how fast is the em2 k20a3 swap??
Old Dec 8, 2005
  #61
C Orndorff's Avatar
Once boosted now i-VTEC
C Orndorff is an unknown quantity at this point
Originally Posted by Sick Cycle
ah, interesting...
I have an 02 ex coupe. I haven't weighed my car ... I don't think the track I went to had a weigh scale ... I've only been once though. I have a cf hood, light battery (12 pounds), nothing in the trunk (except the battery) and a cf trunk ... but I still have all my tar haha.
hmm ... well most k20a2's that I've seen have dyno'ed at 165 whp bone stock ... but that's not a big deal. just from what I've seen.
hmm ... I definitely need to learn how to drive better then. My best trap speed was 99.6 on my 14.3 run ... with a better launch (and me not spinning 1st and part of 2nd), I could've probably had a high 13. Despite my poor times, I've maintained a 98-99 mph trap speed. It was also 80 degrees that day ... but enough with the excuses.
my first run, I ran a 15.3@99 mph ... when I launched, my 1st gear popped out
but since that run, I've also added a dc race header and some wider profile tires that grip better. upgraded from 215/40/17 gy f1 gs-d3's to 225/45/17 michelin pilot sport 2's.
hopefully come january, I will break 13's with ease.
oh yeah ... what was your tire pressure?
EX's are about 100lbs more. you should get that thing weighed see where you are at.
Up here at 6000 ft i run low/mid 15's my 14.3 was near sea level. Everything aside that is a great trap speed. Try a run without the 17's. I run 15" 02-03 si wheels. right now i have shitty tires, with those i can peel out shifting from 1-2 with a little wheel spin 2-3 and chirp 3-4 all this with LSD
What did you have before you got the DC header?
Tire psi was about 20psi
Old Dec 8, 2005
  #62
Sick Cycle's Avatar
Sick Cycle is an unknown quantity at this point
I don't have any other rims that I can use ... but my 17's weigh 12.8 pounds, hopefully that evens out things at least a little bit.
I had a stock dc5-r header.
hmm ... 02-03 stock rims weigh 19.5 pounds ;P ... not very useful info, but interesting none the less.
Old Dec 8, 2005
  #63
C Orndorff's Avatar
What Brand of 17's?
Do you still have the R header?
Old Dec 8, 2005
  #64
Sick Cycle's Avatar
ssr comp's.
yeah I still have the R header ... two sets, actually.
Old Dec 8, 2005
  #65
C Orndorff's Avatar
ssr comp's.
Damn that’s almost as light as HX wheels @ 11.75lbs. Si’s can't be that much, At least when I take them off the car they feel fairly light. I’m getting new tires next week so I will weigh them when I do.
You in the market to sell a set? If so PM me a price.
Old Dec 8, 2005
  #66
Sick Cycle's Avatar
yes. ssr's are one of the lightest rims out there.
15x7's weigh 9.2 pounds
yes, if you check around ephatch.com, you'll find out that the 15x6 02-03 stock rims weigh 19.5 pounds.
Old Dec 8, 2005
  #67
C Orndorff's Avatar
I talking about selling a Type-R header set not wheels if thats what you thought.
Old Dec 8, 2005
  #68
Sick Cycle's Avatar
nah I know. I pm'ed you about that.
Old Dec 8, 2005
  #69
kasimmmmm's Avatar
in case anyone is wondering about a k24a2 swap... i found this. 1/4 mile @ 13.820
http://forums.clubrsx.com/showthread...ighlight=k20a2
Old Dec 9, 2005
  #70
TemjinX2's Avatar
yeah if you wanna drag you want 15''s. Not only because there lighter, but you can make more revolutions per sec on a 15'' wheel then 17's just because the diameter is a lot smaller. More revolutions per min = better acceleration. 17's are better if your going around a track because of the wider rim and tire equals better grip around a track.
just buy some cheap steelies for like $60 and put some good tires on them.
Old Dec 9, 2005
  #71
HondaLuver's Avatar
Its a celebration bitches!
yea... LOOK If i had lsd and better traction, i could have had a mid 13.. bleh...
Old Dec 9, 2005
  #72
acidbaby's Avatar
The Beez Kneez
Originally Posted by HondaLuver
and i need LSD!
oooh i want some LSD too!
Old Dec 9, 2005
  #73
kornsined's Avatar
ahhh my car will be going into the shop soon. I'm getting pumped!
