BoostedVik is an unknown quantity at this point
if its on one block and time is till ticking , thats cuz its still loading, mine took 2 hours to load the firmware, better hook your laptop to charge so ur battery doesnt die!
Old Nov 27, 2006
  #32
DaRk_MauL's Avatar
DaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of light
but the interaction led isnt on let it run for more than a hal hour any their
wasnt any progress.
I was wondering is the software working correct in win Xp.the manual says
95-98 or 2000.
btw wen installing software why the hell does it ask for a serial.??
i also tried a radom combo and still instals..
Old Nov 27, 2006
  #33
dezod's Avatar
7thgen Power Maker
The serial to USB connector needs to be used.
Old Nov 27, 2006
  #34
dezod's Avatar
7thgen Power Maker
2 hours!!! It should take no more than 3-4 mins.
Old Nov 27, 2006
  #35
DaRk_MauL's Avatar
that what i was thinking.but i will try a usb connector.
I just dont understand zhy it start updating just with the
usb to serial cable and than stops.
Old Nov 27, 2006
  #36
dezod's Avatar
7thgen Power Maker
Hmmm. Check to make sure the port does not become inactive after some idle time or something like that..........
Old Nov 27, 2006
  #37
DaRk_MauL's Avatar
how do ya see if the port get inactive,because i got the emanage hookup to
a 12v power source nu my car wanted re erase the boosted map.
But the software keep saying online and the E is green, wen i disconect the
cable it goes ofline so that looks fine too.
Old Nov 28, 2006
  #38
BoostedVik's Avatar
well i used windows vista beta... so i dont know, but it took 2+ hours to load the firmware and then after that everything loads faster as far importing or exporting, and i was using belkin usb to serial so that might have something to do with it, but it work great
Old Nov 29, 2006
  #39
DaRk_MauL's Avatar
If you can update your firmware in vista it should go in every win normally.
I went to a guy at work today,he has a pc shop and wil order my a usb-serial
connector.That about the only thing i didnt try..... if its not working then ill
post pics up of my greddy demolition.
Old Nov 29, 2006
  #40
BoostedVik's Avatar
yeah everything works good, just got it tuned today!!!! good luck dude
Old Nov 30, 2006
  #41
DaRk_MauL's Avatar
Gonna go this weekend to a friend his shop he has installed the emange so
will be checking it there. lets hope
@boostedvic you got any dyno results? post them up.
Old Nov 30, 2006
  #42
BoostedVik's Avatar
yeah look at my sig
or this http://www.7thgencivic.com/forums/sh...d.php?t=284938
thana
Jun 15, 2020 07:05 PM
mrohitredd
18
May 14, 2015 07:35 PM
tylerginevan
Apr 27, 2015 12:29 PM
cdt12271
Apr 23, 2015 11:36 AM
Linda0818
Apr 23, 2015 11:30 AM
