Turbo D17 or K20a?
Old Jun 4, 2005
  #31
Caucasian.Asian's Avatar
think of it this way...
if you boost your civic, thats pretty much it. no more HP for you.
if you swap, you get about the same amount of HP BUT you still have the decision to boost, nitrous, NA, whatever you want.
so, if you just want to be in the range of 200 ponies just boost, if you want more, swap. no one really needs more than 200hp anyways.
Old Jun 4, 2005
  #32
nova4dr_racer's Avatar
nova4dr_racer is an unknown quantity at this point
well not really .. cuz u could always boost more & more all the way to 30 psi ..
Old Jun 4, 2005
  #33
chriscivic's Avatar
chriscivic is an unknown quantity at this point
a local shop here in sc quoted me $3800 for a full k20a2 swap. i didn't believe them at first, so i asked if they knew they needed the subframe, wiring harness, basically a whole front clip, they said they would get a jdm type r front clip with full install for still $3800.
Old Jun 4, 2005
  #34
Ashhole's Avatar
Ashho-san 7thgen Ninja
Ashhole will become famous soon enoughAshhole will become famous soon enough
dude your the 2nd person to say that. what part of sc you in?
Old Jun 4, 2005
  #35
turboengnr's Avatar
DONT PANIC
Im not done making more power with the d17. And im pretty sure the stock k20 wont be able to hold more power than my motor. And im pretty sure a built one wont be much superior to mine.
Old Jun 4, 2005
  #36
chriscivic's Avatar
im in clemson,sc and the shop was psi in central,sc but they have moved to seneca and have a place in nc somewhere also
Old Jun 5, 2005
  #37
Blackness's Avatar
From: Charlotte, NC, But Greenville, NC for School-ECU
Blackness is an unknown quantity at this point
The place in NC is Charlotte. On North Tyron street I think...
Old Jun 5, 2005
  #38
Ashhole's Avatar
sweet. i just drove by psi last weekend. didnt even know it was up there. there was a place in Fort Mill that gave around the same price, but they dont have the best reputation for quality.
btw its on sharon amity i think
Old Jun 5, 2005
  #39
Ashhole's Avatar
I dunno man. I hear a D17 tops off around 300whp. And u can get a k20 over 400whp.
of course with that much power you may want to think about spending the money for an AWD conversion. Be expensive but you could do it.
Old Jun 5, 2005
  #40
xschizx9's Avatar
xschizx9 will become famous soon enough
Can you find a number for the shop... if there talking those prices I want to check into this...
Old Jun 5, 2005
  #41
andyman97's Avatar
Turbo Guru
Ok, apparently whoever told you that knows NOTHING about motors. First off, I have seen d series motors put down over 400 hp. How can anyone make a claim like that? What would limit you in making horsepower? Only thing is displacement. Do you really think that a 1.8 litre Honda motor can make over 800 hp but a 1.7 can only make 300? Doesn't make alot of sense does it?
Of course having two cams produces higher horsepower numbers just because of the cam overlap that you can create but that isn't everything, that is just more efficient flow capability. There is also a k series motor that I have seen put down over 700 hp. But guess how much money went into that setup? Probably around 20-30k (on top of the car.)
We're talking efficiency here. You want something fun and quick. Why spend the extra on a new motor when you can boost your car up to 10 psi for less and get more power and speed?
Old Jun 5, 2005
  #42
Sko's Avatar
Sko
Sko is an unknown quantity at this point
This is a pretty good topic.
I been trolling around these forums for a few weeks thinking about this question, also thinking about saving for an 06 Si.
I have never known anything about cars til about 2 months ago, and since I haven't been able to stop learning more about them.
Anyways, back on topic, the K20a2 swap sounds like you might as well get a new car, unless you want a sleeper, which is what some do want. The turbo sounds like a good option other than the reliability aspect, but for an extra 1000 for internals, another 1000-2000 for dyno tuning it can be reliable.
I wish the 06 Si would come out so I could do a better comparison... It's going to have LSD, six speed shifter, and gawd damnit November is the earliest anyone will be able see the production version...
Hey Andyman, do you have any numbers with your turbo? 0-60 & 1/4mi?
btw- somone mentioned something about the axles only handling 200hp? anyone know if it's an issue?
-Sko
Old Jun 5, 2005
  #43
andyman97's Avatar
Turbo Guru
As far as the si, nobody knows for sure what's going into it. Everything is speculative at this point.
Dyno time will not run you a grand. Should be well under 500 unless someone is trying to rip you off.
I don't have 60 ft times or quarter times yet. I haven't finished everything on my current setup. I still need to pick up a few more things. Expect some dyno hp numbers by july 1st (hopefully.)
Old Jun 5, 2005
  #44
atl01's Avatar
this has been an atl01 production..
atl01 will become famous soon enough
well boosting a D17 is good because if you blow it up you can always pick another one up for a decent price and learn from your mistakes. theres only so much you can do to a D17. and the aftermarket products arent very plentful as it is for a K20. But i think you would come out on top if you did a k swap, then you could allways boost it down the road, or do a toda cam package or something.
Old Jun 5, 2005
  #45
Jeromie's Avatar
Jeromie is an unknown quantity at this point
if i could do it over again i would swap, once u boost for a bit ur gonna want more... then imagine how sick it would be to have a k20 boosted
Thats just my opinion
Old Jun 5, 2005
  #46
andyman97's Avatar
Turbo Guru
Well, there is now a compatible aem ems with the d17. So with that standalone, you are completely UN-limited now!
Old Jun 5, 2005
  #47
atl01's Avatar
yeah thats the way i fell about it, All though i dont have a k20A or A2, I just made up for not haveing real vtec by boosting it
Old Jun 6, 2005
  #48
milba's Avatar
milba has a little shameless behaviour in the past
question on forced induction for the d17,
i live in australia and here the cars are RHD so im wondering if there would be ne problems for installing a turbo ie space wise?
Old Jun 6, 2005
  #49
atl01's Avatar
Should be a problem. everything should bolt up fine. Does everything in the engine bay sit the same as the USDM spec model?
Old Jun 6, 2005
  #50
Ashhole's Avatar
Thats along the lines of what i wanna do to my car eventually. Boost a k20a, would like it to put down over 400whp when im done. Then im gonna do an AWD conversion on it.
Old Jun 6, 2005
  #51
LayinLo's Avatar
LayinLo is an unknown quantity at this point
I've had this same dilemma. As far as boost goes...........when is it too late to turbo an engine?
How many miles are too many?
Old Jun 6, 2005
  #52
atl01's Avatar
I wouldnt turbo any thing over 50k. but i guess it also depends on how you have driven the car since you have owned it, and maint also.
Old Jun 6, 2005
  #53
WhiteCastle's Avatar
buy some sea foam to clean the carbon deposites and your all set after that Also replace the head gasket just to make sure..
Old Jun 6, 2005
  #54
Ashhole's Avatar
sea foam? where do you buy sea foam?
Old Jun 6, 2005
  #55
atl01's Avatar
its that foamy **** you see on the beach after the tide goes down. Gather abunch of it in a bucket and run it into your intake. J/K, yeah what is sea foam?
Old Jun 6, 2005
  #56
http://www.seafoamsales.com/motorTuneUp.htm
dont know been covered on this forum. Stuff does what it is meant to do. clean all the **** out of your engine
ohh ya just to note this stuff isnt legal to have in california but I bet you figured that out
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
C-Hamm
Sep 28, 2015 10:31 PM
justcruzin125
Aug 11, 2015 09:09 PM
Kyle Cargazm
Jul 16, 2015 02:06 PM
