DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
Old Oct 3, 2005
  #31
TheSmuggler's Avatar
Ah, so since you have the type-s one, yiu could just purchase their US package, which includes the RH and Type-R swaybar. I guess my question should have been would the type-r bar fit, lol.
Old Oct 3, 2005
  #32
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
lol.... our stock d17 sway bar fits if you wanted too.. lol.. but wont clear the headers. but yea.. i have tried a BASE.. and a type S sway bar and since the type R is similar it should fit cause i have read others who have had it on there swaps
Old Oct 3, 2005
  #33
Yeah, it's just these little nit picky things I want to get figured out. I appreciate you helping me.
Old Nov 15, 2005
  #34
AirLex-R's Avatar
AirLex-R is an unknown quantity at this point
xproductionz: did u swap the DC5 dashboard into ur car? or ur using ur stock civic dashboard? how do u go about connecting the air cond wire n etc...
Old Nov 17, 2005
  #35
Veracious's Avatar
Reflector Collector
Veracious is an unknown quantity at this point
do u think a k20a2 complete swap incudling EVERY nut bolt screw needed to do the swap into a 01 civic ex is worth 5,000 dollars? when i say everything.. i mean everything as in everything on this page http://hasport.com/News/Articles/ESK1parts.htm .. subframe axles mounts shifter assembly cables etc... its a 03 with 28,000 miles.. no problems with it at all.. just wonderin if its worth it.. thx
Old Nov 24, 2005
  #36
its worth it.. look at importracer.. hondaluver.. and so forth.. especially if you wanna go more than you could with a D17 in your car... with your stock motor your limited to turbo... but with the swap you can go even further... but its all a matter of preference and how af you wanna go and how much can you afford to spend... once you answer these questions then you can see a better picture
Old Nov 24, 2005
  #37
ImportRacer2123's Avatar
K20 Member
yeah he is right... Im soo happy I did a swap.. I used to have a shitty little d17 automatic... Now i have a Strong K20.
Old Nov 24, 2005
  #38
EM2typeflex's Avatar
EM2typeflex is an unknown quantity at this point
^^I got something else strong for you. j/k mane you know I like to follow your posts around and rag on you. I'm really proud to say my boy up in Oregon did a k swap himself. props
Old Nov 25, 2005
  #39
doubledeuce2k2's Avatar
same boat, same feelings. there are 3 turbo d17s that i know of in my state, and 2 are down right now...
Old Nov 27, 2005
  #40
Havok2k1's Avatar
Wicked Pissah Admin
FULL CREDIT TO XPRODUCTIONZ VIA
http://www.xproductionz.com/k20swap/k20swap.html
I am posting this just in case the page gets lost in the future.
DIY: K20 Swap into 2001+ Civic(EM2)
by: michael domingoes of www.xproductionz.com. Check it out especially my forums.Even my game arcade
If you look around especially on Hasport.com you will see a long list of things you need to do the swap into your car. For some of you that have already done it you know that you will not need all the parts listed. Here is a run down in general
Parts needed:
Complete k20 motor changeover
intermediate shaft
O2sensor for the same type of motor
subframe from a rsx or 02+si
Hasport Mount Kit.. (other companies make em to)
Hasport Wire Harness Conversion (I wont be using this, i will attpemt to wire it myself)
Parts needed from an RSX:
shifter cables
headers and downpipe
throttle cable (you can use a 92-95 single cam civic cable, much cheaper and easier to find)
clutch lines from master to slave cylinder
high pressure power steering hose
power steering return line
Parts needed from an 02+ civic si:
ac line from compressor to condenser (if you want ac)
axles
radiator and fans (RSX will fit but need trimming, not very much i might add)
upper and lower radiator hoses
Other stuff you will need:
custom ac line from compressor to condensor (again if you want ac)
92-95 power steering resevoir with bracket (they do sell aftermarket ones which work just as good, especially if you want looks too)
Parts they say you need but dont need to get:
rsx shifter assembly (your stock one works fine)
fuel line
brake booster line
purge line
90 accord negative battery
custom hood latch
Another thing i want to add is this.. Make sure you get the correct o2 sensor for the type of motor you get. Yes the o2 sensor from the k20a3 and the k20a2 is different. I have proven this by buying both and trying it. The k20a2 and k20a use the same/similar o2 sensor and will work.
Another thing you might want to consider is getting K-pro before doing the swap. K-pro allows you to disable the immobolizer which saves you time and money on getting the car towed to the dealer to get the ecu reflashed. One thing i learned in my area is that the acura dealer near my house doesnt do reflash on the ecu but the one clear across town does. And in no way was i going to tow my car that far plus they were charging an arm and a leg not only for the tow but for the reflash itself. The k-pro also allows you to disable the secondary o2 sensor which isnt wired into the harness. If you are wiring the harness yourself then i recommend getting this.
If you are not planning on getting the k-pro then i recommend you get one of the plug-n-play harnesses from either hasport or hybrid-racing. Make sure you tell them to wire in the secondary o2 sensor in for you.
Again if your not planning on getting the k-pro your car will have to be towed to acura to get the ecu and immobolizer and key reflashed to make it work. Unless you get a k20a JDM motor with the JDM ecu. Then there is a way for you to bypass the immobolizer.
Just to prove a point. A K20 Motor with a dual intake runner WILL.. and i repeat WILL fit in a 2001 civic.. but its a pain in the *** to put in
My 2 friends helping me out with the swap
REMOVING THE ENGINE
First thing you might want to do is pull out the your D17 motor out of your car. (alot of rags and brake/carb cleaner will help out alot at this point. The brake/carb cleaner comes in handy on cleaning up oil spills and cleaning the engine bay and parts etc.)
Jack up the front end of the car and take off the tires.
Drain you tranny fluid by removing the bolt on the side that looks like you have to use a square tool to fit in there. Basically a 3/8 ratchet will fit in there. After that pull out your axles very carefully as to not pull the shaft from the cup. You might need to use a really big screw driver to help leverage it out.
If you want to you can drain the oil at this time to help lighten the motor but not neseccary. Also while your at it be careful on pulling out the power steering resevoir cause you dont want to get the fluid all over the place. Then drain the radiator using the small white looking valve thing at the bottom of the radiator
Disconnect all hoses, lines, cables, battery, and wires from you motor. Take out the battery. Then take out the radiator by removing the brackets from the top of it.
Somehow your going to have to find a way to discharge you a/c system. It is illegal to discharge the freon into the air. But if you do then just stick something into the charging ports to release the air from the a/c. (PLEASE NOTE that this is illegal and you take responsibility for your own action. Do not breathe the discharge and make sure you are out in a well ventilated area.) Disconnect the a/c lines and move off an excess line to the side.
Now take off the lower control arms from the subframe and not from the hub. This helps alleviate on step from taking it on and off the hub down the line.
Go into the glove compartment area and open it up by removing the 2 clips found inside of the glove box. This should expose the inner areas of the car. Inside there you will see you ecu and and wire harness. Remove the clips from ecu and you will need a long ratchet extension to get to the back bolts to pull out the ecu. Once the ecu is out yank out the wire harness from the engine bay area. Pull out the complete harness and put it off to the side.
Before continuing make sure there is NOTHING left connected to the motor except the mounts cause you dont want anything to be yanked out while pulling the motor out. Also i forgot to mention that make sure you have taken out you intake, headers, and part of your exhaust till its not in the way of the subframe
IF PULLING MOTOR FROM THE TOP:
Remove the front and rear motor mounts. Attach the lift to the motor with the chains with one point to the far left of the tranny as close to the mount as possible and the other to the far right as possible. ( i do suggest you have someone with you that has had experience using one of these, if not theres always a first time for everything.) Jack up the lift a little till you have some support from the lift. Then go ahead and remove the driver and passenger mounts. Then slowly lift the motor out while continously checking to make sure nothings connnected.
IF YOU HAVE A CAR LIFT DROPPING MOTOR FROM BOTTOM:
Remove the driver and passenger mounts and leave the front and rear mounts Using the engine lift connect the chain to the same points as described above and give the motor some support. Now take off the 4 bolts holding the subframe from under the car. Lower the engine lift to the ground. The whole motor along with the subframe should go straight to the ground. Disconnect the engine lift and then Lift the entire car up on the car lift and preston... Theres your motor out plain and simple
Here is a pic of my car when everything was finally pulled out
Now if you pulled the motor from the top. Jack the car back up so you have enough space to pull out the subframe. There are 4 bolts holding up your subframe. Take those 4 bolts out and the whole thing will drop.
