Which Turbo??
Which Turbo??
I have a 2001 civic ex 4 door. Which turbo should I get? http://www.turbocalculator.com/sale-garrett.php
I heard the Garrett T3/T04E Hybrid Turbos are the best. What is the difference? I dont want to blow up my engine, I plan on running around 6 psi. Also, what compressor trim should I get? What is the difference? Thanks.
SRT-4 owner with 2MCHPSI
Originally Posted by NashVegasEX
I was thinking either the T3 Super60 with the .63 hot side or the T3/T04 .50 cold side .63 hot side and a 57 trim wheel ... looking for about 220 whp ...
you can get 220whp out of a much smaller turbo that will spool quicker
7thgen Power Maker
It's all about the flow rates of the turbo. 8 PSI on a T25 doesn't equal, 8 PSI on a T3, doesn't 8 PSI on a T3/T4. People need to get their facts straight.
Not to mention your power band is going to suffer past 4500 RPMS with that T25. (great low-mid)
The T3 will power straight through redline from 3K RPMS (great mid-top end)
The T3/T4 will power straight through redline from 3500 RPMS (great top end)
Originally Posted by TheSmuggler
T28 will see power all the way till redline also....
very true. i love my t28bb. pulls all the way to redline. cant complain execpt for the blown HG. lol. o well its getting fixed monday.
same here, on thursday Ill be getting tuned. thats when my appointment is, so well see what a T25 does. Since nobody likes to post dynos. If I dont scan it, Ill at least type it all up so people can say, LIAR, lol.
Just stay away from Greddy turbos if your going custom
well i am running 5-6psi right now, but i am gettng a new hg and head studs and e-manage...i wanna turn the boost up but i wanna get a clutch first..so im going to have them tune my car at 6psi. then hopefully by next month ill have a new clutch.ill scan thou so poeple can see.
Turbos, Engines, Chassis and Suspension Tech
Originally Posted by dezod
You failed to mention at higher boost levels for that T25. That T25 will have push about 10-12 PSI to see that power at the wheels. While a T3, can see that power at 8-10 PSI, then a T3/T4 at say 6-8 PSI.
Sort of. At 8psi a motor will flow the same amount of air regardless of which turbo is on the car. The reason for the powerband differences are because of efficiencies and other factors.
7thgen Power Maker
Different amounts of airflow produced by the turbo are what causes the variance in power. CFM all the way.
CFM is a direct relation to pressure ratio across a medium, in this case, the motor itself. If pressure is raised a certain amount a set amount of air will flow.
in my OPINION i think that the t25/t28 would be the best turbo for ours cars if block/head or not built...dont get me wrong, i am not downing the t3 or the t3t04e, i have had both on my car, but many times i had wished that i had a smaller turbo that made boost sooner, on place being the track....
the t28 that i am looking at getting powered Forced Performance 2Gen Awd to an 11.8 @119mph in the 1/4....i bet he was making a lot more than 250whp
7thgen Power Maker
when i said a smaller turbo, i never mentioned the t25 or the t28, but i dont know where you are getting your info about the t25 loosing power after 4500 rpm...think, why would they use that turbo on factory cars if it isnt going to hold boost throughout the power band...the t28 reaches full boost before 3000rpm, and is very capable of holding boost well past the d17 rev limit....
ok So from what I gather the t25 or t 28 is the best turbos for a stock d17. but is it a turbo that can grow with the motor , say down the road doing an engine swap ?
Well, if you swap to a K20 not many turbos will work for both well. A full-race kit for the K20s has a T3/T67 and that would be HUGE for a D17, so, your SOL in that regard.
So the the t25 or t28 at 5-6 psi is a safe start with most stock parts? and is upgrading the clutch the main replacement part to turn it up to 8-10 psi safely or are there other parts that should be upgraded too? BTW Thanks 4dr for a very straight answer, appreciate it..
Jaryn
May 17, 2016 02:52 AM
