video 18 psi - thought i would be nice and share
Old Nov 27, 2006
Myika's Avatar
Myika will become famous soon enoughMyika will become famous soon enough
please right click save as
Still running very rich. Needs more tuning.
2002 civic lx, vtec head, 18 psi on 60-1 stage V
http://www.controlledinertia.com/Por...1/PB270010.MOV
Old Nov 27, 2006
misterpho7's Avatar
misterpho7 is just really nicemisterpho7 is just really nicemisterpho7 is just really nicemisterpho7 is just really nicemisterpho7 is just really nice
Cool, got any numbers? Track,dyno, etc
Old Nov 27, 2006
Myika's Avatar
no numbers. Im too poor to afford a dyno.
Hopefully i will go to the track friday. Depends on if it rains or not.
Old Nov 28, 2006
filipinop1405's Avatar
filipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of light
sweet dude! nice vid... what do you think you make on the butt dyno?! hahaha oh and how fast is your 0-60 you think?
Old Nov 28, 2006
drunkenmagnum's Avatar
more info and stats please
Old Nov 28, 2006
Myika's Avatar
Engine/Performance Modifications:
MSD 45 GPH fuel pump
Mallory Fuel Pressure Regulator
4 Dodge Neon SRT4 Stage III injectors
4 Stock 02 civic injectors
Custom Fuel rail with #4 braided stainless fuel lines to each SRT injector
All XRP Aluminum Fittings
3/8" custom hard aluminum fuel feed line
Stock feed line converted to a return line
Turbonetics T3/60-1 ball bearing hybrid Turbo
ATP wastegate Stud kit
ATP wastegate blockoff plate
TiAL 50mm Blow off Valve
TiAL 44mm Wastegate (0.8 bar spring)
Custom 3" downpipe
Custom 2.5" aluminum intercooler piping
Greddy Emanage with Injector harness, Ignition harness, and greddy MAP sensor
Custom 2.5" exhaust with a 31" resonator and matrix muffler
ARP Head Studs
Ported vtec cylinder head
Custom Arias Pistons
Total Seal Gapless Rings
Crower Rods
modified stock crank
Darton Sleeves
Modified KMS D16 block guard
Honda Main Bearings
Clevite rod bearings
ARP rod bolts
Nippon Leakless Head Gasket
Custom D16 manifold (8 injectors)
Exedy Cerametallic sprung-hub 3-puck clutch
Exedy pressure plate
Custom short shifter
battery re-located to the rear
Suspension/Wheel Modifications:
Tokico Blue struts
H&R springs
Custom Front Strut brace
Custom Rear Strut brace
Old Nov 28, 2006
Michalo187's Avatar
Abortion Survivor
nice! Speedo just flies! Rep for you!
Old Nov 28, 2006
Myika's Avatar
it will go a lot faster when i finish tuning it.
10.0 is not the most performance-friendly a/f ratio........
Old Nov 28, 2006
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
nice vid....good luck with your tuning.....what do those srt injectors run? can you find them used?
Old Nov 28, 2006
sl33pyriceboi's Avatar
hey just wondering, what kinda guagues are those? (ur speedo/rpm/gas etc...)
are those that indo reverse glow ones on ebay?
Old Nov 28, 2006
Myika's Avatar
yea those are ebay ones.
I dont know what the injectors cost because i got 2 sets for free.
Old Nov 28, 2006
susuking's Avatar
susuking is on a distinguished road
sweet ride ... 18 psi? woh...
Old Nov 28, 2006
TRIZ's Avatar
niice... thats a lotta mods to the engine, rock on man.
Old Nov 28, 2006
Myika's Avatar
if it doesnt rain this friday, i will go to the track. I may turn the boost up to 21 psi.... depends on how i feel.
Old Nov 28, 2006
DUDEitsMATTx's Avatar
DUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura about
nice video, not what i expected but nice. i cant w8 till my car is finished then i can post some videos also
Old Nov 28, 2006
ronaldo9's Avatar
You have pretty much a fully built setup for turbo which I know wasn't cheap and no money for dyno time??? Nevertheless, sweet setup and have fun. Were you ripping it in the vid bc it seems traction is not an issue?
Old Nov 28, 2006
exturbo6's Avatar
nice vid man! can u take pics of ur car and take a vid during the day!
Old Nov 28, 2006
Myika's Avatar
with my wheels/tires/suspension setup, traction isnt an issue unless i powershift.
I NEVER powershift or speed shift because i have already broken several trannys. I have an extra in my garage but i havent fixed it yet. I am using my rebuilt LX one right now. My extra is an EX.
Also, it is running extremely rich. It makes this much power on 12-13 psi when its well tuned. I just need to spend some more time working on the tuning.
I was just happy because it was backfiring really badly once the boost came up to 16-18. I tried tuning timing and fuel to no avail. I swapped spark plugs and solved the problem.
I can probably gain 50-60 more whp by simply tuning it. I was just showing the vid because i know people think im full of ****. Now they have no basis for thinking that.
I will post another once its tuned. Ill do the vid from outside the car this next time.
And yes, i have no money. I built the entire turbo setup myself. I got all of my parts at a discounted price, and i did all the labor myself. This motor alone took all of my money. And with buying a house in the near future, my budget does not allow for dyno time. The dyno here in town is $100 for 3 pulls, which is outrageous. Next closest dyno is about 50 miles away
Old Nov 28, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
hi mike ;P
you should put the vid on youtube ..
Old Nov 28, 2006
Myika's Avatar
i just verified my email with youtube 3 times. Still wont let me upload a vid.....
Old Nov 28, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
nice!
Old Nov 28, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
http://www.youtube.com/watch?v=7xISRCC62vM
there u go buddy
[this vid is taking forever to load ... for no reason.]
Old Nov 28, 2006
Civicman1988's Avatar
nice man congrats
Old Nov 28, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
vid is now up [finally].... [check above post]
nice check engine light mike.
Old Nov 28, 2006
Myika's Avatar
lol, thank u derek!
The cel is from no 2nd O2 sensor
Old Nov 28, 2006
TheSmuggler's Avatar
Mike you crazy SOB
Old Nov 28, 2006
puidokas's Avatar
puidokas is an unknown quantity at this point
Nice ride.
Old Nov 28, 2006
Myika's Avatar
i forgot to say.... the vid was from about 10 to 115 mph.
Old Nov 28, 2006
SOAD's Avatar
SOAD is on a distinguished road
nice vid
Old Nov 28, 2006
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
next...a daytime vid...
but still pretty cool