After your motor is out. take the coolant sensor from the D17 and switch it with the K20 sensor. The sensor on the k20 can be found here on the right hand side of the head (tranny side of the motor) right behind this black piece of plastic
Lift up this plastic and it will reveal the radiator coolant temp sensor
WIRING THE ENGINE HARNESS
Next lets do the wireharness. If you bought a wireharness from hasport or hybrid-racing then perform there operations on prepping and install of there harness and skip this step and go onto the next section. If not read on.
First off lets start with the C101 Clip. Here is a picture courtesy of Dark2K1 from 7thgencivic.com. If you dont know what the C101 clip looks like its the really big clip that goes along with the rest of the clips that connect to the ecu. There is also a picture of it on the top-left of the image below. If you can follow the diagram below then you know what to do. If not let me try to guide you through it.
Okay here we go. I have learned from looking at my different harnesses that not all the colors may be the same. In my rsx harness it did look the same but in my jdm harnes the colors where different BUT.. and a big BUT.. even though the colors may be different it still had the same function. This works for all k20 harnesses (si, rsx, jdm) and hasnt been proven with the k24 harnesses yet
To the left of you is what the K20 harness clip looks like. To the right of you is how the civic one is wired up. Basically we have to make the k20 harness look like the civic one with 1 exception. The primary o2 will not be wired in..YET...
So take the rsx clip and look at it from behind where the wires come out. Starting from the top left is pin 1. Refer to the diagram above to help you along.
move clip 1 into 4
move clip 2 into 5
move clip 3 into 6
leave clip 7 as is
leave clip 8 as is
move clip 9 into 17
take clip 10 - cut this wire off and label it with a piece of tape saying clip #10
leave clip 11 and 12 as is
take clip 13 - cut this wire off and label it with a piece of tape #13
move clip 14 into 19
take clip 15 - cut this wire off and label it with a piece of tape #15
leave clip16 as is
move clip 17 into 9
leave clip 18 as is
take clip 19 - cut this wire off and label it with a piece of tape #19
leave clip 20 as is
I dont have the part number for the relay yet but i will have it up shortly and the rest of the diagram to wire the relay
Okay now the fun part of wiring the primary o2 sensor. You will need a relay to make this completely work or else you will throw a code saying heater relay malfunction. If not there is a way around it but you might burn out the o2 sensor. If you have kpro you can disable the heater part.
If you look on your o2 sensor there are 4 wires. 2 black, 1 white and 1 green. Take the o2 clip and hold it in front of you so it looks like this. If you want to do what i did and take a black permanent pen and mark on the side of the clip the numbers so you dont get confused. Make sure you dont get the 2 blacks mixed up cause when i tried reversing it, it didnt work anymore.
white 2
green
black 4
black
So now that you know about the o2 sensor wiring...Lets continue shall we .. On the left hand side of the diagram below is the color of the wires and clip #'s that we originally worked on from clip C101. On the right hand side is the wires and pin # from the o2 sensor. So just gotta match it up.
Clip 10 (black/white) -------------> Pin 4 (black) of the o2 sensor
Clip 19 (red) ------------------------> Pin 1 (white) of the o2 sensor
Clip 13 (red/yellow) --------------> Pin 2 (green) of the o2 sensor
Clip 15 (white) ---------------------> Pin 3 (black) of the o2 sensor
***12v relay-----> Pin 3 (black) of the o2 sensor
****Basically you take the 12v relay wire and combine it with clip 15 (white) and it goes into Pin 3 of the o2 sensor
I will have the wiring of the 12v relay up shortly. Theres a total of 4 wires to wire on the relay.
PREPPING THE ENGINE BAY
Okay now lets get the engine bay prepped a little. Some of you that want a nice looking engine bay now is the time to go to the store and pick u p some black glossy paint and paint the engine bay. If not then lets get moving.
After the wire harness is done. Take the ecu side of the harness and feed it through the hole in the firewall where the old wire harness went. Now if you look at the ecu. See the tabs that stick out on the left and right side of the ecu. I had to cut mines off with a dremel to make them fit in the slot where my original ecu is. Dont know if anyone else did that but thats what i came across. Dont connect the ecu to the harness yet.
Take your power steering line. It should look like half of it is a rubber hose and the other half of it is a metal line. The metal end of the hose screws right in to the stock location of where the original one was. You might have to bend the hose a little bit to get it to fit. Even the wire that connects to it will reach with a little effort. Just cut the plastic wire loom to help extend it.
Now look for the fuel line and purge line that is sticking out of the firewall area. It should look something like this (picture taken from hasport manual)
You have to gently bend the lines so that way it bends with the right line facing to the right and the left line is pointing towards the front of the engine bay. Now if you want to label these lines the left is the FUEL and the right one with the bend is the PURGE which hooks up to a vacuum on the manifold. Make sure you make no kinks in these lines or else you have to replace it somehow someway.
Now lets first start off with the left side bracket (passneger side). This is what was included with the hasport mounts to go on that side.
And this is how it supposed to look when its bolted onto the frame of the car.
Now one thing you might notice is that the washers or spacers they give you will not make the bracket fit flush to the frame of the car. In fact you end up short on spacers. Pick up a bunch of spacers that look just like the ones they supplied so you can mount it flush.... Heres what i mean
The bottom will mount flush except the top. I actually used the spacers on the bottom so it would be flush then didnt have any for the top. So check your package to see if they gave you more than 3 or 4 washers. If not then get a bunch more.
Okay now that side is mounted correctly. Lets move on to the driver side mount. For those of you with ABS you will have to modify the ABS bracket from what i read. I dont have ABS so i didnt have to come across it. SO if anyone who has ABS did the swap and wants to contribute anything about how to do it with the ABS and some pics or came across anything let me know so i can add it.
Okay now if you dont have ABS then the driver plate should be direct mount with 3 screws...... or so i thought.. i bolted one screw and the others wouldnt go in. You will basically need a dremel/ grinder to make the hole bigger on one side. Not all three holes lined up perfectly.
As you can see when the mount is flush to the frame the other 2 holes didnt line up perfectly. So basically what i did was i kept the bottom hole the same because that one lines up perfectly. The far right hole i had to grind it bigger up and to the left and the top one had to be grinded a little down and a little to the left.
Now take the radiator and put it into the original location of the stock ones. I used an RSX one and didnt have to modify anything. They say you have to trim around the cap opening around the grill... Seeing that as i had no grill cause i have an aftermarket one then it was real easy for me. As far as wires go for the fan on the radiator. Originally the wire hanging from the right is the A/C fan switch and the one on the left is the RADIATOR fan switch. Since this motor is reversed run the RADIATOR fan switch wire to the right hand side to make it easier access. I used an aftermarket universal fan so mounting it was easy. If you cant find an SI radiator fan just go to autozone or pepboys or something and get the universal 17in fans for like $30 or something like that.
*NOTE: When you finally get the car running check the fans to make sure it is blowing the air towards the motor. If not then make sure you switch the wires to change the polarity so the fan blows the right direction.