Old Dec 12, 2005
  #74
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
Originally Posted by 02cvcEX
i've been fkn searching for it and couldnt find crap
does anybody with the swap have time slips?? if so, list all mods if possible..and the time slip!
i found xproductionz's whack k20 (haha) swap dyno. max hp/tq @ 201/163 respectively i'm just wondering what everybody is getting on the track.
whack.. haha.. funny.. i dont think its so bad considering i made that with only intake headers and exhaust
Old Dec 12, 2005
  #75
02cvcEX's Avatar
02cvcEX will become famous soon enough02cvcEX will become famous soon enough
^^seriously though, have you figured out what kind of k20 you're using?
i only read some of your articles, and it seems like you have a whack-o k20 hybrid (not the gas/electric hybrid)
Old Dec 12, 2005
  #76
its actually a JDM type S... yes you read correctly... they have 2 types of JDM k20a in japan.. a type R and a type S..... the JDM type S is somewhere inbetween the US civic si and the US rsx type s in terms of power...
Old Dec 12, 2005
  #77
Sick Cycle's Avatar
actually the jdm type s is equivalent to a k20a3.
it's 160 ps, exactly like the usdm k20a3.
if you compare specs with the jdm version and the usdm version, you will see that they both make exactly the same hp and torque figures at the exact same rpm. This jdm K20A "type S" version is not "somewhere inbetween us rsx-s and us civic si" ... it IS a base rsx motor. Gear ratios also remain the same.
This would not apply if you received a jdm "type s" motor. the jdm base model rsx is labeled "Type S", unlike the usdm.
I'm not sure what kind of motor you have in your car ... it is very, very strange indeed. But I do know for certain that you do not have a jdm dc5-r or jdm cl7-r.
what is stamped on your intake manifold? prc or prb? ... what code is stamped on your transmission? y2m3? x2m5? w2m5?
Old Dec 12, 2005
  #78
Nick's Avatar
Formerly 2blu
This is kind of off topic, but. Why not get a k24 from an accord/element, over the k20a3. I found some for aolt cheaper than a3's, They have the same 160 hp plus they have ~30 more ft/lbs of torque.
Old Dec 12, 2005
  #79
the entire motor is labeled with the code PNA.... and the intake manifold pictured in these are no longer on the car...the block and everything else has a k20a stamped on it... right now i have a 6 speed in there... and when i first got the motor it was taken to acura and a local tuner shop and the compression was determined to be at 11.5:1.. or i think it was more like 11.4??:1...i forgot what it was but had a whole discussion on it....to make things easier read this
http://forums.clubrsx.com/showthread...5&page=1&pp=25
here is why i say IN BETWEEN the SI and the TYPE S
the si has no vtec lobes on any of the intake or exhaust cams.....
the type s has vtec lobes on bothe the intake and exhaust cams....
my motor has it only on the intake side....
Old Dec 12, 2005
  #80
Sick Cycle's Avatar
yeah, I did read your whole thread a while back ... I agree with Glimpse, it has to be a honda stream motor. The PNA code doesn't match any other prominent honda motor ... prc, rbc, etc. it can't be a euro ctr motor ... they do have 3 lobes on the intake and exhaust.
do you know what the code is on your tranny?
did you ever post the compression test volumes?
Old Dec 12, 2005
  #81
well i lost the sheet for the actual numbers cause it was so while back.. but the tests showed it to be around the 11.4-11.5 range compression.. something like that... well the tranny i had with it originally wasnt the original... cause it originally came with a 6 speed but i asked for a 5 speed cause i was gonna go turbo... so now i changed my mine again and have a 6 speed again.. but its a rsx type s one though.... if you look in the issue of import tuner they do have my motor listed as the jdm type s... they have all the k20 motor specs listed and there was only one on that list with 3 intake lobes and one exhaust... and that was the jdm k20a type s... if anything i am at work now but i will scan that section of import tuner for you guys to see what i am talking about
Old Dec 12, 2005
  #82
but then again the head dont matter to me much anyways.. i have a type s at the machine shop being p&p and putting in some new cams springs retainers and stage 2 cams
Old Dec 13, 2005
  #83
TheSmuggler's Avatar
Just my 2 cents...
160 ps is not the same thing as 160 hp lol, it's actually going to be a little bit more.
Old Dec 13, 2005
  #84
Sick Cycle's Avatar
^ actually a little bit less.
Old Dec 14, 2005
  #85
Hahaha its a little one way or another!!!
Old Dec 14, 2005
  #86
where the hell did PS and HP come out of this whole thing???
Old Dec 29, 2005
  #87
1SiK CIviC's Avatar
1SiK CIviC is an unknown quantity at this point
well a buddy of mine ALL MOTOR EM2 from here and thecivicforums.com and k-series.com has a k20a3 in an EM2.. he likes it.. and i got a k20a in my EM2 n i love it.. judgin by what cars ive ran on the street id say its a mid-high 13 sec car..
OldschoolCool
Aug 17, 2015 05:05 PM
JetsterDajet
Aug 15, 2015 08:07 AM
Kyle Cargazm
Jul 16, 2015 02:06 PM
