*Title Changed* Fuel/Car Issues
Old May 30, 2005
  #31
andyman97's Avatar
Turbo Guru
Originally Posted by opto_isolator
You are forgetting something. What happens when you boost? You put pressure into the cylinder head. You are creating a pressure differential. The cylinder head is normally at VACUUM when driving, pulling fuel into it from the injectors. When there is pressure in the cylinder head, you are causing LESS fuel from the injectors to go into the cylinder head (granted you are still getting fuel, but its LESS because of the 5-10 psi of boost or whatever you are running). That's why you NEED an external boost referencing FPR! If you don't run with one, and ONLY rely on the FPR in the tank, your fuel pressure will NEVER raise to compensate for the boost pressure. 1:1 - for every 1 PSI of boost pressure you add, you need to add 1 PSI of fuel pressure to compensate - keeping your fuel trims equal across the board. This isn't going to damage your injectors OR fuel system, as the static pressure across the injector remains the same as it did without boost.
That may be accurate but the fpr is still not necessary. With properly sized injectors, you can still deliver the fuel you need with no aftermarket fpr. Either way, I plan to run a wideband and it'll be interesting to see what happens over 5 psi of boost. Good info though, nonetheless.
Old Jun 3, 2005
  #32
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
hey say if I cant find any Type S injectors, what do u guys think about the EP3 injectors?
PiCASSO
Apr 23, 2002 12:38 AM
CIVICTypeRookie
Apr 12, 2002 09:09 PM
droidekaus
Mar 18, 2002 02:06 PM
PiCASSO
Mar 10, 2002 01:34 PM
RiCeGrL
Feb 21, 2002 09:07 PM