TO BE CONTINUED.. AGAIN
K20 Specs and General Info
K20A – Japan Spec
• HP 220 @ 8000 rpm
• Torque 152 lb/ft @ 7000 rpm
• Redline 8400 RPMS
• Bore 86mm
• Stroke 86mm
• Comp Ratio 11.5:1
• Displacement 1998cc
• Specific output 110HP/L
Trans Specs
• 1st 3.27:1
• 2nd 2.13:1
• 3rd 1.57:1
• 4th 1.21:1
• 5th .97:1
• 6th .78:1
• Final Drive 4.765
K20A - EURO spec
• 147 kW (200 hp) @7400 rpm
• Torque 196 Nm @5900 rpm
• Redline 8100 RPMS
• Bore 87mm
• Stroke 86mm
• Comp Ratio 11,0:1
• Displacement 1998 cm3
• Specific output 100HP/L
K20A2 – US spec RSX type S motor
• 200 HP@7400 rpm
• Torque 142 lb/ft @ 6000 rpm
• Redline 8100 RPMS
• Bore 86mm
• Stroke 86mm
• Comp Ratio 11.0:1
Trans Specs
• 1st 3.267
• 2nd 2.13
• 3rd 1.54
• 4th 1.14
• 5th .92
• 6th .73
• Final Drive 4.388
K20A3 – US spec Ep3 / RSX motor
• 160 HP@6500 rpm
• Torque 132 lb/ft @ 5000 rpm
• Redline 6800 RPMS
• Bore 86mm
• Stroke 86mm
• Comp Ratio 9.8:1
• Specific output 80HP/L
Trans Specs
• 1st 3.662
• 2nd 1.769
• 3rd 1.212
• 4th 1.14
• 5th .92
• Final Drive 4.765
K24A2 – US spec TSX motor
• 200 HP@6800 rpm
• Torque 166 lb/ft @ 4500 rpm
• Redline 7100 RPMS
• Bore 87mm
• Stroke 99mm
• Comp Ratio 10.5:1
• Displacement 2354cc
• Specific output 88.33Hp/L
Trans Specs manual
• 1st 3.262
• 2nd 1.88
• 3rd 1.35
• 4th 1.0
• 5th .82
• 6th .659
• Final Drive 4.765
K24A – US spec CRV motor
• 160 HP@6000 rpm
• Torque 162 lb/ft @ 3600 rpm
• Redline 6500 RPMS
• Bore 87mm
• Stroke 99mm
• Comp Ratio 9.6:1
Trans Specs manual
• 1st 3.262
• 2nd 1.88
• 3rd 1.35
• 4th 1.0
• 5th .82
• Final Drive 4.765
2002-2004 Acura RSX Specs in Detail
POWERTRAIN
RSX
RSX TYPE-S
Engine Type
16-valve, DOHC, 2.0-liter, i-VTEC 4-cylinder
Horsepower, SAE Net
160 hp @ 6500 rpm
200 hp @ 7400 rpm
Torque, SAE Net
141 lb.-ft. @ 4000 rpm
142 lb.-ft. @ 6000 rpm
Redline
6800 rpm
7900 rpm
Bore & Stroke
3.39 in. x 3.39 in. (86 mm x 86 mm)
Displacement
122.1 cu. in. (1998 cc)
Compression Ratio
9.8:1
11.0:1
Induction System
Programmed Fuel Injection (PGM-FI)
Valvetrain
i-VTEC intelligent Variable Valve Timing and Lift Electronic Control (VTC), DOHC, 4-valves-per-cylinder, chain-driven camshafts and variable timing control
Engine Block
Aluminum alloy with cast-in iron liners
Cylinder Head
Aluminum alloy with 4 valves-per-cylinder pent-roof combustion chambers
Emission Control
LEV-2 (Low Emissions Vehicle-II) emissions control
Ignition System
Direct ignition system
Alternator
110-amp max
Battery
12V, maintenance-free
Recommended Fuel
Unleaded
Premium Unleaded
Layout
Transverse-mounted, front engine, front-wheel drive
Transmission
Ratios (:1)
1st
2nd
3rd
4th
5th
Reverse
Final
5-speed manual or
5-speed automatic transmission with Sequential SportShift and Grade Logic Control
Manual Automatic
3.267 2.684
1.880 1.500
1.212 0.983
0.921 0.733
0.738 0.571
3.583 2.000
4.389 4.562
6-speed manual
Ratios (:1) Manual
1st 3.267
2nd 2.130
3rd 1.517
4th 1.147
5th 0.921
6th 0.738
Reverse 3.583
Final 4.389
CHASSIS
RSX
RSX TYPE-S
Body Type
Steel unit body
Front Suspension
Fully independent Control-Link MacPherson strut
Rear Suspension
Fully independent compact double-wishbone with coil springs and stabilizer bar
Shock Absorbers
Progressive-valve gas-pressurized
Stabilizer Bars Front
.90 in. (23 mm)
Rear
.75 in. (19 mm)
Steering Type
Variable, speed sensitive rack-and-pinion power steering
Steering Ratio
15.1:1
Steering Wheel Turns (lock to lock)
2.64
Turning Circle (curb to curb)
38.1ft. (11.6 m)
Wheels
16 x 6 ½ JJ 5-spoke cast alloy wheels
Tires
P205/55R16 Michelin MXM4 all-season high-performance
Braking System
Four-wheel disc brakes with ABS
Front Discs
Ventilated, 10.3 in. (262 mm) diameter; .82 in. (21 mm) rotor thickness
Ventilated, 11.8 in. (300 mm) diameter; .98 in. (25mm) rotor thickness
Rear Discs
Solid, 10.2 in. (260 mm) diameter; .35 in (9 mm) rotor thickness
Anti-lock Braking System (ABS)
3-channel system with four wheel sensors
CAPACITIES
RSX
RSX TYPE-S
Crankcase
4.2 US qt. (4.0 L)
4.7 U.S. qt. (4.5 L)
Cooling System
M/T 5.6 US qt. (5.3 L)
A/T 5.9 US qt. (5.6 L)
5.6 US qt. (5.3 L)
Fuel Tank
13.2 US gal. (50 L)
Volumes Passenger
79.2 cu. ft.
Cargo
17.8 cu. ft.
Total
97.0 cu. ft.
FUEL ECONOMY
RSX
RSX TYPE-S
EPA Fuel Mileage–City / Highway
M/T 27 / 33
A/T 24 / 33
24 / 31
EXTERIOR DIMENSIONS
RSX
RSX TYPE-S
Wheelbase
101.2 in. (2570 mm)
Track, front
58.4 in. (1483 mm)
Track, rear
58.4 in (1483 mm)
Overall Length
172.2 in. (4375 mm)
Overall Width
67.9 in. (1725 mm)
Overall Height
54.7 in. (1389 mm)
Minimum Ground Clearance
6.0 in. (152 mm)
5.9 in. (149 mm)
Curb Weight
M/T 2721 lbs. (1234 kg)
A/T 2789 lbs. (1256 kg)
2778 lbs. (1260 kg)
EXTERIOR DIMENSIONS
RSX
RSX TYPE-S
Weight Distribution (% front / rear)
5-speed
Manual Transmission 64/36
Automatic Transmission 60/40
6-speed
Manual Transmission 63/37
INTERIOR DIMENSIONS
RSX
RSX TYPE-S
Front Head Room
37.8 in. (960 mm)
Leg Room
43.1 in. (1094 mm)
Hip Room
51.1 in. (1297 mm)
Shoulder Room
52.6 in. (1337 mm)
Rear Head Room
30.1 in. (866 mm)
Leg Room
29.2 in. (742 mm)
Hip Room
46.7 in. (1185 mm)
Shoulder Room
51.3 in. (1303 mm)
WARRANTIES
RSX
RSX TYPE-S
4-year / 50,000-mile limited warranty
Outer Body Rust-Through
5-year / unlimited-mile limited warranty
Acura Total Luxury Care (TLC) with roadside assistance
TSX Specs in Detail
POWERTRAIN
Engine Type
16-valve, DOHC, 2.4-liter, i-VTECTM 4-cylinder
Horsepower, SAE Net
200 hp @ 6800 rpm
Torque, SAE Net
166 lb-ft @ 4500 rpm
Redline
7100 rpm
Bore & Stroke
87 mm x 99 mm
Displacement
143.6 cu. in. (2354 cc)
Compression Ratio
10.5:1
Induction System
Valvetrain
i-VTEC intelligent Variable Valve Timing and Lift Electronic Control (VTECTM), DOHC, 4-valves-per-cylinder, chain-driven camshafts and variable timing control
Engine Block
Cylinder Head
Aluminum alloy with 4 valves-per-cylinder and pent-roof combustion chambers
Emission Control
Ignition System
Alternator
105 amp. max
Battery
12V, maintenance free
Recommended Fuel
Premium Unleaded
Layout
Transverse-mounted, front engine, front-wheel-drive
POWERTRAIN
Transmission
6-speed manual
Ratios (:1)
1st 3.267
2nd 1.880
3rd 1.355
4th 1.028
5th 0.825
6th 0.659
Reverse 3.583
Final 4.7
5-speed Sequential SportShiftTM automatic
Ratios (:1)
1st 2.652
2nd 1.517
3rd 1.082
4th 0.773
5th 0.566
Reverse 2.000
Final 4.44
CHASSIS
Body Type
Steel unit body
Front Suspension
Independent, double-wishbone with coil springs and stabilizer bar
Rear Suspension
Independent multi-link double-wishbone with coil springs and stabilizer bar
Shock Absorbers
Telescopic, hydraulic nitrogen gas filled
25.4 mm x 4.5 mm wall thickness
Rear
15 mm solid
Steering Type
Torque-sensing, variable power assist rack-and-pinion
Steering Ratio
14.8:1
2.7
40.0 feet
Wheels
17x7JJ 7-spoke alloy wheels
Tires
Michelin P215/50R17 all-season high-performance
CHASSIS
Braking System
4-wheel disc brakes with 4-channel ABS
Front Discs
Ventilated, 11.8 in (300 mm) diameter x 28 mm thickness
Rear Discs
Solid 10.2 in (260 mm) diameter x 9 mm thickness
4-channel
Vehicle Stability Assist (VSA)
Throttle control and brake control utilizing yaw, lateral g, speed and steering sensors for traction control and stability enhancement
Traction Control System (TCS)
Incorporated into VSA
CAPACITIES
Crankcase
5.3
Cooling System
MT 7.4 U.S. qt.
