AT --> MT swap
Old Oct 28, 2005
zach_04LX's Avatar
zach_04LX is an unknown quantity at this point
AT --> MT swap
Alright,
I've searched and searched and I can't find this information on the forum. I need to switch my transmission to a manual, and I need to know a couple things.
Does anyone have a list of ALL the parts that are needed and a possible place to buy them?
As my username says, I have an 04LX coupe. The auto tranny just isn't working for me, and I wish I would have bought a MT, but I didn't. Now I have too much money invested in the car to buy a manual and scrap this one.
I've been trying to find out exactly what is needed and where I can buy the parts. Thanks a lot.
Zach
Old Oct 28, 2005
leonhsieh's Avatar
leonhsieh is an unknown quantity at this point
Tranny
ECU(auto ecu will work fine, but you will get CEL)
Axels
Tranny Mounts
Clutch hardline and softline
subframe
Engine wire harness
Dash wire harness
Pedals
Clutch
Flywheel
master cylinder
slave cylinder
starter
shiflt linkage
shifter assembly
Shift ****
Old Oct 28, 2005
White0nGold's Avatar
White0nGold has a spectacular aura aboutWhite0nGold has a spectacular aura about
look through my member page, and go under find all threads, i made a forum about the exact question, check it out, i decided to just go A/T turbo
Old Oct 28, 2005
mrDFWmechanic's Avatar
save up for a K20 swap and do your at - mt swap then 2 birds with one stone
Old Oct 28, 2005
eye_see_you's Avatar
let the devil out
build your auto tranny , I did and its even funnier when my built TCI auto built tranny and 12 psi boosts hands them there own
Old Oct 28, 2005
zach_04LX's Avatar
So would it just be better to get these two things and call it a day:
http://www.levelten.com/store/import...shiftronic.htm
http://www.levelten.com/store/import...cord_civic.htm
The shiftronic and PTS TORQUE CONVERTER SERVICE STALL 3200-3400?
So that would be a total of about $1000. Is that all I would need?
Old Oct 28, 2005
Does Any1 Have A Pic Of That ^?
Old Oct 28, 2005
let the devil out
Level ten is nice but I had my tranny rebuilt using the TCI auto master overhaul kit and the torque converter plus stage 2 cv half shafts from Drive Shaft shop. that was 1700 for eveything plus labor etc... and me running 12 psi with the TSI T25bb kit
Old Oct 29, 2005
zach_04LX's Avatar
I really want to be able to shift it though, and not have it do it for me. I hate when my AT chooses to shift. When I'm in first, it thinks that 5200 rpm is the point at which it should go to second. That is just not cool; I just start getting true boost there. That's why I thought about either an AT --> MT swap or the shiftronic from LVL10.
Old Oct 29, 2005
let the devil out
not true because my tranny was built with the TCI kit and all it shifts faster than most people can a manual under hard boost. I've handed a RSX-s his *** in a auto so a tiptronic controller is not always needed
Old Oct 29, 2005
Supermanrider's Avatar
I dont know what im talking about
Supermanrider is an unknown quantity at this point
Mine will let me red line and i have an 04 ex coupe auto if i floor it, but if i dont floor it will shift as low as 2500 in the first couple of gears
so maybe ur not pushing the peddal down all the way or maybe something is stuck behind the pedal so u cant pust it down
Old Oct 29, 2005
Havok2k1's Avatar
Wicked Pissah Admin
I hate when you guys don't search for this stuff and I have to. It makes baby jesus cry.
http://www.7thgencivic.com/forums/sh...auto+to+manual
This one has three MORE threads that I posted within it...
You get my point. The parts lists are out there.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Scout1
Oct 5, 2015 01:33 PM
juicetayne
Sep 30, 2015 11:02 AM
ThatGuy913
Sep 28, 2015 05:35 PM
ttamrekab
Sep 28, 2015 01:22 AM
