Dezod Turbo Kit FAQ and DIY
Old May 1, 2007
  #31
ronaldo9's Avatar
Re: Dezod Turbo Kit FAQ and DIY
To my knowledge no. I'll have to ask Paul or Chris but if you have an EX ecu I'd let your ecu control vtec. If you did a headswap my buddy did some rewiring so he sends a 12volt signal at 3200rpms to engage vtec.
Old May 1, 2007
  #32
Buds302's Avatar
Buds302 will become famous soon enough
sell the vafc2 and buy an Emanage or something along those lines. my car was just tuned with emanage yesterday. i am curently running the Dezod V1 kit. ( he is now selling the V3) i made 218hp/198tq at 10psi with emanage. it took a total of 2 hours to dyno tune from scratch. i was actually there 5 hours but they couldnt keep the o2 sniffer in the pipe. it kept falling out. Emanage can be had for under 300 bux. do some looking.
Old May 1, 2007
  #33
dezod's Avatar
7thgen Power Maker
Originally Posted by bigmax1665
does PCS control vtec?
No it does not.
Old May 1, 2007
  #34
dezod's Avatar
7thgen Power Maker
Decent numbers for sure.
Old May 1, 2007
  #35
ronaldo9's Avatar
Nice numbers . What injectors are you running?
Old May 1, 2007
  #36
bigmax1665's Avatar
bigmax1665 is an unknown quantity at this point
so you guys think i should just get the emanage. well ill get the emanage when i turbo my car, but i think im gonna go with the ex ecu and engine harness. i know it matters that the ecu is for a manual, because i have a manual, but is it necessary for the engine harness to be for a manual as well? and also, i heard i need to add on a sensor. which one, how? ive looked around for a writeup on this but only found diy for a vafc2.
Old May 1, 2007
  #37
andyman97's Avatar
Turbo Guru
so you guys think i should just get the emanage. is there any specific emanage, or will any one do? and also, i have no idea as to where to bring my car to get dyno'd. does anyone know of a place in central/northern california.
I think you should be patient and wait until you can use a real management system to properly tune. Do it right the first time and you'll save yourself trouble and money.
Old May 1, 2007
  #38
bigmax1665's Avatar
i would like to just get an emanage or something now, but theres just no place in my area that has a dyno. so im kinda stuck using the ex ecu/harness until i turbo my car.
Old May 1, 2007
  #39
andyman97's Avatar
Turbo Guru
Well that's fine. But when you boost, you need more capability over all of your functions. I've said this before so many times but I would never ever run a high performance motor without a standalone ever again. It is the most essential part of your platform, that's the last place I think anyone should ever skimp.
Old May 1, 2007
  #40
bigmax1665's Avatar
alright well thanks for the help.
Old May 1, 2007
  #41
dezod's Avatar
7thgen Power Maker
I would never ever run a high performance motor without a standalone ever again. It is the most essential part of your platform........
True! The flexibility and tuning control is 2nd to none.
Old May 1, 2007
  #42
ronaldo9's Avatar
What Andy said is 100% correct. You CAN get away with emanage. Plenty of ppl are running without major issues however, they have competent tuners to get them running ok. If you don't have any tuners around you or don' t have access to one I would wait also.
Old May 1, 2007
  #43
dezod's Avatar
7thgen Power Maker
Originally Posted by Sujak
**ontopic**
aem ems is nice, buddy running e-manage with little problems.. just install the map sensor got messed.
**offtopic**
Paul make a turbo kit for a k20
I can build you a custom one if you want. I have some mean ideas.
Old May 1, 2007
  #44
Buds302's Avatar
im running RSX type S injectors
Old May 1, 2007
  #45
dezod's Avatar
7thgen Power Maker
On stock fuel pressure?
Old May 1, 2007
  #46
Buds302's Avatar
yes stock pump.stock rail stock everything.
Old May 1, 2007
  #47
dezod's Avatar
7thgen Power Maker
Wonder what type of duty cycle your seeing at the level.
Old May 1, 2007
  #48
Buds302's Avatar
id have to check. ill hook it up tommorow and find out
Old May 2, 2007
  #49
bigmax1665's Avatar
alright. im just gonna get the greddy emanage. is there any specific type. because ive seen them sell from $300-$600. and do all of them control vtec? which ones do/dont? are they any good at controlling vtec? cause ive heard that they're not.
Old Apr 18, 2009
  #50
boostnut87's Avatar
boostnut87 is an unknown quantity at this point
go dezod lol i finally got my *** on here paul, its about time
HondaGuy7
Feb 22, 2016 01:00 PM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
speedlever
Sep 24, 2015 07:18 PM