AT 7.3 U.S. qt.
Fuel Tank
17.1 gallons
Volumes Passenger
91 cu. ft.
Cargo
13.0 cu. ft. without Navigation System
12.8 cu. ft. with Navigation System
Total
104 cu. ft. without Navigation System
103.8 cu. ft. with Navigation System
FUEL ECONOMY
EPA Fuel Mileage–City/ Highway
Manual: 21/29
Automatic: 22/31
EXTERIOR DIMENSIONS
Wheelbase
105.1 inches (2670 mm)
Track, front
59.6 inches (1515 mm)
Track, rear
Overall Length
183.3 in (4657 mm)
Overall Width
69.4 in (1762 mm)
EXTERIOR DIMENSIONS
Overall Height
57.3 in (1456 mm)
4.7 in (Full-Load) 6.2 in (Unladen)
Curb Weight
MT without Navigation System
MT with Navigation System
AT without Navigation System
AT with Navigation System
3230 lbs
3241 lbs.
3318 lbs.
3329 lbs.
Weight Distribution (% front/rear)
MT
AT
60/40
61/39
INTERIOR DIMENSIONS
Front Head Room
37.8 in (960 mm)
Leg Room
42.4 in (1076 mm)
Hip Room
54.4 in (1381 mm)
Shoulder Room
55.4 in (1406 mm)
Rear Head Room
37.3 in (947 mm)
Leg Room
34.2 in (868 mm)
Hip Room
54.4 in (1382 mm)
Shoulder Room
53.5 in (1360 mm)
WARRANTIES
4-year/50,000-mile limited warranty
5-year/unlimited-mile limited warranty
4-year/50,000 mile
2002+ ACCORD SEDAN SPECIFICATIONS IN DETAIL
2002+ ACCORD SEDAN DX LX EX LX V-6 EX V-6
ENGINE
Type: Aluminum-Alloy In-Line 4 In-Line 4 In-Line 4 V-6 V-6
Displacement (cc) 2354 2354 2354 2997 2997
Bore x Stroke (mm) 87 x 99 87 x 99 87 x 99 86 x 86 86 x 86
Horsepower @ rpm (SAE net) 160@5500 160@5500 160@5500 240@6250 240@6250
Torque (lb.-ft.@rpm) 161@4500 161@4500 161@4500 212@5000 212@5000
Compression Ratio 9.7:1 9.7:1 9.7:1 10.0:1 10.0:1
Valve Train 16-Valve DOHC i-VTEC 16-Valve DOHC i-VTEC 16-Valve DOHC i-VTEC 24-Valve SOHC VTEC 24-Valve SOHC VTEC
Fuel System: Multi-Point Fuel Injection l l l l l
Direct Ignition System with Immobilizer l l l l l
Electronic Throttle Control l l
CARB Emissions Ratings LEV-2 LEV LEV-2 LEV or PZEV * LEV-2 LEV or PZEV * LEV-2 ULEV ** LEV-2 ULEV **
EPA Emissions Rating Tier 2, Bin 5 Tier 2, Bin 5 Tier 2, Bin 5 Tier 2, Bin 5 Tier 2, Bin 5
Tune-Up Interval (miles) 110,000 110,000 110,000 105,000 105,000
POWERTRAIN
Type: Front-Wheel Drive l l l l l
Manual Transmission: 5-Speed l l l
Automatic Transmission: 5-Speed Available Available Available l l
Gear Ratios: 1st (MT/AT) 3.267/2.652 3.267/2.652 3.267/2.652 NA/2.563 NA/2.563
2nd 1.769/1.517 1.769/1.517 1.769/1.517 NA/1.552 NA/1.552
3rd 1.147/1.037 1.147/1.037 1.147/1.037 NA/1.022 NA/1.022
4th 0.872/0.738 0.872/0.738 0.872/0.738 NA/0.727 NA/0.727
5th 0.659/0.566 0.659/0.566 0.659/0.566 NA/0.520 NA/0.520
Reverse 3.583/2.000 3.583/2.000 3.583/2.000 NA/1.846 NA/1.846
Final Drive Ratio 4.389/4.438 4.389/4.438 4.389/4.438 NA/4.429 NA/4.429
CHASSIS
Body Type: Unit Body l l l l l
Double Wishbone Front Suspension l l l l l
Five-Link Double Wishbone Rear Suspension l l l l l
Stabilizer Bar (mm, front/rear) 25.4/NA 25.4/14.0 25.4/14.0 25.4/13.0 25.4/13.0
2005 ACCORD SEDAN DX LX EX LX V-6 EX V-6
CHASSIS (cont.)
Variable Assist Power Rack-and-Pinion Steering l l l l l
Turning Diameter, Curb-to-Curb (ft.) 36.1 36.1 36.1 36.1 36.1
Power-Assisted Ventilated Front Disc/Rear Drum Brakes l l
Power-Assisted Ventilated Front Disc/Solid Rear Disc Brakes l l l
Anti-Lock Braking System (ABS) l l l l l
Disc Brake Diameter (in., front/rear) 11.1/NA 11.1/NA 11.1/10.2 11.1/10.2 11.1/10.2
Steering Wheel Turns, Lock-To-Lock 2.98 2.98 2.98 2.93 2.93
Electronic Brake Distribution (EBD) l l l
Traction Control Sysytem (TCS) l l
Wheels 15" w/Full Covers 15" w/Full Covers 16" Alloy 16" w/Full Covers 16" Alloy
Tires: All-Season P195/65 R15 P205/65 R15 P205/60 R16 P205/60 R16 P205/60 R16
Shock Absorbers (Hydraulic, Nitrogen Gas-Filled) l l l l l
EXTERIOR DIMENSIONS
Wheelbase (in.) 107.9 107.9 107.9 107.9 107.9
Length (in.) 189.5 189.5 189.5 189.5 189.5
Height (in.) 57.1 57.1 57.1 57.1 57.1
Width (in.) 71.5 71.5 71.5 71.5 71.5
Track (in., front/rear) 61.1/61.2 61.1/61.2 61.1/61.2 61.1/61.2 61.1/61.2
Curb Weight (lbs., MT/AT) 3053/3117 3109/NA 3144/3210 NA/3349 NA/3384
Weight Distribution (lbs. MT front/rear) 1850/1203 NA/NA 1896/1248 NA/NA NA/NA
Weight Distribution (lbs. AT, front/rear) 1911/1206 1949/1215 1964/1249 2086/1263 2097/1287
Gross Vehicle Weight Rating (lbs.) 4080 4080 4125 4300 4300
INTERIOR DIMENSIONS
Headroom (in., front/rear) 40.4/38.5 40.4/38.5 38.3/36.8 40.4/38.5 38.3/36.8
Legroom (in., front/rear) 42.6/36.8 42.6/36.8 42.6/36.8 42.6/36.8 42.6/36.8
Shoulder Room (in., front/rear) 56.9/56.1 56.9/56.1 56.9/56.1 56.9/56.1 56.9/56.1
Hiproom (in., front/rear) 54.6/53.5 54.6/53.5 54.6/53.5 54.6/53.5 54.6/53.5
Cargo Volume (cu. ft.) 14.0 14.0 14.0 14.0 14.0
Passenger Volume (cu. ft.) 102.7 102.7 97.7 102.7 97.7
Seating Capacity 5 5 5 5 5
EPA MILEAGE ESTIMATES**/FUEL CAPACITY
5-Speed Manual (City/Highway) 26/34 26/34 26/34
5-Speed Automatic (City/Highway) 24/34 24/34 24/34 21/30 21/30
Fuel (gal.) 17.1 17.1 17.1 17.1 17.1
Required Fuel Regular Unleaded Regular Unleaded Regular Unleaded Regular Unleaded Regular Unleaded
* PZEV vehicles are SULEV-rated and have zero evaporative emissions. Available on select LX and EX-4 cylinder models with AT in CA and some Northeastern states.
