How do you run your IC piping on both sides?
Also if you look at where the pipe goes in to the TB, the pipe i have didnt have a tight enough radius so i took 3 little pie wedges out of it and then bent the pipe in to a tighter radius and welded the cuts up. I stilll need to grind down all the welds and make it look pretty with some powder coating!! And if you look close you can see where i mounted the IAT sensor in to the pipe via welding a nut to the pipe then threading the out side of the sensor 10mmx1.25 and it worked beautifully!
CarStuff
Dec 6, 2020 12:52 PM
mrcell24
May 19, 2015 10:02 AM
mievil
Apr 28, 2015 11:02 PM
