I think I'm running lean
Old Oct 10, 2005
zach_04LX's Avatar
zach_04LX is an unknown quantity at this point
Hi everyone,
My turbo has been in for a while now and seems to be running nicely. However, my Apex'i EGT gauge shows that during full throttle I hit about 800 C. Is that too hot? If so, does that mean I'm running lean? And finally, what can I do to fix it if right now I'm broke and can't afford DYNO?
Thanks in advance,
Zach
Old Oct 10, 2005
zach_04LX's Avatar
Oh, forgot to mention, I'm currently running 7psi on the stock engine. Is it possible to run 8psi and still keep my car for a LONG TIME?
Old Oct 11, 2005
exturbo6's Avatar
Fix your problem before running more boost. Your car could last a long time if you take care of it. Dont beat the crap out of it all the time.
Old Oct 11, 2005
iamboo's Avatar
Retired - SoCal FI Mod
first thing.... keep the boost setting but don't hit full boost when you're driving...
what kind of fuel setup are you running on the car?
get yourself an air/fuel guage or a wideband air fuel if possible
do you hear your car detonating/knocking? it sounds like static coming from the engine.. you should be able to hear it in your car...
Old Oct 11, 2005
zach_04LX's Avatar
I don't hear anything bad coming from the engine at all. The only reason I was asking was because my EGT was at around 800C at full throttle, and that seemed a little high. I know that everything can handle up to 870C without problem, and thus I have my warning indicator at 840C, but I thought 800C was a little high. I have no problems except for the EGT being at 800C.
Old Oct 11, 2005
ritalin's Avatar
ritalin has a little shameless behaviour in the past
Hook up a wideband and find out. Also how many cc/min are stock 7th gen injectors? Its not a problem with boost levels. Besides possibly running too lean its a power problem. Is it tuned at all?
Old Oct 11, 2005
civic01vtec's Avatar
Where do you have the sensor installed at ????
Where do you live, is it hot out and does the EGT temp get hot only after you have been driving for a long time or does it early ???
A EGT gauge isn't a good indicator of detonation. You are better off using a wideband.
Old Oct 11, 2005
eye_see_you's Avatar
let the devil out
yes you can run more i'm running 12 psi on my stock engine with my auto tranny that was built byt tci auto
Old Oct 12, 2005
ritalin's Avatar
Speaking of widebands I highly recommend an Innovative. I had one until I either lost it or it got stolen. Pretty cheap too.
Old Oct 12, 2005
zach_04LX's Avatar
Where can I get an Innovative Wideband?
Old Oct 12, 2005
tfnaaf's Avatar
BLDNPSI Mod
Here is a real good deal, i bought my plx m-500 from Streetrays
Old Oct 12, 2005
HondaLuver's Avatar
Its a celebration bitches!
get a tune, it can be as much as 50 hp that you could be losing
themechanic
Lighting
Feb 2, 2018 09:23 PM
Blazz
May 25, 2015 10:56 PM
JoeB16
61
Oct 16, 2003 07:58 PM
vietnam
Detailing
Feb 19, 2002 09:34 PM
ripper
Bolt-on Engine Performance
Jan 28, 2002 01:34 PM