** ULEV-rated on V-6 models available in CA and some Northeastern states
The K20A3 does not have a standard DOHC VTEC valvetrain as we know it from the B-series engines - the K20A3 should actually be called a "DOHC i-VTEC-E" engine, because it uses a VTEC-E cam setup. The K20A2 is the "real" DOHC i-VTEC engine, utilizing the standard DOHC VTEC cam setup we're all familiar with. To help you understand the differences between the K20A2 and K20A3 engines, I've included the following information from a post I made elsewhere:
Allow me to evaluate. Let's start out by defining some terms:
VTEC - Variable valve Timing and lift Electronic Control. At low RPM, a VTEC engine uses a normal cam profile to retain a smooth idle, good fuel economy, and good low-end power delivery. The VTEC mechanism engages a high-lift, long-duration "race" cam profile at a set RPM value (i.e., ~5500RPM on the B16A) to increase high-end power delivery.
VTEC-E - Variable valve Timing and lift Electronic Control for Efficiency. This system isn't really VTEC as we know it. At low RPM, the VTEC-E mechanism effectively forces the engine to operate as a 12-valve engine - one of the intake valves does not open fully, thus decreasing fuel consumption. At a set RPM value (i.e., ~2500RPM in the D16Y5), the VTEC-E mechanism engages the 2nd intake valve, effectively resuming operation as a normal 16-valve engine. Note: in a VTEC-E engine, there are no high-RPM performance cam profiles; this engine is supposed to be tuned for fuel economy, right?
VTC - Variable Timing Control. This is a mechanism attached to the end of the intake camshaft only which acts as a continuously variable cam gear - it automatically adjusts the overlap between the intake and exhaust cams, effectively allowing the engine to have the most ideal amount of valve overlap in all RPM ranges. VTC is active at all RPMs.
i-VTEC - intelligent Variable valve Timing and lift Electronic Control. This is a combination of both the VTEC and the VTC technologies - in other words, i-VTEC = VTEC + VTC. Currently, the only engines that use the i-VTEC system are the DOHC K-series engines.
Now this is where things get tricky - Honda uses the term "DOHC i-VTEC" for two different systems: The first system is used in the K20A2 engine of the RSX Type-S. The second system is used in the K20A3 engine of the Civic Si.
The First System (K20A2):
This system is pretty close to the older DOHC VTEC engines. At low RPM, the K20A2 uses a normal cam profile to retain a smooth idle, good fuel economy, and good low-end power delivery. At 5800RPM, its VTEC mechanism engages a high-lift, long-duration "race" cam profile to increase high-end power delivery. The only difference between this i-VTEC engine and the older VTEC engines is the addition of the VTC system. The intake camshaft has the automatic self-adjusting cam gear which continuously optimizes valve overlap for all RPM ranges.
This system is used in engines powering the JDM Honda Integra Type-R, Civic Type-R, Accord Euro-R, and the USDM Acura RSX Type-S and TSX.
The Second System (K20A3):
This system does not really conform to the "DOHC i-VTEC" nomenclature, as Honda would like us to believe. As I mentioned in my previous post, it actually should be called "i-VTEC-E," because it uses a VTEC-E mechanism rather than a standard VTEC mechanism. At low RPM, the VTEC-E system effectively forces the engine to operate as a 12-valve engine - one of the intake valves does not open fully, thus decreasing fuel consumption. At 2200RPM, the VTEC-E system engages the 2nd intake valve, effectively resuming operation as a normal 16-valve engine. There are no high-RPM performance cam profiles; this engine is tuned to balance fuel economy and power, rather than provide pure performance. On the intake cam, there is the VTC mechanism which basically is an automatic self-adjusting cam gear used to continuously optimize the valve overlap for all RPM ranges. This being a VTEC-E system - and not a true DOHC VTEC system - is the reason the K20A3 redlines at a measly 6800RPM, while the K20A2 is able to rev all the way to 7900RPM.
This system is used in engines powering the USDM Acura RSX base, Honda Civic Si, Accord 4-cylinder, CRV, and Element.
Special note: The K20A3 engine used in the Acura RSX base has a slightly different intake manifold design from the K20A3 engine used in the Civic Si. The RSX engine uses a dual-stage manifold, similar in concept to the manifold of the B18C1 in the old Integra GSR. It uses long intake runners at low-RPM to retain low end power, and switches at 4700RPM to a set of shorter intake runners to enhance high-end torque. This accounts for the extra 9 ft-lb of torque in the RSX (141 ft-lb, vs. 132 ft-lb in the Civic Si).
Myths:
1. The i-VTEC engine engages VTEC gradually, and not suddenly like in the old VTEC engines.
Wrong. The i-VTEC engine "engages VTEC" at a single set RPM, like always. Whoever started this rumor is a ****tard. Read the definitions above.
2. VTC engages at a set RPM.
Wrong. VTC is always activated. Read under "VTC" above.
3. The K20A3 engages VTEC at 5000+ RPM.
Wrong. Technically, there is no "VTEC" (as we think of it) in the K20A3 engine - it uses a VTEC-E technology, which engages at 2200RPM. Read under "The Second Sytem" above.
ARTICLES
ALL IN THE FAMILY
By Keith Buglewicz
A sense of nervousness has seeped into the Honda performance community. It comes not from new anti-racing laws, or emissions regulations that will weld the hoods of new cars shut. No, this nervousness comes directly from Honda itself.
K. It's just a letter, but in the coming years its significance to Honda enthusiasts will achieve the status that "B" has now. With the introduction of the Acura RSX, the new Honda Civic Si and CRV, Honda chucked more than 12 years of engine experience and aftermarket support out the window for a clean sheet of paper design. The new engine family is the K series, and on paper, it makes even the highest performance VTEC B series engine look like yesterday's blue plate special.
Look at the specs. The K20A2 in the RSX Type-S churns out a solid 200 hp from its 2.0- liters. That's 100 hp per liter, and you can thank i-VTEC for this specific output. The "VTEC" part of that acronym is already familiar to Honda enthusiasts. When the engine reaches a certain speed, rocker arms are locked together, linking them to a higher-lift cam, and allowing more fuel and air into the engine. In the world of variable valves, this is known as cam shifting right now, only Honda, Toyota, BMW and Porsche sell cam-shifting systems in the United States.
However, that little "i" means a lot. It means the K series engines are also equipped with VTC, or Variable Timing Control. This cam phasing system uses a spool gear, oil pressure and some fancy electronics to change the angle of the intake cam by plus or minus 30 degrees of timing.
The result is an engine with excellent power and especially torque, but one that still manages better fuel efficiency and lower emissions than its predecessor.
Now, this is all fine and good, but what does this mean for an aftermarket that has been centered on the B series engines? What can be done with it? Can it be turbocharged? Can it be swapped? Does it respond to the simplest bolt on mods? These are the questions on the minds of Honda enthusiasts, and we intend to answer as many as we can. First, let's take a close-up look at the engines as they come from the factory.
THE ENGINES
The K series currently consists of four power plants. The K20A3 is found under the hood of the standard RSX. With 160 hp at 6500 rpm and 141 Ib-ft of torque at 4000 rpm, it churns out the same power as the B16A, 10 hp less than the B38C1, but much more torque than either one of them, all at a lower engine speed. The i-VTEC system works only on the intake cam on this engine, and it has a composite two-stage intake manifold.
