Whats more accurate?
Old Oct 2, 2005
Michalo187's Avatar
Abortion Survivor
I was wondering what reads the boost more accurate? I have a greddy e-01 that says i go up to like 8.7 psi and then my boost gauge says that i only run 5. I don't know which one is right could you guys please let me know what you think is happening and what i can do to fix it?
Old Oct 2, 2005
C2i0v0i1C's Avatar
SuperMODrizd
electronic guages should read better, mechanical ones allow for leaks
Old Oct 2, 2005
diskreet's Avatar
who makes your boost gauge? greddy is usually as accurate as they get. greddy's gauges are second to none. Im assuming the e-01 would not be built to any lower of standards in getting data.
Old Oct 2, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Could your gauges read boost in different places, and the boost level is uneven where you see differences in psi???
Old Oct 2, 2005
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
also depends where the tap for the boost gauge and the e-01 is connected... you will get different readings if one is off the turbo housing and if one is tapped on the manifold.. the one tapped of the turbo gives you what its putting out near the turbo and the one tapped into the manifold will give you what is actually going into the manifold
Old Oct 2, 2005
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
Did you install that little metal filter in the "T" provided with the E0-1 pressure sensor? I'm not sure if that would cause a problem but it's an idea. Also, maybe one of the lines to one of your gauges is kinked. There is also the chance that you are taking the signals from 2 different places and that is causing the problem (a difference of 3.7 psi seems high for this, though). Finally, the other gauge you're using may be junk.
Old Oct 2, 2005
Michalo187's Avatar
Abortion Survivor
one is autometer prolite the other is greddy. They are tapped into the same place i think maybe the autometer line is kinked. Another thing is the greddy one is reading and then when i let off the gas it jumps up to the boost and it flashes three times but its weird how fast it jumps when i let off the gas
Old Oct 2, 2005
diskreet's Avatar
well if your blow off valve sucks than you will get a large surge of pressure onto the throttle body, when you close it (let off the gas), untill your BOV releases the pressure and relieves the strain on the turbo system.
Old Oct 2, 2005
Michalo187's Avatar
Abortion Survivor
My bov is the stock sf one. So you then when i close my tb the pressure is then being read by the e-01 so that makes the boost suddenly go from 5 to 8.9 and higher while my autometer reads 5? How should i have my bov soft or hard?
Old Oct 4, 2005
DelSolid's Avatar
DelSolid is an unknown quantity at this point
what do they read when the car is turned off?
Old Oct 4, 2005
Michalo187's Avatar
Abortion Survivor
the autometer doesn't move the greddy reads -.1
Old Oct 4, 2005
DelSolid's Avatar
hmmmmm,
I think one of them is fvcked up. The question is: which one?
Just call me "Master of the Obvious"!
Old Oct 4, 2005
Michalo187's Avatar
Abortion Survivor
Well look the remote to the e-01 is screwed up so maybe the e-01 is. Also when i dynoed my car i had 160 whp at 10 psi which i thought was dam low for what i was running. The autometer said i was running 5 psi and the emanage would jump. My car feels fast but not that fast to be running 10psi and compared to everyones numbers i was expecting over 200whp
IronFist
30
Nov 27, 2003 01:01 PM
RunawaySoul
Apr 16, 2003 10:25 PM
tuxedocivic
Feb 5, 2003 01:20 AM
Grey
Feb 4, 2003 03:37 PM
Numinous001
Jul 17, 2002 11:07 PM
