Turbo Upgrade Parts
Originally Posted by exturbo6
they do not make a better HG for our cars yet.
IF YOU WANT AN AFTERMARKET HG YOU GOTTA CALL!!!!!!!!!!!!!!!!!!!!!!!!!!!!
7thgen Power Maker
HG may not be necessary until the 225-300 WHP mark with good tuning and EMU
Definitely turbo pistons w/ thick rings
Forged turbo rods
Possible Sleeving of the motor**
Return fuel system
Larger injectors
Upgraded fuel pump
Go stand alone engine management**(be the first on here) Haltech, Tec3, HKS F-con...
That should equip you enough to handle 15-18 PSI easily.
** indicates that not entirely necessary.
Forged turbo rods
Return fuel system
Larger injectors
Upgraded fuel pump
yeah, get a 9:1 compression, and a good tune, stack 2 HG's if ya want, that will drop compression a little bit (allow for more boost), definately stand alone emu.
wtf..........you don't need nothing.
why spend the money if it is not needed. I've been boosted for over 1 yr and i run 9psi daily.
I have hit well over 10psi many many times. My motor is still completely stock and I still have my factory clutch and HG.
$5,000 later.........
just keep it stock unless you wanna boost more than 10psi daily
DONT PANIC
i agree.... everyone cries about head gaskets. WHY?!?
There is nothing wrong with an MLS gasket. The stock honda gasket is awesome. The only thing that causes them to blow is detonation. If you detonate, you will probably blow most aftermarket gaskets, unless you get a copper one. I have several friends running the stock head gaskets on their cars, and they make insane power. My friend Jeff has a 96 hatch running 10.20's, and making 500+ hp at the wheels with a turbod GSR. And the fastest of my friends ran a 9.30 with the stock head gasket on a turbod GSR. So i would think the stock gasket would hold with some good tuning.
What i do with my motor is....
Torque the head to 59 ft/lbs
tune conservatively
run high octane gas when racing
tune conservatively
Supramk3
Jun 11, 2015 11:13 AM
cloudguy
Apr 28, 2015 05:02 AM