Similar to the K20A3 is the K20A found under the hood of the new Civic Si. K20A-what? Well, we're not sure. The cars we've seen have all been pre-production vehicles, without the requisite engine code stamp on the block. The best information we have so far is that it's a K20A3, same as the RSX. But that sounds a little off to us. While it has the same i-VTEC system as the RSX, it boasts the fixed, single-stage aluminum intake manifold of the K20A2 under the hood of the RSX Type-S instead of the dual-stage manifold of the base RSX. Whatever the final engine code works out to being (we'll just call it a K20A for now), this manifold swap actually works against the Si, reducing its torque. It weighs in with the same 160 hp, but with only 132 Ib-ft of torque at a higher 5000 rpm than its K20A3 sibling.
Following the logic of Honda's engine codes, the K24A1 is a 2.4-liter version of the K series. Following a philosophy similar to the B20 found in the previous CR-V, it's tuned to be a torque monster with a long, 99 mm stroke. That's a full 13 mm (0.51-in.) longer than any of the K20 engines. The extreme stroke works. With 162 lb-ft available at a low 3600 rpm, the CR-V is a veritable stump puller among small four-cylinder SUVs. At the top of the enthusiast heap is the K20A2 that powers the RSX Type-S. With a lofty 7900-rpm redline, 200 hp and 142 lb-ft of torque, this engine really is as good as its hype. With the exception of the stroked K24, the engines are all very similar structurally. AII three of the 2.0-liter versions share the same 86 mm x 86 mm bore and stroke. This is known as a square design. An oversquare engine has a longer stroke than bore, like the K24. This generally results in more torque, but at the expense of peak power. Conversely an undersquare design (such as the S2000's engine) has a bore larger than stroke, and generally produces more high-end horsepower at the expense of torque. Not surprisingly, a square design like the K20 is a compromise between these two extremes, offering good torque and good horsepower without sacrificing or optimizing either. Aside from the manifold change on the Si's version of the K20, the main difference between these engines is the way they manipulate their valves.
VALVE DANCING
The K20A2 in the Type-S works the way you expect VTEC to work. The two camshafts are equipped with three cam lobes and rocker arms for each cylinder's pair of intake and exhaust valves. At 5800 rpm, oil pressure activates pins that lock the outer rocker arms to the center arm. This forces both valves to use the higher lift, longer duration center camshaft profile. However, this is augmented by VTC on the intake side, which manipulates the timing of the cam itself. This can be used to augment torque, reduce emissions or a variety of different things depending on what the computer thinks is best at the time. The RSX's K20A3, the Si's K20A and the CR-V's K24A1 use i-VTEC differently. First, it only operates on the intake valves. But even then, the philosophy is changed. Until the VTEC threshold is reached, the lesser K engines essentiality only use one intake valve per cylinder. The other is opened just a crack, enough to keep fuel from pooling behind the valve, but that's about it. In addition, the VTC is tuned primarily to keep emissions as low as possible. All this weirdness results in excellent swirl inside the combustion chamber and very efficient combustion. It's great for fuel efficiency and low emissions. However, it isn't so great for driving fun, as the engine inhales less deeply and revs lower.
FRANKENSTEIN RETURNS?
The K24A is more closely related to the K20A3 and K20A. While it uses the same i-VTEC tuning as those engines, it's the long stroke design that's intriguing. The difference is in the block. The K24's deck height is roughly 19 mm higher than its smaller siblings. It's also slightly bored, with 1 mm larger cylinders. The compression ratio is also down slightly from the non-Type-S engines, 9.6.1 vs. 9.8:1. So what? Well, the natural temptation is to throw the K20A2's efficient head onto the K24A1 block, raise the redline and have a torquey, ultra-powerful i-VTEC stroker Frankenstein monster engine.
The actual bolting on part wouldn't be too difficult, as the heads should mount right up. However, you do run into an issue with piston speed. At its 7900-rpm redline, the K20A2 in the Type-S has a piston speed of 4464 feet per minute (fpm). Thanks to its long stroke, the K24A1 comes close to that, running at 4225 fpm at its much lower redline of 6500 rpm. By the time you've spun your K24 up to just 6900 rpm, you're already at 4485 fpm, and at the 7900 rpm redline of the K20A2, you're at a crazy 5135 fpm. For comparison, even the hyperkinetic S2000 with its 9000 rpm redline doesn't exceed 5000 fpm (it maxes out at 49% fpm). And the Integra's B18C1 only reached 4573 fpm. Translation: If you're going to plunk a K20A2 head on a K24A1 block and redline the concoction to 7900 rpm without seriously building up the bottom end.. duck.
If you scan the chart on page 85, you'll see that we've covered most of the cars there. The Integra is just for comparison, of course, and we've hit the RSX and CR-V engines. So what's the S2000 doing there? That is the true wild-card in all this. It seems as though despite the different engine code (F20C1) and north-south orientation, the S2000's engine block is a kissing cousin of the K series. In fact, according to engine developer Paulus Lee at Advanced Engine Breathing Systems in San Diego, the head gaskets are the same. This means the S2000's standard VTEC head could, in theory, be put on the K series block.
HEAD GAMES
The head design of the different Ks are intriguing, beyond just valve manipulation. The K20A2 found in the Type-S is a wonderful design, according to just about everybody; Honda nailed it, putting even the very effective B series engines to shame. The valves are huge, noticeably bigger than the B series valves even without the use of a caliper. But measure them and the difference is that much more apparent. The intake valves on the K are 2 mm bigger than the B series intake valves, and the same goes for the exhaust valves. The intake port angle is also excellent, with a straighter shot into the combustion chamber than the B series. On the other side of the head, the improvements continue. While the B series heads force the exhaust gases through a strange humped path through the head, the K sends it straight out to the manifold.
There are other improvements. The K uses roller rocker arms. This not only reduces friction in the valvetrain, making more power possible it also frees up the aftermarket to offer durable billet cams for the Ks. Slipper followers like those in the B series put too much pressure on billet cams, wearing them down prematurely. Forged camshafts are better, but expensive to produce in small numbers. Note the difficulty Crane has gone to in creating roller followers for its new billet B series cams. But with roller followers built in, we expect to see some radical profiles for these engines in coming months.
The other K head is not quite as efficient. While the Type-S head boasts big, smooth, unobstructed ports, the regular head features a strange groove cut into the wall between the intake valves. Undoubtedly there to help improve the single-valve operation of the VTEG system these engines use, any head porter can tell you this kind of weirdness plays havoc with airflow into the engine. The result is pretty clear. The Type-S K20A2 is the engine to have. While the other two K20s are OK in their fuel-miserly, non-polluting way - and the K24 is the undisputed torque champ - they are less ambitious, and offer less potential for improvement compared with the mighty K20A2.
THE BOTTOM OF IT
Under the head is an all-new block. Made of aluminum alloy, it's a beefy unit, heavily ribbed and gusseted for extra strength. However, it's also an open deck design. An open deck means that at the top of the block (the deck), the water jackets around the cylinders are open to the head, and rely on the head gasket for sealing. This limits the amount of boost that an engine block can withstand, because the individual cylinders can actually wobble slightly under high pressures. This is why drag racers will seal the deck on their B series engines before pumping the pressure up to bone-crushing levels.
But for a naturally aspirated engine, this is pretty darn strong. Flip the engine over and you're greeted with a bearing girdle that actually makes up the lower quarter of the block. Known as a split case, this design is much stronger than the internal bearing girdle used in the B engines. About the only drawback to this design is that it only uses two bolt mains, rather than the four bolt mains preferred by racers. No matter, considering the overwhelming beefiness of the design, this is still quite acceptable. Remove the lower part of the case, and you'll see there's a lot of room inside the block. This means that one could go pretty crazy with rod length before the block itself needed modification.
The crank is Honda's typical overbuilt forged unit. The Type-S crank is, again, the better of the two, being fully counterweighted. The rods are similar in both designs, although the Type-S rods are stronger to cope with the higher piston speeds encountered in the engine. The pistons are another matter, however. The Type-S pistons are about what one would expect, and are in fact quite similar in design to the high domed structure that one finds in the B series engines. The piston itself accounts for the higher compression in this engine, as the bore and stroke are identical. On the other hand, the lower end K series piston looks, well, weird. Off center on the top of the piston is an odd, round dish that for all the world looks like a bellybutton. We can only speculate that this is another way the non-Type-S engines achieve good fuel economy and low emissions.
WHAT ABOUT SWAPS?
