stage 2 na crower cam experience
Old Sep 11, 2005
  #61
ncirom2003's Avatar
if your in the area ill do it at 25 an hour.
otherwise id say it will most likely be a..............2 hour install and figure 65 an hour so 130 give or take like 15 bucks.
Old Sep 11, 2005
  #62
se7engen_riDe's Avatar
se7engen_riDe is an unknown quantity at this point
^^^ it takes 2 hours to instal a camshaft?
Old Sep 11, 2005
  #63
how much is installation and dyno tuning gonna cost me??
Old Sep 11, 2005
  #64
Vantage's Avatar
Vantage should not be trusted
When i got my b18 cams/springs/retainers installed it was 324 Candian.
Old Sep 12, 2005
  #65
how much is that in US money?
Old Sep 12, 2005
  #66
ncirom2003's Avatar
uhmmmm yes???
lol i dunno i just shot that off the top of my head, i figure if he doesnt have to do springs/retainers he wont have to pull the head, saving a ton of time.
Old Sep 12, 2005
  #67
^^^ yea i hope so. i needa start makin some phone calls to some shops around and ask how much they will charge for intallation and dyno tune. dyno tune will take about an hour.
Old Sep 13, 2005
  #68
meowdog's Avatar
meowdog is an unknown quantity at this point
Originally Posted by kezay
meowdog the fcon is only designed to controll fuel however we need something to controll the ignition timing, raise the rev limiter, adjust the VTEC point, and also to controll fuel. The AEM EMS is the easiest choice for us. However the greddy e manage would be able to controll both fuel and the ignition timing but I have come to the conclusion that if I am going to but anything to tune my car I am going the AEM route. (Just do it right the first time around)
kezay, the mech who is tuning the fcon for me said tt idling and ignition can definitely be tuned. but he doesnt know til wat extend though. cos they have not tried it on a 7thgen w high cams before. sadly, fcon cant raise the rev limiter. too bad aem ems is not available at my location. fcon can control vtec as well.
im currently on emanage now..not running very well w the cams. seems like the stock ecu is "kicking in" very often and my air-fuel is screwed up. on the dyno, the air/fuel ratio started to change just after 3 runs. indicating the stock ecu kicking in to remove the settings inputted by the emanage.
Old Sep 13, 2005
  #69
turboengnr's Avatar
DONT PANIC
meowdog, read this thread.
http://www.7thgencivic.com/forums/sh...d.php?t=220799
it deals with the long term and short term fuel trims on the D17 ecu. It will explain why your dynographs are inconsistent.
Old Sep 13, 2005
  #70
kezay's Avatar
kezay is an unknown quantity at this point
This is exactly my point but my question is what do we do?
Old Sep 13, 2005
  #71
tfnaaf's Avatar
BLDNPSI Mod
Spend HOURS, and HOURS tunning, read turboengnr's posting about how and what to look for
Old Sep 13, 2005
  #72
djmota's Avatar
hey kezay what is the code that you are throwing? have you had it read?
Old Sep 13, 2005
  #73
turboengnr's Avatar
DONT PANIC
exactly.
Old Sep 13, 2005
  #74
kezay's Avatar
I am not trowing any codes. But as stated above we just need a lot of tuning.
Old Sep 14, 2005
  #75
jky's Avatar
jky
jky is an unknown quantity at this point
As I see it the only thing is the AEM EMS 30-1030, right ?
But at 1400$+ that is a lot of money and you will have to keep the stock ecu!! S**T , ... !
Well back to the drawing board.
Old Sep 14, 2005
  #76
djmota's Avatar
I really don't see whats wrong with keeping the stock ecu. All it does is run the multiplex system. (ac guages ect.) The ems is alot of cash if you are going to stay with the d17. If you are planning a swap in the future. It nice to have something to play with now (d17) and still be able to use it later (k series).
Old Sep 14, 2005
  #77
ncirom2003's Avatar
what about any hondata products??? do theyre things even work with our cars and engines?
Old Sep 14, 2005
  #78
djmota's Avatar
hondata has pretty much given the d17 the middle finger.
Old Sep 14, 2005
  #79
ncirom2003's Avatar
NICE!!! lol dam
Old Sep 15, 2005
  #80
jky's Avatar
jky
If you keep the stock ecu, then there is no point in swapping cams, pistons, headers , ...
In Europe you pay al lot more for a 200hp engine, as for 125hp engine, the difference is round 800$/year in insurance money!!!! that is why I would like to keep my engine and just upgrade it, so on paper the engine is still 125HP, but in realty it is +-140WHP !
Old Sep 15, 2005
  #81
djmota's Avatar
The stock ecu does not run anything else. It just allows you to continue to use the stock temp guage and ac button. EMS will handle everything else.
Old Sep 16, 2005
  #82
jky's Avatar
jky
I know why the stock ecu is used with AEM EMS. I just want to know if there are any cheaper alternatives, as some mentioned there is a problem with E-manage and VAFC-II when the stock ECU triest to fix close loop ?
Old Sep 16, 2005
  #83
ncirom2003's Avatar
can somebody explain closed loop? thanks
Old Sep 16, 2005
  #84
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Get a turbo kit. Engine looks as stock with cold intake. Everyone who looked at my engine, could not tell right away that it has a turbo. +-140WHP will be nothing compared to +-180 whp and you dont spend $1400 on AEM just to keep your camshaft happy....
Old Sep 16, 2005
  #85
ncirom2003's Avatar
do you think the turbo cam is a waste then?^^^
Old Sep 16, 2005
  #86
Vantage's Avatar
AEM isnt the difference from 140-180 whp, also, if someone cant notice a turbo'd engine. Then u should probably stop showing off your car at elementary schools :-)
Old Sep 16, 2005
  #87
Nokturnl's Avatar
Crawlin Similar To An Ant Low To Da Earth
Nokturnl has a spectacular aura aboutNokturnl has a spectacular aura aboutNokturnl has a spectacular aura about
Cwick187....to answer your question reguarding idle qulity
Says on the spec sheet...Stage 1 idle to 7000+, Stage 2 1000-8000+. Meaning that with the stage 2 you will be above the stock idle...780ish. That alone should tell you that the ECU can't stay stock cause there is no other way to adjust idle but set screw and that WILL throw an idle adjustment code. ONLY way to fix this wis with the EMS. No other unit for ours cars has the ability to change this.
Old Sep 16, 2005
  #88
tfnaaf's Avatar
BLDNPSI Mod
Here is a explanation taken from HERE
CLOSED LOOP
Definition: The basic principle of electronic engine management in which input from an oxygen sensor allows the engine control computer to determine and maintain a nearly perfect air-fuel ratio. To enter closed loop operation, the oxygen sensor must be producing a voltage signal and the engine must have reached a certain operating temperature.
OPEN LOOP
Definition: A mode of operation in a computerized engine management system that occurs after a cold start. During open loop, the computer provides a fixed air/fuel ratio that is richer than normal to improve cold derivability until the engine warms up.
Old Sep 16, 2005
  #89
turboengnr's Avatar
DONT PANIC
the 1000-7000 means that is where the power band is.
I have an edelbrock cam that has an RPM range of 1500-6500 in my corvette. It still idles great at 650 RPM.
Old Sep 16, 2005
  #90
cwick187's Avatar
cwick187 is an unknown quantity at this point
Yeah, I just wonder if any of these cams were R & D'd...If they said the stage 2 had a stock idle and all these people are having problems, will the stage 1 be any differnet regardless of what they say on the specs
