ignition
Old Jan 15, 2006
jacky599r's Avatar
jacky599r is an unknown quantity at this point
ignition
hi. im wondering if any1 of u has got problems advancing ignition timing for the 7th gens d series? ive got a CEL whenever i tune up the timing. what could have caused it?
Old Jan 15, 2006
skipbarber's Avatar
what are you using to tune?
Old Jan 15, 2006
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
It has electronic advance doesnt it? is it even adjustable?
Old Jan 15, 2006
tfnaaf's Avatar
BLDNPSI Mod
like skip said, what are you using to adjust it ? and what is the code its throwing ?
Old Jan 15, 2006
jacky599r's Avatar
using emanage..have not gotten the code. it just threw a cel wheneve i wanna advance it.
Old Jan 15, 2006
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
Its probably knocking, man. Honda has these cars pretty damn advanced in the first place. Part of being a ULEV car is due to the fact that they are so well tuned from the factory. Having the tune right on the money means a/f ratios and ignition timing is almost peaked with some tolerance for weather and fuel variances. If you are advancing the timing more than a couple degrees in cold or cool weather you are gunna get knock for sure. Random misfire codes will trip as well. My advice would to NOT advance the ignition timing at all. You may be able to get a few degrees out of it but then the weather may change and you are screwed. Remember, street tuning isnt max power tuning, its max SAFE tuning.
Old Jan 16, 2006
jacky599r's Avatar
knocking? but u guys have no problems what so ever right? got this tuner who says that th 7th gen has 4channel ignition and can only boost to 0.5 bar for a safe level. wtf?
Old Jan 16, 2006
jacky599r's Avatar
and im not in any kinda cold weather. its like 30s degree celcius back here. and im running on 98 octanes and sometimes 97. is there some sort of ignition and injector harness that u guys happen to run with the e manage?
Old Jan 16, 2006
02fpcivic's Avatar
I dont run emanage anymore but yeah, you need those harnesses. Im probably not running any more advance than factory. Under boosted conditions its less than factory. Where do you live?? I wanna go there if you can get 98 octane from the pump thats affordable to use every day. hehe
Old Jan 16, 2006
jacky599r's Avatar
hha.im like living in singapore. minimum standard will be 92,95 followed by 98 and some premiums will be 98 w additives. its like 1.617 per litre of 98 octane patrol. yeah...
so you decided to take the e manage out? damn. i need more help! im boosted with a lousy management and hell is my consumption high and im not getting the power that i deserve!
Old Jan 16, 2006
djmota's Avatar
your boosted? you should not be advancing the timing on a boosted engine. Its probably knocking.....not good.
Old Jan 16, 2006
02fpcivic's Avatar
Yeah I run the AEM now, much nicer. No bull to deal with, except for the purchase and tuning costs. Id rather pay 1,000,000 then deal with what I did with the E-manage. I would really frown on advancing the timing at all. I think you are getting knock.
Old Jan 17, 2006
jacky599r's Avatar
yeah im boosted. but just wanna find a reliable system to work with. looking at say 9-10 psi daily. my management only does fuel. dats y i want to get it sorted out asap. whats so bad abt the emanage on the 7th gens? any1 tried the ultimate. my intake mani and tb is pure stock. running 2.5 straight thru. any advise? wanna improve some low end before the boost.
Old Jan 17, 2006
tfnaaf's Avatar
BLDNPSI Mod
I've been running e-manage blue for almost a year with no problems, works great just like any other fuel managemant when tuned properly
Old Jan 17, 2006
civic01vtec's Avatar
Why are you advancing your timing ????
Old Jan 17, 2006
02fpcivic's Avatar
I had the E-manage blue with everything and the thing would always act up on me, I think it had a lot to do with running my big *** injectors though. Piggybacks have there limits and I was probably just exceeding them. Some people never have any problems with them though.
Old Jan 20, 2006
jacky599r's Avatar
hmm.sowhat do i need for the whole setup? e manage unit,fuel,ignitionharness, a boost sensor, wideband hooked to the exhuast pipings... anything else. running 10psidaily is ok right?
danace99
Oct 17, 2015 02:51 PM
Bruce2
Sep 27, 2015 08:45 PM
meicalnissyen
Sep 22, 2015 06:20 PM
Donahue
Sep 9, 2015 05:55 PM