It goes without saying that the various K's should swap into the RSX, Civic Si and CR-V engine bays without a problem. In fact, one of the first swaps we're likely to see is the anemic K20A in the Si being ditched in favor of the more powerful K20A2. This is a drop-in replacement. In fact, the same hatchback is sold in Europe with the K20A2 and called the Civic Type R, and there's some speculation that we'll see this exact car in the United States sometime in the 2003 model year.
But the real question is will it fit in the standard, non-Si EM-chassis 2001-2002 Civic? Well, after analyzing the size of the engine bays and the way the engines bolt in, we'll say that it's possible, but it won't be the drop-in replacement we've become accustomed to with the EJ Civics and the B series engines.
The EM Civic, the Civic Si, RSX and CR-V are all cousins under the skin. However, that EM Civic is the redheaded stepchild of the group. In an effort to save some RBD bucks, Honda opted to further revise the venerable D series engine which powered Civics since the late '80s, rather than plunk the new K engines in them. At 1.7- liters and 127 hp (in the EX), it runs well enough, and is still a solid economy car engine. Of course, EM Civic owners want more.
One major obstacle is the D series engine spins the wrong way. For a very long time, Honda engines all spun counterclockwise, backwards from almost every other engine on the market. Why? Well, it put the engine on the left side of the engine bay, which is the passenger side in Japan. This made the steering mechanism easier to route. But with Honda being an international company for several decades, it mainly was a case of corporate culture sticking around for no good reason.
The K series engines spin clockwise, like most other engines, and as a result they sit on the right side of the engine bay. In order to make one basic engine bay that would fit both a left-side and a right-side engine, Honda had to do a little bit of clever engineering. The transmission side of the engine in each car attaches directly to the frame using a beefy engine mount, which bolts to the tranny case. The pulley-side mount bolts to a "box" that is welded to the frame. The problem is that the "box" is on the right side of the engine bay in the RSX, Type-S, Si and CR-V, and on the left side in the EM Civics. Dimensionally, there isn't much of a problem. The K engines should fit into the Civic engine bay just fine without any clearance issues. Getting it to bolt in place, however, will require some tricky mounts. To top it all off, you'll have to drop in the K20 transmission and driveshafts as well. Even if the engine mount situation is solved, the cost of this engine swap (at least until K20A2 engines become more readily available) will be so much that one might as well just buy an RSX Type-S.
Of course, this doesn't mean that somebody won't try it. As for earlier EJ Civics or earlier Integras, we'd just leave that whole can of worms unopened until K20A2-powered EM Civics are commonplace.
WHAT DO TUNERS THINK?
The reaction to the Type-S engine has been overwhelmingly positive. Despite a few reservations about VTC, the engine has been greeted with open, loving arms. Many tuners have delved deep into the guts of the K engines, and are coming back with some interesting findings. The non-Type-S engine has received a more lukewarm response. Although it is a decent engine, it isn't really the best choice for an enthusiast. We can expect to see intake and exhaust systems for this engine, maybe supercharger kits later down the road. But this is not like the B18A "LS" engine, which is a pretty good powerplant by itself. It's best left alone.
You're probably wondering what tuners have discovered about the engines, though. For example, how easy is it to turbocharge the K series'? What kind of internal mods have they made? Can you really put an S2000 head on a K block? The answers to these and other questions will be found in Part 2, in the next issue of HT.
Don't you just love cliffhangers'?
Part2: The Tuners' Perspective
In the April/May issue of Honda Tuning, we took an up-close look at Honda's new K series engine, the motivational power behind the RSX, new Civic Si and CR-V sport utility. We compared it to the B series powerplants, far and away the mainstay of the Honda tuning market, and discovered Honda really did its homework on this engine. With robust construction, bigger ports, extremely trick valvetrain, and a number of other goodies, we were positively giddy with excitement.
However, we're just a bunch of magazine schlubs, so we talked to some of the top tuners to discover what they thought of the K, what they have planned, and what obstacles they've had to overcome to achieve their goals. Although we wanted to give the tuners a little more time to develop their various K series projects.
RECAP
The K20A2 found under the hood of the RSX Type-S obviously king of the hill. While the A3 in the standard RSX and new Civic Si, and the A1 in the CRV, have been tuned with an eye toward fuel efficiency and low emissions, the A2 has been tuned for power.
The big difference between the A2 and the other K series engines is how the cam-switching part of iVTEC works. The A2 uses a cam-switching technique familiar to the most Honda fans. Extra rocker arms are slaved to one of two cams, increasing lift and duration at higher revs for better high-end power. The other engines use a version tuned for fuel efficiency. One intake valve is essentially closed when "off-cam," and when the switch happens, the closed valve is just slaved to the same cam the opening one does. No higher lift or duration, but some pretty good fuel economy and emissions figures.
The K20A2 is a gem of a powerplant, and is already making serious power in the Type R versions of the Integra (Yes, it's still called that in Japan.) and Civic. It's clear it has plenty of potential for performance, but how will it react to intake and exhaust modifications? What about nitrous oxide and forced induction? Can the engine be turbocharged or supercharged with all that cam-phasing wackiness?
BASIC TUNING
If you're looking for basic, bolt-on power you're in luck. The K20A2 responds beautifully to intake systems, some systems making a solid 10 hp at the wheels. Manufactures, such as AEM and Injen, are coming up with short ram and cold-air systems. Short ram systems bold right in, while the location of the windshield washer bottle requires a bit more work form cold-air systems. The bottle must be relocated or removed, and a small portion of the fender liner needs to be trimmed, as well.
For the skinny on exhaust systems, we turned to DC Sports of Corona, Calif. These guys have been in the Honda exhaust market longer then just about anyone in the United States and are the first to have both an effective cat-back system and header for the Type-S.
The engineer in charge of the K series engines, Jehan Tetangco, told us the RSX proved to be a tricky customer. Naturally, DC fell back on its prior knowledge of Honda engines, fitting a 2.25-inch B-pipe to the car. It promptly lost power. A 2-3/8-inch pipe lost even more power. After going backwards and fitting a 2-inch pipe, which pushed power back up to just less then stock levels, he finally reached for the B series power handbook and threw it away. Clearly, this K was a completely different animal.
After much experimentation, Tetangco finally discovered a combination that worked. According to DC Sports, its Twin Canister System axle-back system and a 2.5-inch B-pipe resulted in a solid 6 hp gain and an average 3 hp gain from 3000 rpm to redline.
Headers are even more difficult proposition. The good news is the catalytic converter is still separate form the exhaust manifold. However, it is shoved so close to the head that there is very little room for long exhaust runners. In fact, Tetangco discovered Honda's engineers did such a good job on runner size that he, instead, focused attention on the collector. After trying numerous designs, he discovered one that worked, again adding a nice 6 hp and 3 hp, average. Together, the header and cat back are good for 8.6 hp, according to DC Sports. However, add DC's cold-air intake system and the power gain shoots up to over 22 horses, with almost a 10 hp average from 3000 to redline. Clearly, intake, not exhaust, is the K20A2's biggest shortcoming from the factory.
NITROUS OXIDE AND FORCED INDUCTION
Traditionally, one of the quickest and easiest ways to get power form an engine is a shot of good ol' nitrous oxide. With more power just the push of a button (and a few hundred dollars) away, many vehicles fine themselves with nitrous bottles in the trunk for a little added oomph. Simple, single-fogger systems are commonplace, but multiple fogger systems with ports drilled directly into the intake manifold are not unusual.
W spoke to Eric Vargas of Advanced Engine Management in Torrance, Calif. Eric is the brain behind AEM's burgundy, nitrous-charged RSX you might have seen in our sister publication, "Sport Compact Car." The car has been through a lot, including a blown engine caused by an unforeseen problem with the fuel delivery system.
The Integra (and previous Hondas) used a fairly conventional fuel and ignition system. The fuel routed to the rail where a regulator controlled pressure, and excess fuel was returned to the fuel tank. Even in the high-tech Integra, a mechanically activated distributor controlled the ignition.
The K series has a "headerless" fuel system, meaning the regulator and return line are actually in the tank. There is no fuel return from under the hood. This gives Honda the advantage of building the pump, regulator, return and fuel level sensor all in one unit. It also helps reduce evaporative emissions.
Vargas tells us the down side to this type of system is it becomes very difficult to build extra fuel pressure. It used to be that adding a fuel pressure regulator would build enough additional pressure from the stock pump to make forced induction or big nitrous applications relatively simple. The way the K series' fuel is supplied make building adequate pressure much more difficult.
