Cant take oil pan off!
I unscrewed all visible nuts and bolts that hol it, it's not comming off!
Also I noticed, my oil pan made out of aluminum and uses a paste, rather then "normal gsket".
Is there a special technick I need to use? Tools?
Please help
Please help
well I wasnt sure of plastic, but I do know its made of cheaper material, dont exactly know what material, but considering plastic is cheap, I said plastic.
IM 100% sure that the lx model has a cheaper oil man than the ex model.
SRT-4 owner with 2MCHPSI
if you have removed all the nuts and studs holding it on, then i recommend tapping it with a rubber mallet...basically you just have to break the gasket seal...that is probably what is giving you trouble...i ran into that when i took mine off the first time
Look in through the wheel well on the drivers side and there is a tab at the top of the pan. You have to pry on that tab while hitting the pan with a rubber mallet. Also, if you go under the car from the front, there is another tab on the oil pan towards the tranny. Pry on that while beating it with a rubber mallet. I also took a gasket scraper and lightly tapped it in along the pan to help break up the seal.
Originally Posted by C2i0v0i1C
one of the models is made of something that is not WELDABLE.
Yeah, its off now!
I used mini-pry bar, as advised, and pulled it off corenrs. It came off, but the hell, it was difficult, it did not want to let go..it was holding to the cylynder block as mother to her child...
DONT PANIC
The only difference is that the vtec models have an aluminum pan while the non-vtec models have a steel pan.
Originally Posted by turboengnr
i have welded the pans on an Lx, Dx, Hx, and Ex.
Originally Posted by 03-Acura-1.7-EL
Also it was pain in the butt to put the pan back on, but its finaly done.
The most difficult part if the project so far..
SidCivic
17
Aug 23, 2015 03:14 AM
fafa1234
Aug 8, 2015 06:42 PM
fecrni
Aug 8, 2015 06:15 PM
Q-Bert
Jul 19, 2015 09:09 PM
