Getting So Pissed Off
Old Feb 12, 2005
JDm7thGen's Avatar
Slow Down Im Gonna Spurt!!
JDm7thGen is an unknown quantity at this point
Question Getting So Pissed Off
I just built a brand new d17 , boosted it with every accessory possible, and now its running bad, i put it on the computer and come to find out there is a short, question is where....im going to pull out every sensor and check to see if there is a wire toching or wire thats loose, im almost there 99.8 percent complete with one badass build and now of course this **** happens, everything went so smooth anyone have any ideas of where else it might be shorting out that causing my revving of my engine to fluctuate. and my idle???
Old Feb 12, 2005
JDm7thGen's Avatar
it just doesnt want to rev right
Old Feb 12, 2005
dirtySAMURAI's Avatar
I log in from time to time
ecu?
Old Feb 12, 2005
JDm7thGen's Avatar
just put a new one in
Old Feb 12, 2005
JDm7thGen's Avatar
injectors, alternator, spark plugs, brand new also
Old Feb 12, 2005
pon55's Avatar
02 sensor
Old Feb 12, 2005
02sleeper's Avatar
Boosted Auto Sedan Project In Progress
02sleeper is an unknown quantity at this point
Originally Posted by pon55
02 sensor
agreed
Old Feb 12, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
did you hook it up to a OBDII scaner?? What is the code???
Old Feb 12, 2005
abmerop18's Avatar
Jam out with your clam out.
MAP sensor. If it is not reading right, the ECU will go into limp mode and the idle will be very low and jump up and down.
Old Feb 13, 2005
streetglower's Avatar
exactly. How do you know there is a short? You need to hook a OBDII scanner and see what code you get.
Old Feb 13, 2005
mxcivic's Avatar
mxcivic is an unknown quantity at this point
what fuel upgrade r u using ?
Old Feb 13, 2005
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
You win.
Old Feb 13, 2005
JDm7thGen's Avatar
yeah thats exactly what is happening slp
Old Feb 13, 2005
JDm7thGen's Avatar
my bad abmerop posted that my fault
Old Feb 13, 2005
HyaBoosta's Avatar
yeah either Map or check the throttle body sensors(IAC valve) oh and what do you mean by fully built? what have you done to the motor?
Old Feb 13, 2005
JDm7thGen's Avatar
pistons, rods, bearings, rings, sleeves, blockguard, mainstuds
Old Feb 13, 2005
JDm7thGen's Avatar
replaced every sensor now, every one
Old Feb 13, 2005
HAVE YOU CHECKED YOUR ECU WITH A OBD II SCANNER? You keep saying you hooked up your computer and you have a short, so I am assuming you hooked one up, but the way you keep talking doesnt sound like you did. Sounds like you dont have a short, sounds like you have a bad part, or you installed something wrong when hooking everything back up. DOnt keep throwing parts at your car, find the cause. Start with running a scanner to the ECU and see if you come up with a code. Most likely you will. If you dont, retrace your install steps. If that comes out fine, think about how your engine works, and start checking stuff that has to do with the problem.
Old Feb 13, 2005
allmotor's Avatar
nor cal 7thgens
why a block guard?
Old Feb 13, 2005
tfnaaf's Avatar
BLDNPSI Mod
i didnt think you could block guard and sleeve a block...hmmm
Old Feb 13, 2005
JDm7thGen's Avatar
before internals i had block guard, now sleeved no longer block guard
Old Feb 13, 2005
allmotor's Avatar
nor cal 7thgens
oh yeah cause block guards suck lol
Old Feb 14, 2005
aellerman's Avatar
aellerman is an unknown quantity at this point
on a side not, how much of a difference does the NX intercooler spray make? it said that a turbo'd honda made 52 more hp but im wondering if thats like a fully built b series or somethin...
Old Feb 14, 2005
JDm7thGen's Avatar
I Look at it more for the use on hot days ....bc colder air is more dense....on a hot day save like 20 hp
Old Feb 14, 2005
gotti's Avatar
^ u fix the problem yet?
hatch90
Sep 3, 2015 08:45 AM
USCGBM
Aug 12, 2015 04:22 PM
Drix
Aug 5, 2015 12:44 PM
iamboo
Apr 16, 2002 12:06 PM
colombianDXcivic
Feb 19, 2002 12:38 AM