Unfortunately, there is no simple workaround for this problem. The stock fuel pump is capable of about 55 lbs of pressure, adequate for low-horsepower (40 hp or so) nitrous system or very low-pressure turbo or supercharger. Any higher and the system will run very lean-a dangerous condition that could result in a blown engine.
For higher horsepower application, a return line will have to be run, meaning the single-piece fuel pump/regulator/return/level sender assembly in the tank will have to be separated into individual components. This is an expensive and time-consuming process that would make a bolt-in kit a more diffcult proposition. Of course, that hasn't kept HKS, Greddy and Jackson Racing from continuing to develop kits. Racing applications that need more than just a few pounds of boost are still in the future.
The ignition system is also very different. The B and H series engine use distributors, despite all the high-tech valve gizmos. The K uses a computer-controlled ignition without a distributor. While this is great for precisely retarding and advancing spark to meet different conditions, it makes it very difficult to alter the spark curve using external devices. Simply put, the engine freaks out and switches into limp mode until the computer itself is allowed to manipulate spark again.
ENGINE COMPUTER
It's easy to see the K's computer is the dominant force in the engine, and nobody knows Honda computers better than Doug Macmillan of Hondata in Torrance, Calif. After digging into the stock computer, his excavations have unearthed some surprising-and hopeful-answers.
First, the programming is extensive. The fuel maps alone take up more memory then all of the programming for the B series put together. Macmillan told us there are six non-VTEC and six high-lift cam tables. There are also another 24 that, as of press time, he was still working on. He also discovered the ignition tables and the tables governing VTC cam advance.
Additionally, he discovered something tuners are going to love about the stock ECU: Flash programmability. Unlike the previous car, this would make reprogramming of the computer far simpler. And with the hurdles surrounding ignition and cam timing for forced-induction engines, being able to directly manipulate these factors is crucial.
Macmillan also told us a possible trouble spot doesn't seem to affect the engine's performance potential. The RSX's compute is multi-plexed, meaning it sends multiple signals to different systems down the same line. This would have the potential to play havoc with aftermarket tuning but it seems the multi-plexing is confined to systems outside the engine compartment.
FRANKENSTEINS AND SWAPS
One of the greatest performance features of the B series engines is the interchangeability of the parts. With some modification, you can put a VTEC head with a Type R intake manifold on a B20 block and make yourself a monster of an engine.
Is the same true for the K? Skunk2 thinks so. It's in the process of building a naturally aspirated race engine based on the Frankenstein concept. With the K20A2's high-powered VTEC head mated to the CR-V's long-stoke K24A1, Michael Choi of Skunk2 told us he hopes to create a high-revving, high-power, high-torque monster that will rip the wheels off the shop's racecar. The biggest obstacle will be the lack of off-the-shelf, high-performance parts. Anybody wishing to build up the internals of their K engine will simply have to wait for those parts to fill the pipeline.
Engine swaps are a different story. We spoke to Brian Gillespie of Hasport, based in Phoenix, Ariz. Known throughout the tuning industry for its engine mount kits, Hasport has already been working on stuffing the K into its chassis mates.
The easy part is swapping the K series engines between car that were originally equipped with them. So, if you want more bang out of your Civic Si, it's relatively simple to drop in an RSX Type-S engine and be on your way. The only snag might be with swapping a K24 engine into the RSX or Civic, owing to its slightly taller block.
The non-Si Civics are a different matter. The current-model EM Civics are built on the same basic chassis as the RSX and CR-V. This means that, theoretically, the K series engines should fit in the Civic chassis. However, the engines mount differently in their respective bays-the D series engines used in the Civics on the driver's side, the K on the passenger side. This is a more complicated proposition for potential swappers.
According to Gillespie, the trick is using the RSX subframe. This subframe simply bolts in place of the standard Civic subframe, and ahs the rear engine and transmission mount in the proper place for the K series engine. After that, it's a matter of developing the proper engine mount on the sides of the engine. Gillespie is confident the swap will be complete soon, and that before long he'll have a K20A2-powered Civic coupe up and running. This is great news for owners of current-model Civics who have been stymied by the D17's lack of tuning options.
FINAL WORD
The future is bright for the K series but, compared to what the aftermarket is use to, the K series is a whole new ball game. From the most basic tuning to the most advanced, it's going to take time for the RSX and its counterparts to get up to speed. But it will. Whether you like it or not, Honda is not making the B anymore. Smart tuners are going to get cracking on the new K as soon as they can. Those that don't, will undoubtedly be left behind.
FULL CREDIT TO XPRODUCTIONZ VIA
http://www.xproductionz.com/k20swap/k20swap.html
I am posting this just in case the page gets lost in the future.
Old Nov 29, 2005
  #41
allshownogo01's Avatar
allshownogo01 is an unknown quantity at this point
what happened to the part about installing the tranny?
Old Nov 29, 2005
  #42
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
uhh... first off you dont install a tranny... it should be already attached to the motor when your putting the motor in... now if anything i havent had time lately to finish up the write.. i stopped at the wire harness part.. and thats the part where everyone usually has the hardest of time anyways.. but if im mistaken please do clariy what you mean by tranny install
Old Nov 29, 2005
  #43
i have an automatic. ive seen people with automatic em2s convert to the 6spd rsx tranny, but i dont know how its done.. is there a seperate DIY about manual swaps?
Old Dec 2, 2005
  #44
AirLex-R's Avatar
AirLex-R is an unknown quantity at this point
can we used the DC5 Tein adjustable Type Flex into our civic Ex with the D17A engine? can it fit perfectly...if no, wat are the items that we need to fit it....thanks..
Old Dec 3, 2005
  #45
i right now i am using stock RSX type S shocks and sway bars in my car so in my opinoin yes it should fit
Old Dec 8, 2005
  #46
DAQIUN's Avatar
DAQIUN has a little shameless behaviour in the past
thanks for the info
Old Dec 10, 2005
  #47
ImportRacer2123's Avatar
K20 Member
Originally Posted by ImportRacer2123
i got it all wired up. is the grey wire the ground or is the black wire on the primary o2? i wired it up hopefully i was right and the black is ground.
Originally Posted by Dark2k1
I think.. hte 2 black wire is for the heater.... white for the signal and grey for signal ground.... but I'm not sure
Did Anyone Figure this out?
Old Dec 10, 2005
  #48
there is no gray wire on the primary o2.... theres only 2 black one white and one green
Old Dec 23, 2005
  #49
caspers_hatch's Avatar
caspers_hatch is an unknown quantity at this point
Sounds like he has a non-OEM o2, they have a grey, i just don't remember which is which
Old Dec 23, 2005
  #50
the secondary o2 which is after the cat has a gray wire... but not the primary...
Old Feb 18, 2006
  #51
well.. i will be spending the next to days cleaning up the wires around my ecu and the relay swaitch for the o2 area.... so in less than 48 hours i will have the rest of the o2 relay part done if anyones still interested in it
Old Mar 3, 2006
  #52
where did you get the hasport mounts for $400? i checked the website its like $600 did the price go up or something?
Old Mar 3, 2006
  #53
kasimmmmm's Avatar
^werd
Old Mar 5, 2006
  #54
updated guys.. i finally added the wiring of the REALY portion of it with some pics to help out
Old Mar 5, 2006
  #55
aznrocka's Avatar
aznrocka is an unknown quantity at this point
first time i've seen this write up...it's a very good and detailed write up...and a very expensive swap
Old Mar 5, 2006
  #56
it can be... but sometimes people do come up on really good deals for complete swaps
Old Mar 5, 2006
  #57
cubanmike26's Avatar
Thanks for this great article X..one of, if not the most complete k20 swaps for our cars..
Old Mar 5, 2006
  #58
tfnaaf's Avatar
BLDNPSI Mod
Thanx for the updates Xproductionz...... maybe someday
Old Mar 7, 2006
  #59
gh0st's Avatar
TAQUITOS!!!!
nice write-up. i might try this someday. :thumbup:
Old Mar 9, 2006
  #60
k20newbie's Avatar
k20newbie is an unknown quantity at this point
Unhappy subframe k20 required?
taking off subframe civic.But is it need to get subframe from dc5 put in side?
i only bought the engine and other stuff but no sub frame d5.
e mail me Dannziggg@yahoo.com
